Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. Mar 30, 2024 at 6:23 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Gonna hit ya with a couple things....
    42" forks are a really good option for most people. 36" are too short if you have a mid/large tractor cause you cant see them well from the seat. 42's you can see.
    As TD mentioned the only drawback to 42's is that a full size pallet is 48" & this means you miss the back board of the pallet & have no stick out.
    Most people aren't doing much pallet work. EVERYTHING at my place is on pallets as my back is crap now days. stumpgrinder= pallet, snow blade= pallet, crusher=pallet, heavy steel=pallets.. my ammo stacks/horde= pallets
    My neighbors wood stove pellets that I move for him? Pallets....
    So its all more about your use. For those of us with not much space who have to store on racks vertically? Pallets are the answer. 42" forks still work just fine, you just don't have any stick out.
    PS: I'm in process of switching out to all plastic pallets vs wood.
    To other stuff: did a full on mow job yesterday, trimmed, mulched. Mowed twice already, but this was the first time of doing the 5acres completely for the season. Was trying to beat the all day rains we are supposed to have for the next 4 days.
    Got up to a very clear dry sky.
    Tiedie, KRAMERICA, DES2009 and 2 others like this.
  2. Mar 30, 2024 at 6:51 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Carrier is FedEx. The latest update this morning shows all three pieces out for delivery. However two pieces went out for delivery early this morning, and show delivery between 10:00 a.m. and 2:00 p.m. The third piece (that had showed exception) went out for delivery later this morning and just shows delivery by 7:00 p.m. I'm thinking it missed the boat for the early truck and it's going to arrive on a separate delivery.
    sdk1968 and six5crèéd[OP] like this.
  3. Mar 30, 2024 at 7:09 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Naw they don't usually leave out till like 09:00 or even later. May all show up at the same time. If not Monday.
    sdk1968, six5crèéd[OP] and DES2009 like this.
  4. Mar 30, 2024 at 9:03 AM
    Tiedie
    David
    WFOY
    Heading out for weedeating, mow last yard and till garden. Maybe monday pland taters.
  5. Mar 30, 2024 at 12:35 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Everything showed up about an hour and a half ago. @Tiedie was correct... all on the same truck. Haven't tried picking up stuff yet.. had to go look at a new dining room table, chairs, and side piece. Now TCU Baseball is on TV. Maybe in a few hours . . .
  6. Mar 30, 2024 at 12:40 PM
    Tiedie
    David
    WFOY
    Well thanks. For 18 years I was the LTL driver with a 48' trailer tagging along, I would see stuff like that all the time especially if it gets put on a different trailer because it got left behind by accident.
    Good luck putting it together.
  7. Mar 30, 2024 at 12:51 PM
    Tiedie
    David
    WFOY
    Well got the last little bit of weed eating done and last yard mowed. Tilled the garden ready for taters to be set. Sitting on the porch having a cold beverage 17118282411872096073909644189770.jpg
    Delta09, koditten, 308savage and 4 others like this.
  8. Mar 30, 2024 at 1:56 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    The thankless job of creeping ivy murdering on my South property
    40” fir
    upload_2024-3-30_13-52-42.jpgAnd the biggun
    upload_2024-3-30_13-53-37.jpgIt’s I figure 72”
    upload_2024-3-30_13-54-29.jpgupload_2024-3-30_13-54-49.jpgHad to bush wack through the blackberries and cut 2 th 4’ of leaders to starve them and they’ll dry up come summer. Then I’ll yank them down as much as I can with the choker and tractor
  9. Mar 30, 2024 at 5:07 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Did you jinx me????
    Not sure if I'm doing something wrong, or if the pieces just don't fit together. The orange backplate says USA, the forks don't. Maybe they sent me chopsticks.. I mean Chinese forks?
    Left side
    Right side
    six5crèéd[OP], sdk1968 and Clark27 like this.
  10. Mar 30, 2024 at 5:13 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I remember a very specific order. I believe the bottom had to go in first and the top slipped into place after. Has to do with the lever on the top too. Let me see if I can dig up some info. I struggled a bit when I get mine
  11. Mar 30, 2024 at 5:20 PM
    Clark27
    Springfield, MA
    2015 Lexus GX460
    Titan says in the manual “No assembly required. Ships pre-assembled” :rolleyes:
  12. Mar 30, 2024 at 5:21 PM
    Kbar
    Western WA
    22 OR
    There should be a gap in the bottom of the frame for the bottom hook to enter and slide outwards in place. Rinse and repeat for the other fork
  13. Mar 30, 2024 at 5:21 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    There is a spot in the middle of the rack at the bottom that is recessed to allow the bottom of the forks to slip into place under the 2" receiver. Then slide them back to the outside for use.
  14. Mar 30, 2024 at 5:24 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Thanks. I downloaded the Titan "Operators Manual" for these yesterday. Doesn't say a word about how to assemble. I put the top on first, then tilted the backplate to try ti get the bottom in. Trying to avoid picking anything up manually. Had double hernia surgery 7 years ago, and busted something loose again a month after we moved to the country. :annoyed:
    six5crèéd[OP] and sdk1968 like this.
  15. Mar 30, 2024 at 5:27 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    @Kbar and @KRAMERICA .... Thanks! It would be soooooo much easier if their stinkin' "Manual" would tell you these things!!! :mad:
  16. Mar 30, 2024 at 5:48 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Stupid me :facepalm:
    I had taken one more picture earlier that I neglected to post. It clearly shows the gap that you guys described. Tomorrow morning I'll see if I can get the forks installed before the Easter Bunny takes over. :)
  17. Mar 30, 2024 at 6:50 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    So I have had a big pothole in the driveway near the house, been there for years but it recently started growing rapidly. I decided to use the box blade to rip up the gravel and redrag the 200 yard section of the driveway closest to the house. The gravel was a bit thinner the I expected it to be and I over did it a wee bit. I tore up to much of the gravel (the gravel layer was really thin), that I dug into the dirt under it. There doesn't appear to be much if any base rock underneath, it rained right after I dragged then that area turned to a mud pie. Unfortunately I didn't take a before I started pic, but I've taken some of my attempts to repair the extra damage I caused.
    I cleaned up and removed the mud after most of it dried. Unfortunately my turf roller hadn't been very effective against the mud.IMG_4787.jpg
    I ordered a load of Surge from the quarry for $480 :spending:to create a new base in the new expanded mud pit. With a new drain pipe to hopefully :fingerscrossed: let the water drain better in the future.
    I also rented a roller for the weekend, :spending: add another $370.:eek:
    Using my awesome tractor:D, I spread the big rock into a good base and used the roller to pound the rocks into a hard pack.
    Now the low spot is packed into a nice solid base, with a drain pipe in the lowest spot.
    I've got an order into the quarry for a load of Pug for Monday morning:spending:. Hopefully, it will arrive before they come to pickup the roller. The roller will do a much better job packing the Pug than I can do with my tractor and roller.:fingerscrossed: This has turned into a very expensive pothole repair.:annoyed: If I'm lucky I won't ever have to do it again.:pray:
  18. Mar 30, 2024 at 6:52 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    if I remember right, it is towards you. If you bring it around the loop the other way there’s only one way to wrap it where it actually catches and cinches down if that makes sense.
  19. Mar 30, 2024 at 6:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    What is " pug"?
  20. Mar 30, 2024 at 6:55 PM
    koditten
    Kirk
    Central Michigan
    I think you quoted the wrong post. I understood because I remember the context. Or I'm just wrong, like normal
    Edit: yeah I'm wrong.
    At least I'm consistent.
