Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Nov 14, 2023 at 4:37 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    sdk1968 and six5crèéd[OP] like this.
  2. Nov 14, 2023 at 5:31 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Now that were talking about splitting wood my brother-in-law was using his log splitter this weekend and got his left ring and pinky caught and lost his ring finger just past his 1st. joint.:eek::annoyed::sorry:
    sdk1968 likes this.
  3. Nov 14, 2023 at 5:31 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :eek::eek::eek:
    sdk1968 likes this.
  4. Nov 14, 2023 at 5:32 AM
    Tiedie
    David
    WFOY
    they had the finger but it was too far gone to save. He's 70 years old.
  5. Nov 14, 2023 at 6:15 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    thats a super cool thing!!
    my wood splitter is still me & a splitting maul. BUT we only burn for fun & as a emergency back up supply.
    have enough wood/trees for one of those.... just no place to put it. need more barn!
    six5crèéd[OP] likes this.
  6. Nov 14, 2023 at 12:38 PM
    sdk1968
    03 Taco TRD
    and no wood needed for the fireplace in the living room.
    she wanted one in there for her birthday & because she is incredibly spoiled.... i made it happen. it was some work to do it in lone ranger mode, but its done. ran the lines, converted it from gas to LP... added a blower.
    wow it will run you out of this room in a couple minutes on low!!PXL_20231114_192412057~2.jpg
  7. Nov 14, 2023 at 1:02 PM
    Tiedie
    David
    WFOY
    She is starting to like the fireplace.
  8. Nov 14, 2023 at 1:31 PM
    sdk1968
    03 Taco TRD
    my dogs hate the real fireplace. when i clank that flu open..... they go in full on attack mode.
    & anytime i go to put wood in? holy crap. Poppy goes full on apeshit crazy. she bites the doors, tries to bite the wood.
    it gets flat out dangerous trying to hold her back & load the thing up.
    usually put her in the crate first, but sometimes you forget.
    KRAMERICA, Tiedie and wilcam47 like this.
  9. Nov 15, 2023 at 4:26 AM
    Tiedie
    David
    WFOY
  10. Nov 15, 2023 at 5:26 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
  11. Nov 15, 2023 at 10:11 AM
    sdk1968
    03 Taco TRD
    got some more outside cleaning done in the shop & then did a little painting on the hydraulic cylinders on the mini X.
    they just looked like they need painted & the machine is a 2007 model.
    just did the 3 on the boom, didnt do the blade cylinder or the boom swing cylinder (which is up inside the body)
    koditten and six5crèéd[OP] like this.
  12. Nov 15, 2023 at 10:15 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    :worthless:
  13. Nov 15, 2023 at 1:12 PM
    sdk1968
    03 Taco TRD
    ask & you get.... :)
  14. Nov 15, 2023 at 1:45 PM
    Tiedie
    David
    WFOY
    I could use 1 of those.
  15. Nov 15, 2023 at 3:24 PM
    sdk1968
    03 Taco TRD
    thanks! its a good little machine. right at 6,000lbs. 21hp Yanmar engine. real strong for its size.
    but its NOT the one i wanted, its just the one that was the best buy.
    still want a Cat 302.7d CR..... but they pricey!!
    would settle for a Kubota U25 too!
  16. Nov 15, 2023 at 4:38 PM
    koditten
    Kirk
    Central Michigan
    She gots remotes! Wonderful unit!
    sdk1968, six5crèéd[OP] and wilcam47 like this.
  17. Nov 15, 2023 at 5:31 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    envy isnt the best. but i would love one of those and your paint looks great. yanmar makes john deere tractor motors too iirc.
  18. Nov 16, 2023 at 6:23 AM
    sdk1968
    03 Taco TRD
    thanks!
    only did those 3 cylinders & decided if there is a rebuild on the other 2 that will do them then cause they hard to get to.
    no need to take it apart until theres a problem.
    the green color on this Yanmar was something they used overseas. so this is a "gray market" machine.
    good news there is Yanmar made zero differences in the machines as far as mechanic/parts & so on.
    it was only safety stuff, killswitches & things like that. havent found any parts that dont interchange with the yellow colored ones that were here in america in 2007.
    this machine only had 18oo ish hrs on it when i got it, but had a leak & the gauge problem we talked about before here.
    fixed that leak, but man it was in a really difficult place. then spent several days cleaning under carriage, inside the cradles, engine compartment & everywhere else that was gunked up. its fairly clean now. cleaned out the fuel tank & sanitized it, did all the filters, fluids & so on. dug a small pond with it here at our place. helped my neighbor take his pond out with it, dug some drainage ditches for another neighbor, did some drainage of my own, dug up couple dozen tree stumps just for practice.
    always loved playing on these things & thats all im capable of is playing. NOT an operator or even skilled at its use ..... but will keep trying to improve.
    someone mentioned that John deeres have this motor a lot.... YUP lots of your smaller JD's have this exact everything.
    think that once they get bigger sizes that they switch to Perkins motors though.
    but i really want that CAT!! had a deal on one & it went south. still looking & might trade around if the right deal comes up.
    cant complain though as this Yanny purrs like a kitten & is doing whatever i ask of it.
    did i mention that i really want that CAT 302.7d CR? LMAO
  19. Nov 16, 2023 at 6:53 AM
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    IMO those Yanmars are just as good as Cats. And cheaper to maintain! That being said I have always been a Cat guy. I suppose because my dad was too. I bought a gray market Cat 306d at auction earlier this year and after getter her fixed up I realized that I had way too much equity in it so I flipped it for a nice profit. Currently looking for a deal on a 305. Once you've owned an excavator its hard to live without one.
  20. Nov 16, 2023 at 9:23 AM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Brute Force 26-24 box wedge
    Does make some trash though which we use for kindling and/or give it away to the neighbors
    Kbar, wdb and six5crèéd[QUOTED][OP] like this.
