Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you wear your seatbelt on your tractor?
  1. Yes
    5 vote(s)
    29.4%
  2. No
    12 vote(s)
    70.6%
  3. It doesn't have one.....anymore
    3 vote(s)
    17.6%
  4. It's connected, but not around me
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Dec 2, 2023 at 4:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    We spend the cold months here. Heading home mid march.
    six5crèéd[OP] and sdk1968 like this.
  2. Dec 2, 2023 at 4:19 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Let know if y'all plan a trip to Biltmore if the stars line up maybe we can meet up.
  3. Dec 2, 2023 at 4:26 PM
    koditten
    Kirk
    Central Michigan
    I'm very much looking forward to that. Most likely it will be after the new year.
  4. Dec 2, 2023 at 4:27 PM
    Tiedie
    David
    WFOY
    Good maybe I can get there too.
  5. Dec 2, 2023 at 4:45 PM
    koditten
    Kirk
    Central Michigan
    i want to try that northern route to Ashville. it looks to be a bit more direct.
    six5crèéd[OP], sdk1968 and Tiedie like this.
  6. Dec 2, 2023 at 5:08 PM
    Tiedie
    David
    WFOY
    Not only that it puts you on the Biltmore side of Avl.
  7. Dec 2, 2023 at 5:25 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I usually use a bungee cord to keep my suitcase weights from clanging around in the winter, but that never worked perfectly. I decided to waste a little time making something more robust from stuff I had laying around
  8. Dec 2, 2023 at 7:04 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    no sleigh bells jingling there.
    tractor mods are time well spent.
    six5crèéd[OP], sdk1968 and koditten like this.
  9. Dec 2, 2023 at 7:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    those weights look like a challenge to mount/remove.
  10. Dec 3, 2023 at 7:39 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    This is a consumer grade ZT for sure. It's a high grade one though; for example the hydro drives have spin-on filters, and the deck is fabricated and very meaty. It's not so much the quality of the materials that bugs me, it's the brain-dead engineering and design decisions.
    23HP Kohler v-twin, 720-ish cc's. I don't put 15/50 in it, it gets 10/30.
    The new starter spins it over without even trying hard. A proper sized battery for the job.
  11. Dec 3, 2023 at 8:38 AM
    js312
    Joe
    New England
    They are actually super easy, just hang on the frame. No rack to attach or anything. Obviously, I remove my clamp mod first so I am not lifting all of them at once.
  12. Dec 3, 2023 at 9:25 AM
    Tacoma Mike
    Southern Maine
    I use a chain and a dumbbell
  13. Dec 3, 2023 at 1:16 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    what you guys doing with those baby weights on those lawnmowers?
    and you both have turf tires with chains.... yall crack me up.
    dont want no chains chewing up my concrete!
    every thing spins on ice though. even AGs. a good blade is key!
    i run this, anybody else got one? https://shop.agricover.com/product/snowsportlt
    granted i run it on my tractor, mini truck & ZT,
    its manual adjust swing, but its very versatile & wont tear up your gravel, asphalt, concrete, bricks or even hurt your grass!
    they pricey, but have had it for 10 years & still works perfect.
    heres a reall good video: https://youtu.be/ZxcuWKCcOPY?feature=shared
  14. Dec 3, 2023 at 3:30 PM
    Tacoma Mike
    Southern Maine
    Mmmmmmmm
    Wasn’t trying to be funny this time. I must be expanding my repertoire…
  15. Dec 3, 2023 at 3:58 PM
    js312
    Joe
    New England
    I have a 44" snowblower attachment. The chains aren't really needed on the solid driveway, but as soon as I go clear anything on the lawn it'd be hopeless without them.
    six5crèéd[OP] likes this.
  16. Dec 3, 2023 at 3:59 PM
    koditten
    Kirk
    Central Michigan
    I just want to know who is throwing around 30# dumbbells? I haven't played with those since I was in my 20's!
  17. Dec 3, 2023 at 4:05 PM
    Tacoma Mike
    Southern Maine
    Dam things get heavier all the time.
    six5crèéd[OP] and joeyv141 like this.
  18. Dec 3, 2023 at 4:07 PM
    sdk1968
    03 Taco TRD
    just funnin ya.
    i get it, trying to get some traction & all. AND anything is better than a shovel.
    even then with the blade.... there is always a spot that takes a shovel at my place.
    do you guys not have 4 wheelers, sidexsides, or tractors?
    do you have enough snow for a blower?
    when was a kid we had a blade for the troy built. That was the first thing we ever got after a shovel.
    now days its all about temperature.
    if its blue balls cold? i put it on the mini truck & sit inside with the heater running.
    if its not real windy/cold? the tractor is better to see with.
    pretty rare that i mount it on the ZT in the winter, thats usually a yard clean up thing.
    now putting this alum/rubber blade on the excavator mounted to the pusher blade? already been planning that, but again: if its real cold will sit in the mini truck with the heater running. Ya gotta get out & flip the blade from side to side, but that minimal vs being out in the cold all the time.
  19. Dec 3, 2023 at 4:14 PM
    koditten
    Kirk
    Central Michigan
    You forgot:
    Go south and not think a bit about it until spring.
    six5crèéd[OP] and Tiedie like this.
  20. Dec 3, 2023 at 4:17 PM
    Tiedie
    David
    WFOY
    Unless you live in the area of the south that gets snow.
    But here today gone tomorrow.
