Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Apr 14, 2024 at 7:39 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    kinda feel like my poor kid self. watching all the cool kids with tractors and atvs when im without. this is a super rad thread to read by.
    308savage, sdk1968, koditten and 2 others like this.
  2. Apr 14, 2024 at 8:13 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    It's one of those things you will find more and more stuff to do with it. Or just make your life easier. You think now it's just "o all I'll use it for is moving hay". Then you get it and next thing you know you have 50 hours on it in a month lol.
    308savage, sdk1968, Kbar and 3 others like this.
  3. Apr 14, 2024 at 8:30 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    like buying an atv and trailer. use it more that planned. glad i have it.
  4. Apr 14, 2024 at 8:40 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    And best part with the neighbors having them already....just borrow their implements!
    As for trailers...I lucked out on that. Wife's coworker has a trailer we can use whenever. We borrowed it once for a cross country trip and I fixed it up a bit (new bearings and new lights) and he was so happy that he just lets us use it whenever we want.
    308savage, sdk1968, Tiedie and 3 others like this.
  5. Apr 14, 2024 at 8:53 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Mine has acres of grass to choose from. She goes wherever the urge takes her. Sometimes it is two feet off the front steps others it is in weeds next to the fence. Always gotta watch your step. :poking:
  6. Apr 15, 2024 at 4:48 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    My dogs like to crap under the bird feeders to ward off the squirrels. They hate squirrels
  7. Apr 15, 2024 at 4:57 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Today is cross thread day. Got a seatbelt ordered for the B7100 yesterday. Measured 60" but went with the 72" one in case I get fatter:eek:.
    Cross thread part:
    I have a old 55 gallon drum and I'm going to cut the top off, and the bottom and use it to set on top and old stump to burn it out.
    :nuclear:
    308savage, sdk1968, KRAMERICA and 3 others like this.
  8. Apr 15, 2024 at 5:01 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Finally finishing the refresh on the new to me L245. After changing out all the fluids and filters I started on the rest. Upgraded the headlight bulbs to LED bulbs, changed out the rear light housing that only threw light in a weird angled line to an LED pod I had laying around. Then started on rebuilding the steering. All the tie rod ends were cooked, boots were rotted away no grease in any of them, front tires death wobbled bad while speeds were faster in high gears 3 and 4. Drag link was easy, two new tie rod ends and some grease. Knuckle to knuckle front tie rod assembly I was quoted at $300 to replace brand new since they don't make the extendable tie rod for the passenger side. Its basically a solid rod with a tie rod end on it. So I decided to make my own. 5/8" rod, Piece of 7/8" bushing steel drilled out, LH tapped on one end, cross drilled for plug welds. Now I can change out the tie rod end in the future with another LH threaded tie rod end and not have to replace the entire piece. Cost me $100 to make including the tie rod end. throwing some paint on today and will slap it back together later this week.
    Only thing left to do now is change out the dry rotted front tires for the new ones sitting on the garage floor but since the tubes are holding air fine I may wait till next fall to do those.
    20240324_105008 - Copy.jpg 20240413_144931 - Copy.jpg 20240413_150033 - Copy.jpg 20240413_151012 - Copy.jpg
    Delta09, ACEkraut, Toyko Joe and 7 others like this.
  9. Apr 15, 2024 at 5:04 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    :101010:That tie rod should have been like that from the factory :thumbsup:
  10. Apr 15, 2024 at 5:08 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    100%. All 3 of the others are threaded, why they didn't thread this one as well is beyond me.
  11. Apr 15, 2024 at 7:15 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    I don’t have a green thumb and this is literally the first time I have ever started a yard. This is what the yard looked like in the beginning.
  12. Apr 15, 2024 at 7:48 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    That completely changes the look of your place! :thumbsup::cheers:
  13. Apr 15, 2024 at 9:07 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Feel ya there..... Tractor & mini truck are things I could never be without now on a mini farm... Will never own a wheel barrel again.
    That's really impressive with your grass growing. It's just near impossible for someone like me to be successful at grass. Bad soil, don't water enough, don't pay enough attention to it... Blah blah.
    Good results for you though!
    Headed out to do some tractor time right now!
  14. Apr 15, 2024 at 4:17 PM
    Tiedie
    David
    WFOY
    What's a wheel barrel?
  15. Apr 15, 2024 at 5:01 PM
    Tiedie
    David
    WFOY
    Ok some of my day didn't go as planned. Was removing the not so engineered remotes got the parts, 1 was the wrong part but I got it anyway.:eek: back to slowes I go. Ok onto the fire extinguisher thingy. We have 5 and it's time for the refresh. Driving by on my way to home Depot wasting time I dropped the Tacoma fire extinguisher off. Said it will be ready after noon tomorrow :thumbsup:. Then I'll take 2 more in and so on. The plan is to put 1 on the tractor. And that 55 gallon drum I spoke about, well it has 2-3 inches of dried lacquer in the bottom :rofl::rofl::rofl:. Got the top off that's when I discovered the lacquer :rolleyes:. Flipped it over but batteries were of no help today :ballchain: poor planing on my end. But alas I did get the bottom 3/4 the way cut. :thumbsup:
    Oh yeah I forgot I did get the yard mowed by the work shop. All this and had 2 Dr appointment today. Whew no wonder I tard. @RustyGreen ... See how I did that :rofl::rofl::hattip:
  16. Apr 15, 2024 at 8:16 PM
    w.adventures
    Nowheresville, SC
    Alright trailer people. I have a rusty frame on my trailer. What’s the best paint to restore it?
    Cant afford steel-it. Is rustoleum 2-1 reform and seal any good?
    sdk1968 and six5crèéd[OP] like this.
  17. Apr 16, 2024 at 3:51 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I haven't heard anything about that product, but I do hear people have good success with Eastwood's Rust Encapsulator. You do have to top coat it as well.
    Body guys don't seem to like POR15, can't remember why. My dad (retired body/paint guy) always put an epoxy top coating on frames over the years.
  18. Apr 16, 2024 at 4:37 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I've always tried to wire brush a frame the best I can then paint it, I've never used what you shared but I don't see why it wouldn't work.
    KRAMERICA and sdk1968 like this.
  19. Apr 16, 2024 at 5:03 AM
    Tiedie
    David
    WFOY
    @w.adventures
    I used corroseal on my bridge I beams. It goes on white and turns black like new steal then paint. Not sure I would want to put rubber on a frame look at what we use on our 2nd Gen frames.
  20. Apr 16, 2024 at 5:06 AM
    Tiedie
    David
    WFOY
    Just started thinking about how they say don't put rubber on frames because it traps moisture in.
