Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Mar 25, 2024 at 4:10 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I bought mine when Ryobi Days were going on. Buy 2 batteries get a free tool deal, and it has been handy!
  2. Mar 25, 2024 at 4:13 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    another way to clean belts or paper is a fireplace brick. diamond blades for example are a combo of steel and diamond. they can get gummed up cutting soft material. finding a stone or such of the correct hardness can clean it up when (dressing) the blade.
    other near useless facts- i clean/ tune my tile saw blade by holding my angle grinder perpendicular to the tile blade. (both tools on) with 80 grit sandpaper. creating a square cutting edge on the blade. reduces runout, cleans, and cuts noticably better and straight(er) cuts. a rounded blade surface can have 20% more cutting surface slowing the motor.
  3. Mar 25, 2024 at 7:14 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Yeah, I wouldn't mind if you could wipeout all the inflation from the last six years!:annoyed:
    The CX2510 will still be a good fit for the size of your property.:thumbsup:
  4. Mar 25, 2024 at 7:28 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I don't have a plow for the tractor and the ground was too hard for the tiller to dig in much. So I improvised with the box blade to dig up the ground for a garden. I'll give the tiller another go, hopefully it'll go a little easier now.
  5. Mar 25, 2024 at 7:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have cement hard dirt im my garden area. we bought a dozen 100gal rubbermaid horse troughs. black plastic wont breakdown/no maintenance. elevated so mole proof, stays warmer earlier to get crops going. 4 years of portable success. just drilled drain holes in bottoms. just an idea.
  6. Mar 25, 2024 at 8:08 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    It would probably be fine but I went from wanting the ck3520 and ck4020 to the ck2620 already. Don’t need the horsepower but I do want the loader capacity.
  7. Mar 25, 2024 at 8:20 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    My aunt did a raised bed the last couple years. I'm trying to keep the cost down but also increase the size of the garden. If I stick with the ground garden, I won't need to buy so much soil.
  8. Mar 26, 2024 at 10:14 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Any of those Kioti's is a good tractor! I'm partial to my ck4010 & sure KR is to his 35...
    Yeah man always another way to do it. Once you have the tines from the box blade bust it up.... A couple passes with the tiller should make that real nice!
    w.adventures and six5crèéd[OP] like this.
  9. Mar 26, 2024 at 11:53 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Youll find uses for that extra horsepower though!
    But really, Ive been happy with our 2610. Only a few times Ive wished I'd gone with something bigger (mostly using pallet forks). I havent done the "mod" to up it to the 35hp as Im under warranty. But itll scoop a full bucket of dirt/gravel just fine.
  10. Mar 26, 2024 at 2:20 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  11. Mar 26, 2024 at 5:04 PM
    sdk1968
    03 Taco TRD
    Doesn't really matter what it is in life........ There is no substitute for more cubic Inches.
  12. Mar 26, 2024 at 5:09 PM
    w.adventures
    Nowheresville, SC
    Went to the Kioti dealership after work today and they had a CX2510 and CK2620. I must say the CX would be the perfect size but the lift capacity is so much more on the CK. :annoyed: Even more confused on which one to get now.
  13. Mar 26, 2024 at 5:59 PM
    sdk1968
    03 Taco TRD
    Same motor on both, but way more capability & strength on the CK.
    six5crèéd[OP] and w.adventures like this.
  14. Mar 26, 2024 at 6:16 PM
    w.adventures
    Nowheresville, SC
    Just watched a dealership YouTube video and it said the CK engine is close to the same as the bigger models just detuned. And the CX engine is a smaller completely different engine and they both have the same horsepower. Guy on the video said they sell the CK2620 the most.
    Edit: Boring video but a nice comparison
    https://youtu.be/QRGHIRwdoVg?si=qTDlJN8mj8RLEvE7
  15. Mar 26, 2024 at 6:28 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'd go with the CX2510. The CX line is not a beefed up lawn mower and nothing says you can't trade up later when your bank account is bigger. Get a good counter weight box and fill the tires, get some pallet forks and you'll be able to lift plenty. If you look back a couple pages at @Kbar's post moving those big tree trunks around with a JD 2025 that is smaller and has less lift capacity than the Kioti CS line. The CX2510 will help you get the work you need done now, without breaking the bank today. The CX tractor will also put the 25hp to better work than it would on the CK. If you need more power you can probably adjust it up a bit more similar to the CK. A comparison of the three Kioti models the CX is not that far off from the CK, but it would be much easier on your wallet right now. That's my .02¢ worth of advice.
  16. Mar 26, 2024 at 6:33 PM
    w.adventures
    Nowheresville, SC
    The CX really would be the perfect size for day to day work. And that deal you posted from LSE was a really good deal at $250 a month
  17. Mar 26, 2024 at 7:08 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Nope there isnt! Long as you can afford it that is
  18. Mar 26, 2024 at 7:14 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    That's a cool comparison video. The CX has a lot of nice upgrades, to get those on the CK series you have to get the CK2620SE model. That would add about 2+K to the price of the CK. I know you'd like a CK series, heck I'd like a DK series, but cost has to be considered. So I stick with my recommendation for the CX2510. If you can get your local dealer to match the price from LSE, I'd buy it locally. If not, call Mike and see what delivery would cost, or if you have a trailer come and get it.
    Edit: For me money is certainly a serious consideration, I posted what I paid for my tractor the other day. At the time I could easily manage the payment, but I was bringing home 30K more a year than I am now. If I were in the market for new tactor today, I'd be buying the CX over the CK because I just don't have as much disposable income to swing another 10k when I think the CX would also get the job done.
  19. Mar 27, 2024 at 5:23 AM
    sdk1968
    03 Taco TRD
    ^^^^^^^^ This is very good.
    Like KR...... When I bought my Kioti was still working & had double my current income. So the $800 more I spent on the CK 4010 vs a 2610 wasn't a big deal. Now days? Maybe would look at it harder.
    Then again? Look at your work load. I did a LOT of things with a B7200 Kubota & a 2601 that were WAY WAY out of the range for those little tractors. They did it.... But it wasn't really what they were made for.
    Same thing on the little tractors with the lightweight frames: They can do way more than what's good for them.
    Going the opposite way: the DK series is just too big/heavy for my yard & most of the things I do.
    The CK series is too heavy with the counterweight a lot of the times as well.....
    As my neighbor points out to me all the time (he has 5 tractors): a small tractor is good for most things, then you ad a big tractor for everything else. :)
    Would love to have a Kubota 2920 for day to day stuff & then have this CK4010 for bulk/heavy jobs.
    Toys toys toys. Never enough.
  20. Mar 27, 2024 at 9:07 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Final punch list time for the generator. Decided to replace the molded lead clamps. I've had trouble in the past with them corroding internally.
    AP1GczOBqRtLJWgYsS0D2XTV4U_HWLE3rY5LAoS-_89f4d3ceead3c436ad59b5772faa26e0c53deeb9.jpg
    Installing cover hinges.
    AP1GczP5adUYHB24sTxIYeoMeqezhaBv6T2LhfLi_5da17c6e5b34d8503b50713b20f33838f0a14b21.jpg
    AP1GczMMKX9T6rvZMX45toysJeNJtU8FtxWAhvHB_843b37c75bb0e7f07a2489cb34a668c035e9846f.jpg
    Cover installed and test turned over the engine. I need to cart the whole thing to the base and connect the gas so I can properly test run it.
    AP1GczMBNOYDIAB6Hmv6s6qIiezyTEFMCdtnCLBl_4c6d085be9cb67be9d73cea7fc59839c447b25d8.jpg
    To be continued...
    Delta09, wdb, RustyGreen and 5 others like this.
