Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.7%
  2. After
    57.1%
  3. Neither
    11.4%
  4. I weed whack while someone else mows
    5.7%
Multiple votes are allowed.
  1. Mar 23, 2024 at 12:51 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    You can turn your prv up. Those hoses and seals are prolly rated over 3k but I don’t know much about the red or orange tractors.
  2. Mar 23, 2024 at 1:05 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Yeah, that's an option on the Kioti. There are several videos on YT that show how to do it. I've not done it, as my hydro will outlift the counterbalance I currently have available now, so I don't need more. I have plans to build a proper 1200# counter weight box that will increase the what the tractor can lift. Once I have that, I might adjust the pump flow up a bit.
  3. Mar 23, 2024 at 1:47 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    KR,
    my counterweight box is only #650lbs loaded, but then got another 350lbs total in the two back tires... puts it at about 1k of counterweight. That covers me at max lift pretty good.
    w.adventures and six5crèéd[OP] like this.
  4. Mar 23, 2024 at 1:51 PM
    Kbar
    Western WA
    22 OR
    Better look to your manual more. 650 lbs is barely enough ballast for a scut. Loaded tires help but they’re not counterweight.
    sdk1968 and six5crèéd[OP] like this.
  5. Mar 23, 2024 at 2:11 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    More tractor for less than what I paid for my Kubota
  6. Mar 23, 2024 at 2:33 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    My back tires are loaded with about 500# of beet juice, and my heaviest implement is the brush hog at about 700#. But the brush hog is very long and difficult to use in tight spaces. With the box blade which is about 350# I've still managed to lift the back off the ground. I want a build a box that will only add a couple feet to the back, but have more ballast than the brush hog. I figure 1200# will be more than sufficient to do the job. Given you only have brakes in the back I want to make sure the tires stay on the ground!
  7. Mar 23, 2024 at 4:19 PM
    sdk1968
    03 Taco TRD
    Like KR said... Most of my implements are between 500-700lbs. 650lbs hanging 2' behind me has been plenty for a ton in the bucket or on the forks. Still got hanger holds that could ad more weight if needed but cant really pick up anymore than that on the front anyway.
    Kioti & Kubo's are fairly rear heavy right out of the gate. Especially these newer models like we have.
    Roll around weight for me is about 4,850lbs.
  8. Mar 23, 2024 at 4:58 PM
    Kbar
    Western WA
    22 OR
    Been through ballast plenty so I won’t be the disruptive one here. If it feels good, run it. My goal isn’t to be a know it all but spread awareness that a lot of people don’t have enough ballast when they think they do just because their tractor weighs x amount. Just being a friend here. Not trying to ruffle no one’s feathers. BTW scrap steel makes awesome ballast
    upload_2024-3-23_16-55-34.jpgupload_2024-3-23_16-56-53.jpgupload_2024-3-23_16-58-4.jpgupload_2024-3-23_16-58-29.jpg
  9. Mar 23, 2024 at 6:22 PM
    Kbar
    Western WA
    22 OR
    Dunno where else to put this. Don’t see a shop thread so
    upload_2024-3-23_18-20-26.jpgupload_2024-3-23_18-20-43.jpgupload_2024-3-23_18-21-2.jpgupload_2024-3-23_18-21-22.jpgupload_2024-3-23_18-21-41.jpgupload_2024-3-23_18-21-58.jpgupload_2024-3-23_18-22-13.jpgupload_2024-3-23_18-22-27.jpgupload_2024-3-23_18-22-38.jpg
  10. Mar 23, 2024 at 6:25 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  11. Mar 23, 2024 at 6:26 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  12. Mar 23, 2024 at 6:27 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  13. Mar 23, 2024 at 6:27 PM
    Kbar
    Western WA
    22 OR
  14. Mar 23, 2024 at 6:27 PM
    koditten
    Kirk
    Central Michigan
    Hopefully the hint sticks.
  15. Mar 23, 2024 at 6:36 PM
    Kbar
    Western WA
    22 OR
    Hint taken. Won’t bore you anymore
  16. Mar 23, 2024 at 6:44 PM
    koditten
    Kirk
    Central Michigan
    Well, to be technical, your submission is actually a welding project.
    It would fit just as well in this location.
    Just between us girls, it's gonna get the most attention in the thread we 1st posted.
    https://www.tacomaworld.com/threads/anything-welding.113957/
  17. Mar 23, 2024 at 7:25 PM
    Kbar
    Western WA
    22 OR
    Thanks for the links. I’ll show myself to the door. Again I apologize for the disruption. Be safe
    six5crèéd[OP], koditten and sdk1968 like this.
  18. Mar 23, 2024 at 7:35 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Come on over to the shop thread, we occasionally build stuff - and have some fun too. ;)
  19. Mar 23, 2024 at 7:58 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Are you using a backhoe to dig those stumps out? Or the loader? Looks like I can rent a 9500lbs excavator for a weekend for $1100. Have 12 more big trees to cut down and then plan on digging them all out.
    six5crèéd[OP] likes this.
  20. Mar 23, 2024 at 7:59 PM
    w.adventures
    Nowheresville, SC
    Turned out really good!
