Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Apr 16, 2024 at 5:24 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Ha ha... Laugh at the hillbilly....
    It's something I no longer have or have use for. :)
  2. Apr 16, 2024 at 5:32 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Not my fault I live in the Appalachian mountains. Wait yes it is :D.
    I know what it is it's that bucket thing on front of the tractor right? Or the cart behind it.
    EDIT: I meant to say buggy.
  3. Apr 16, 2024 at 5:33 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Oh now you're just rubbing it in! :rofl:
  4. Apr 16, 2024 at 7:49 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    House siding wash update:
    Used 30 second cleaner from HD. https://30secondscleaners.com/outdoor-cleaner
    Results are excellent. Will see about next year, but it took about 1 1/2 gallons total for about $30 or so. Beats dragging around pressure washer.
    wdb, sdk1968, KRAMERICA and 4 others like this.
  5. Apr 16, 2024 at 7:52 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I need to do our entire house, we moved last August and have vinyl siding now. Thanks for sharing :thumbsup:
  6. Apr 16, 2024 at 8:02 AM
    Lt. Dangle
    Ohio
    Works well,goes through it fast though. I had no issues reaching second story with 100' of hose. Spigot on that side of house needs repaired lol.
  7. Apr 16, 2024 at 8:10 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Anyone interested in buying a JD X500 with 48" mower?
    2011, kawasaki motor, 273 hrs on it.
    I moved my led work lights over to newer mower but this one still has brackets on fenders, switch and wiring in place, and rear lights that shine down behind tires still there too.
    My newer mower is bigger so I still like this x500 for being easy to get around flower beds and such but i also don't really "need" 2 mowers.
    sdk1968, koditten and six5crèéd[OP] like this.
  8. Apr 16, 2024 at 3:02 PM
    sdk1968
    03 Taco TRD
    You know I'm in the Appalachian mountains with you ... Right?
    308savage and six5crèéd[OP] like this.
  9. Apr 16, 2024 at 4:44 PM
    Tiedie
    David
    WFOY
    Yep messing with you on that. Thought you might get a little kick out of it.
  10. Apr 16, 2024 at 6:02 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Asked over in the Milwaukee thread but figured you all might have used these.
    Anyone here uses a recip saw as a substitute for light chainsaw work? Ive always been partial to Diablo blades regardless of type and have happily used Diablo demo demon carbide tooth pruning blade but I noticed that Milwaukee now has a similar AX carbide tooth pruning blade. Is the Diablo or Milwaukee drastically better then the other? Price is almost the same and the Milwaukee looks like a rebranded Diablo.
  11. Apr 16, 2024 at 6:39 PM
    Tiedie
    David
    WFOY
    Your a little farther north then me though.
  12. Apr 16, 2024 at 7:04 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    So ugh. You want to hop on over there and take some pictures? :thumbsup:
  13. Apr 16, 2024 at 8:34 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I got my soil test back today. Looks like I need to add a little fertilizer and some lime.
  14. Apr 17, 2024 at 4:33 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I wouldn't think either one would be any better than the other, comes down to personal preference :thumbsup:
    sdk1968 and 308savage like this.
  15. Apr 17, 2024 at 4:46 AM
    Tiedie
    David
    WFOY
    Ok that's not too bad then. I would think that you have experience with both of those. Lime you can get it dropped in bulk ground up/ powder by the ton or just buy bags. Fertilizer just bags. But I'm sure you know all this stuff.
  16. Apr 17, 2024 at 5:27 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    You might just add lime, didn’t you till it under? You’d be surprised how adding lime and the decomposing of the existing will give you available nutrients. If I were you I’d do an experiment and fertilize half the garden but lime the whole garden and see what happens.
  17. Apr 17, 2024 at 6:53 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i do it all the time. diablo makes a great blade. some stuff i do is pretty sketchy so i mainly use the stihl for bucking firewood.
    wilcam47, sdk1968 and six5crèéd[OP] like this.
  18. Apr 17, 2024 at 6:56 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I know how to add fertilizer and till the soil, but this is my first attempt at a serious garden of my own. My previous gardening experience was with my dad’s garden. At the time I tended to view that experience as a punishment. Usually because I was doing something I should not have been doing, and Papa would send me to the garden to pull weeds. So instead of having a lesson in growing things I learned to hate gardens. Beyond a few tomato plants in recent years, I have never grown anything in the dirt.
    wilcam47, sdk1968, 308savage and 3 others like this.
  19. Apr 17, 2024 at 7:14 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My dad would make my brother and I pick up rocks for hours, he would drive the tractor through the field and point them out to us. I hated it. Now, our garden has rocks in it and I try to get them up. I ask the kids to go get some out yesterday but I try to make their effort worth a reward. Cole gets a little tractor time now :D
    I remember when I was about 14 I thought I was doing a good job for my dad while he was at the fire station one day. I got his tractor and disc and disc a spot he had previously disc. I thought it had weeds coming up in it, turns out he planted it in winter peas and I murdered them.
  20. Apr 17, 2024 at 7:15 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I’ll talk with my Aunt, I’m doing most of this under her direction. But I like the idea. I’m also mixing in the chicken coop waste since the fall. I’m definitely going to be doing another soil test this coming fall. To compare the results and prep for the next season better. For $30 I think they are a good investment.
