Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. Dec 11, 2023 at 6:12 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Find out what media you have so you can do it yourself. I have hand written directions but am going to type up so I have clear instructions too. look in you DM's.
    sdk1968 and six5crèéd[OP] like this.
  2. Dec 11, 2023 at 6:19 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Thanks. I see the pm, but no attachment. But there's no rush, the system is working fine currently. To see what the filter media is I guess I would need to pull the timer off, correct? I don't see any unions in the piping, so that would need to be a cut and re-glue procedure.
  3. Dec 11, 2023 at 6:20 AM
    Tiedie
    David
    WFOY
    Nope do you know where the water goes outside of pump house.
  4. Dec 11, 2023 at 6:25 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Yes sir. The pipe extends about 2 inches outside the wall! :anonymous:
  5. Dec 11, 2023 at 6:28 AM
    Tiedie
    David
    WFOY
    Ok ca;cite is kinda white/gray crushed up like kitty litter but smaller.
  6. Dec 11, 2023 at 6:43 AM
    Tiedie
    David
    WFOY
    @DES2009 if you don't see anything it might be empty. I see calcite outside my drain spot in the drivway.
    sdk1968, six5crèéd[OP] and DES2009 like this.
  7. Dec 11, 2023 at 7:45 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    no worries ! all good! pic of my pump below! https://images.thdstatic.com/produc...bmersible-well-pumps-efsub10-253hd-64_600.jpg
    man you have a VERY fine looking pump house & set up! very neat, very clean. doesnt matter that its old. thats a nice looking pumphouse! one of the driest/cleanest ive seen.
  8. Dec 11, 2023 at 8:00 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Ha ha... my brother-in-law had told me several times I needed to clean it up. Because it was pretty dirty and had a bunch of pieces of OSB in it that had been wet and were deteriorated. Three or four weeks ago I cleaned the trash out and then went through it with a broom and then my shop vac. Some of the pictures I originally posted were alter from before I cleaned it up. The other pictures were all taken in the last day or two after it looks like Mr Clean went through there. :D
  9. Dec 11, 2023 at 8:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Is pumphouse envy a thing?
    Doesn't it say somewhere " thou shall not covet thy neighbors pumphouse"?
    I kid, I kid.
  10. Dec 11, 2023 at 8:06 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    The home inspector guy that we hired to go over everything before we bought the house said that it was the finest wellhouse he'd ever seen. People that have been to the house tend to say the same thing about the house and the property. I don't know. It cost us a lot of money, but I'm 70 years old and worked hard for a long time. It was like now or never for us, so we decided to move here. A lot of the stuff in the house ranges between what I would call high-end and Overkill. But we love living here, and the dogs like the wide open space to run in.
    RustyGreen, wdb, Tiedie and 4 others like this.
  11. Dec 11, 2023 at 8:26 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Those pump houses are so foreign to me living up North. Everything is in a basement or deep concrete pit if you have a mobile home.
  12. Dec 11, 2023 at 9:41 AM
    Tiedie
    David
    WFOY
  13. Dec 11, 2023 at 9:45 AM
    sdk1968
    03 Taco TRD
    that is a huge & fine pumphouse! will make a lot of people want to covet. :)
    no pumphouse here at all. will snap you guys a pic a bit later today of what you see on ours.
    hats off to you! i hope that it works out for you that way!
    we undertook this same move when i was 46. (55now)
    we are planning on being here until im 70. if the health allows me to take proper care of it, then sell off at a profit & see what happens.
    all of the animals will have passed by then & daughters should be settled in their careers & ready for us to relocate.
    just remember: man plans..... God decides.
  14. Dec 11, 2023 at 9:52 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Yes, I found that video after your pm. But I did forget to report back and let you know that I'd found it.. :anonymous:
  15. Dec 11, 2023 at 11:33 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    I'm moving out (god-willing and we make it to closing) to a little parcel - 3.5 acres; and I'm trying to convince myself I need a subcompact tractor vs just a mower and a utility trailer. The land will have a walking path next to a wandering pasture for a couple sheep next year, and maybe 10 chickens and that's about it. Need is a funny thing. I *want* a tractor. But to get what I want, I *need* a tractor :)
    As I'm mowing only about 1/3rd the land, I'm considering a standard lawn tractor, but I also want something I can clear a little land/space/over-growth with to build the wandering paths and whatnot. Or to dig up a place for a lined pond/water thing and a tiny excavator would be wonderful. Here's to hoping I make friends with any of the local farmers so I can merely borrow, eh?
  16. Dec 11, 2023 at 7:15 PM
    sdk1968
    03 Taco TRD
    If thats your intended need?
    then just get a compact or sub compact tractor. it can still mow & you will be able to save your back using it for everything else.
    heres your excuse: if you gonna have animals? you gotta haul feed, hay, muck, mow & so on.
    its much more likely that you can avoid the injury with a tractor & FEL.
    just make sure you get something with at least a 3point hitch on the back.
    FEL is great, but not a must have for hobbying. you can make a carry all for the back.
  17. Dec 11, 2023 at 7:19 PM
    DetroitDarin
    York County PA
    Thanks! :) Sound reasoning. Now I have to come to terms with 15k or so...It'll take some time as the closings costs nowadays are astronomical.
  18. Dec 11, 2023 at 7:42 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    well im thankful my well system is relatively new. im lucky too. comes out the faucet unfiltered and is perfect. my maintenance day will hopefully be a ways out.
  19. Dec 12, 2023 at 4:09 AM
    sdk1968
    03 Taco TRD
    Ok now that you got some info, this won't hi Jack your question/info.
    Next thing:
    Anybody got a GOOD line on a Hustler 6400 hillsider?
    six5crèéd[OP] likes this.
  20. Dec 12, 2023 at 4:12 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Heh, my house was half the price of yours and I was still pulling my hair out over all the cost :laugh:
    Luckily for me I acquired all the needed lawn equipment over the years beforehand. Now, all the home improvement stuff, yea that's still hurting :laugh:
