Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you wear your seatbelt on your tractor?
  1. Yes
    5 vote(s)
    29.4%
  2. No
    12 vote(s)
    70.6%
  3. It doesn't have one.....anymore
    3 vote(s)
    17.6%
  4. It's connected, but not around me
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Jan 19, 2024 at 7:33 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Having both Kubota & Kioti..... I'm gonna say this:
    In Kubota: nothing smaller than B2601 or L2501 (if I go back to Kubota only? L3901 for me!)
    Kioti: for sure you want the 3510 or 4010. tractors are identical frame, just a few extra HP on the 40.
    For what you are saying you are gonna do? Anything smaller than these will not have enough PTO or pump power to do what you want.
  2. Jan 19, 2024 at 8:30 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
  3. Jan 19, 2024 at 8:54 AM
    w.adventures
    Nowheresville, SC
  4. Jan 19, 2024 at 9:14 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    In the Kioti brand for 3 acres, I'd stick with the CK line. If your pocket book can handle it, I'd go with the CK3520SE HST or CK4020SE HST. You'd have choice of back and forth work, you'll want an HST trans over the Shuttle shift.
    The DK line would be nice, lots of power, but over kill for 3 acres. More importantly if you're going to be in the trees a lot, I wouldn't want a cab tractor. Having AC and heat, a radio are nice pluses, but tree branches break cab windows and doors, and they are about $1k each to replace.
    I generally think Kubotas are over priced, but this one, if it isn't a scam, is attractively priced. New that would be over $40K.
    Edit: Due to the over abundance of scammers out there, I wouldn't be sending any money to hold this. But I'd call the guy and if you think it's legit, I'd race up there to get it.
  5. Jan 19, 2024 at 10:10 AM
    sdk1968
    03 Taco TRD
    KR & me are very like minded on tractors.
    I agree with everything he said in that post.
    Kubos are pricey. Tht 1 is probably a scam.
    The Kioti 53 series is just too big for us small farm set ups.
    Oh & yes if you got enough power to spare? HST is the way to go.
    I run 5' tiller, 66" hog, 6' blade, stump grinder, grapple, plows, box blade & so on w/a ck4010.
  6. Jan 19, 2024 at 11:39 AM
    w.adventures
    Nowheresville, SC
    All good info! I will have to swing by the local dealer and check them out.
  7. Jan 19, 2024 at 4:58 PM
    sdk1968
    03 Taco TRD
    KRAMERICA and six5crèéd[OP] like this.
  8. Jan 19, 2024 at 5:29 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  9. Jan 19, 2024 at 6:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Front and rear array with logging!
  10. Jan 20, 2024 at 7:30 AM
    leftright
    leftright Well-Known Member
    charlie
    south Texas
    2023 tacoma SR5 DCSB celestial silver Technology package black out package tinted windows
    Clazzio seat cover Vled tail light conversion
    I was mowing on my Zero turn and lost my phone again haha I searched everywhere and saw a shiny piece in deck cover yep there it was it went thru pulley system until it got stuck the pulley dug a hole in battery there was a small fire but the screen protector held fine not a crack O well off to get another cheap phone20200204_161518.jpg
  11. Jan 20, 2024 at 9:43 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    o_O:rofl::rofl::rofl::rofl:
  12. Jan 20, 2024 at 11:07 AM
    sdk1968
    03 Taco TRD
    do run a rear camera when grinding lots of stumps... Helps the neck.
    But not into the whole GoPro thing people do. I do too much dumb shit for those.
  13. Jan 20, 2024 at 12:07 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  14. Jan 20, 2024 at 12:35 PM
    sdk1968
    03 Taco TRD
    yep that looks a lot like the one in use here. mounted it low down at the leg so it looks right at the grinding wheel.
    if you are doing a lot of grinding its a neck saver for sure.
    six5crèéd[OP] likes this.
  15. Jan 20, 2024 at 6:37 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Got the heads off today. Both head gaskets looked great.
  16. Jan 21, 2024 at 5:56 AM
    sdk1968
    03 Taco TRD
    So its saveable?
  17. Jan 21, 2024 at 10:36 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    same stuff. if i had one she would know i rolled my riding mower....twice.
  18. Jan 21, 2024 at 10:39 AM
    Tacoma Mike
    Southern Maine
    Well not anymore because you took it apart and now they’re ruined.
  19. Jan 21, 2024 at 12:12 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes sir, just got to get the valve guide back in place and locked down.
    Delta09, sdk1968[QUOTED] and koditten like this.
  20. Jan 21, 2024 at 2:10 PM
    w.adventures
    Nowheresville, SC
    Well, I was looking into a new Kioti. Looks like they have 0% financing for 72 months and .99% financing for 84 months. Even with 84 month financing the payment will be about $375 a month. Need to win the lottery or find a really good deal on a older one :annoyed:
