Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    44.8%
  2. After
    58.6%
  3. Neither
    13.8%
  4. I weed whack while someone else mows
    6.9%
Multiple votes are allowed.
  1. Mar 11, 2024 at 11:42 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Good neighbors are worth their weight in GOLD!
  2. Mar 12, 2024 at 5:46 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Finally collected a bunch of stuff over the past couple weeks to refresh the new to me Kubota L245. Going to start chipping away at items on the list tonight and hopefully get it all knocked out before the ground dries.
    2 new front tires and tubes
    Engine Oil
    Transmission/hydraulic oil
    Oil Filter
    Fuel Filter
    Transmission Filter
    Coolant flush
    4 new steering tie rod ends
    LED headlight bulbs
    Injector Cleaner
    Red-n-Tacky grease for all the zerks
    And fresh fuel to clean out the tank and re-prime the fuel filter with
    Also going to replace the dated and not bright incandescent rear light with a pair of LED amber pods I had as ditch lights on my Tacoma that I am no longer using.
    I then bought some 5/8 steel rod and a steel sleeve that I am going to weld up a passenger side extendable tie rod and tap the end. The passenger side tie rod is a tie rod end with a extension as one unit and is 300ish to replace the tie rod so I am going to weld up a new rod and make it so the tie rod end is replaceable for the future. All in all it cost me $150 with the new tie rod end and I should be able to drill/weld/tap it all out myself.
    I also picked up a 3 point boom pole from TSC. I have a bunch of trees and piles of old trees that need picked apart and burned in smaller piles Ill use the pole with.
  3. Mar 12, 2024 at 7:05 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    my main reason for posting. im really greatful for everything!
  4. Mar 12, 2024 at 7:24 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Cause everyone needs a 36” bar :eek:
    Delta09, sdk1968, KRAMERICA and 5 others like this.
  5. Mar 12, 2024 at 7:28 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek::eek::eek:
  6. Mar 12, 2024 at 7:48 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Da Chain! Da Chain!!
  7. Mar 12, 2024 at 7:52 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that is a spooky big saw. iirc its 8.6hp. savage.
  8. Mar 12, 2024 at 8:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Gas tank is empty, it cleaned up good though. He told me he paid $2,500 for it new in 2016 and he’d like to pocket $1,200 for it. That leaves me some room to make a little on it.
    Delta09, sdk1968, 308savage and 5 others like this.
  9. Mar 12, 2024 at 9:04 AM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Your "new" limbing saw?
  10. Mar 12, 2024 at 9:18 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It had a touch of gas in it, I pulled it a few times and it fired up. Sounds like a 2 stroke motorcycle. I'm not man enough to handle it for long, I got some wood I'm gonna play with it in before putting it up for sale. You know, to make sure it works like it should..............
    Delta09, Lt. Dangle, sdk1968 and 4 others like this.
  11. Mar 12, 2024 at 9:27 AM
    StihlToyota
    Mark
    No. Idaho panhandle
    The 880 was the only saw I had to start on the ground as the 41" bar & the heft of the damn thing made it unwieldy otherwise on drop starts.
    Didn't keep mine for long either, migrated to ported 660s,661s & 395s
  12. Mar 12, 2024 at 10:00 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Was the porting worth it on your 395? I am tempted to do it on mine
  13. Mar 12, 2024 at 10:58 AM
    StihlToyota
    Mark
    No. Idaho panhandle
    Yes, but that was back in the days of $275 plus shipping instead of the $400+ now (plus shipping)IMG_1037.jpg
    Ported 395 & 385
    But I suppose after spending $50-55 K on a new Tacoma, $400 isn't much
    Better mid range & top range
    Even opening the muffler & reducing the squish will make for good improvements
    Always big wood laying around
  14. Mar 12, 2024 at 5:29 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my father built competion saws, and raced them. porting was just the start until he built his own custom pipes. i have 10 1st place trophys of his i need to hang. reed valves, compression tricks, and freezing temp race fuel. he even build his own flow bench to test. he was pretty rad. most were super modified 066 and 044 mags. he would build a chain link by link hand filed 12/1000 thinner then tefloned. jewlers rouge for mirror/ razor sharp. he was my idol and main man.
  15. Mar 12, 2024 at 5:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    cant remember if it was an up,down, up but think it was on a 21" log. 2.23 seconds. super impresive. being full time logger helped.
  16. Mar 14, 2024 at 8:02 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I listed the saw on marketplace for $1,850, one offer so far for $1,250. No thanks.
    sdk1968, KRAMERICA and koditten like this.
  17. Mar 15, 2024 at 3:58 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Been on the B7100 last couple days for a few hours each day. Smoothing out the old barn footprint. P.I.A. because of all the junk buried in the ground. I only have a scrap blade so there's that too. Getting better just need to work on the corners where springs are. Maybe ready for grass seed and straw by next week.
  18. Mar 15, 2024 at 4:07 AM
    w.adventures
    Nowheresville, SC
    :worthless:
    sdk1968 and six5crèéd[OP] like this.
  19. Mar 15, 2024 at 4:25 AM
    Tiedie
    David
    WFOY
    Yes! :rofl:You know that's my weakness no phone while I am outside working. Just call me old school. I can go anywhere without it.:burp:
  20. Mar 15, 2024 at 5:55 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The Kioti I worked on for my buddy is doing good, he bought an aerator for it and said he told his kids to get stuff out of the yard. Is that a first down or a fumble?
    JGO, KRAMERICA, Delta09 and 6 others like this.
