Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Apr 2, 2024 at 4:55 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Good job young man.
  2. Apr 2, 2024 at 5:24 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i like how my girl just says ok babe. it could mean youre a dumbass or i love it. so i gets the pass. getting the cattle panel on the sides of the barn now for the horse i pick up in 3 weeks. ok babe.
  3. Apr 2, 2024 at 5:27 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    six5crèéd[OP] and sdk1968 like this.
  4. Apr 2, 2024 at 5:28 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  5. Apr 2, 2024 at 5:57 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    hey man.... dont be anything but positive on the B71/7200's! those are little work horse tractors. have had several & they are great little machines that just last forever.
    not everyone has the use for a bigger machine. got my eye on a B8200 across the field from me right now.
  6. Apr 2, 2024 at 6:18 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    sdk1968, six5crèéd[OP] and koditten like this.
  7. Apr 2, 2024 at 6:36 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Looks like the Reserve wasn't met, so the seller isn't required to let it go for that. I personally hate when auction put a reserve on whatever is being sold. If a seller has a min sale price they should just start the bidding at that min.
  8. Apr 2, 2024 at 6:45 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Bloody hate reserves at auctions, makes me so mad.
  9. Apr 2, 2024 at 6:47 PM
    w.adventures
    Nowheresville, SC
    Good catch!
    sdk1968 and six5crèéd[OP] like this.
  10. Apr 3, 2024 at 3:43 AM
    Tiedie
    David
    WFOY
    Don't I know it, that thing has saved my back many times:muscleflexing::headbang:. I just keep servicing it and fixing anything that is age related,or like now I blew a cylinder seal on the right lift arm. Sometimes I try to do too much weight with it.:facepalm:
    :101010::101010:
  11. Apr 3, 2024 at 4:20 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    For those of you who have used grader blades and/or box blades which do you prefer and why (or maybe both?)? It sounds like they both have their pro's and cons and I have been debating which makes more sense to look into. I have a 2wd L245 and we are prepping to break ground on 5 acres for our barndo build and am thinking of picking up one or the other in the next year for maintenance around the property once the build is complete. I live in an area that maybe sees a good snow that would require pushing 1-2 times a year on average, the rest are usually just a dusting that wouldn't require any pushing. The land is pretty flat and we are planning a gravel drive. I would mostly use it to prep for grass, keep the drive smoothed out, maybe some snow work when we do happen to get a bigger snow.
  12. Apr 3, 2024 at 4:29 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    They both have their place. A box blade is great for doing work you want more level. A rear blade that swivels/pivots/etc. is awesome for driveways/ditches so you can move gravel or dirt whichever way you want it and also better for snow. A box blade in snow just gets full and starts rolling out the top and sides. You need both :anonymous:
  13. Apr 3, 2024 at 4:29 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looking good :thumbsup:
    sdk1968 likes this.
  14. Apr 3, 2024 at 5:48 AM
    sdk1968
    03 Taco TRD
    Nothing I could ad to that answer. It's dead on.
  15. Apr 3, 2024 at 9:21 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    If you can only afford one, I'd get the box blade. It's more expensive but the box blade is more universal and will do more than the grader blade can do. Most box blades have a front and rear blade so you can push snow in reverse with a box blade if you need to, or move a box full of dirt or gravel across an area to fill in low spots. But I also agree with @six5crèéd and @sdk1968 having both would be better, especially if you don't have a front loader. Plowing snow and grading with a box blade is more difficult than with a grader blade, though neither is impossible just more work. Eventually I'll buy a grader blade when I find a good used one for a fair price. There are also land levelers and planners you can look into if you just want to make an area flat, but they wouldn't be much use moving snow.
  16. Apr 3, 2024 at 10:15 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    Neither one of those are going to do everything you mentioned. For dirt work and Seed bed prep you'll be best served by something along these lines.
  17. Apr 3, 2024 at 10:25 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    What exactly is that?
  18. Apr 3, 2024 at 10:26 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  19. Apr 3, 2024 at 10:37 AM
    SomeTacoDude
    Soil pulverizer.
    sdk1968 likes this.
  20. Apr 3, 2024 at 10:46 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I usually put stuff in the bucket or on the implement and use bungee straps to hold it down.
    I've been wanting to build something for a long time, but haven't got the materials to do it yet. I thought about buying this one from ask tractor Mike, but it's rather expensive. I put it on my Christmas list for the past few years, but I didn't get any takers.:rolleyes:
    https://asktractormike.com/product/tractor-caddy-tool-box/
    PS Mike has a lot of good videos for the novice to help with the tractor learning curve.
    https://www.youtube.com/@TractorMike/videos
