Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Apr 26, 2024 at 2:05 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    100% honset OP here..... not htat you asked for it.
    YES you should buy a good set of tires for that persons trailer just as a thank you to them for loaning it so often.
    Get a good set with a spare!
  2. Apr 26, 2024 at 2:58 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Tractor question....
    Since I only drive the tractor on grass, dirt, or the rock driveway.. is there any reason not to just leave it in 4WD all the time? I noticed about 2 weeks ago that it was apparently in 4WD mode when it was delivered and I had been unknowingly using it that way for the first several weeks I had it. I changed it to 2WD, but I've had several times that I've had a rear wheel slip since making that change. Can I just put it back in 4WD and just leave it unless I have to go out on the road?
    six5crèéd[OP], Tiedie and sdk1968 like this.
  3. Apr 26, 2024 at 3:09 PM
    sdk1968
    03 Taco TRD
    Yes you can. Mine has never been out of 4wd in 6yrs.... Hasn't hurt a thing & its always "in" when in need it.
    "They say" you can wear out front end parts & joints faster.... But for me the whole point of having a 4wd tractor is so that its there when I need it without having to switch anything.
    A lot of times you wont get into "trouble" to start with if it was already in 4wd.
    My mini truck stay in 4wd as well. Only time it ever comes out is if I run down the blacktop to the store.
    six5crèéd[OP], Tiedie and DES2009 like this.
  4. Apr 26, 2024 at 3:46 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    I just flip back and forth as needed with a small tractor I can feel it binding in the front sometimes and its easier for me to steer no power steering.
    Don't worry about it.
  5. Apr 26, 2024 at 3:58 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yeah, you are not gonna want 4wd when trying to back up a hay wagon into a tight spot.
  6. Apr 26, 2024 at 4:06 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Wasnt even a question of getting a good set. He will probably want to go in 50/50 on them anyways not that I expect him to. Honestly think he is just glad it is getting used and not just sitting. Before we started borrowing it he hadnt used it in like 3 years at least. He has a bigger goose neck they use a lot more
  7. Apr 27, 2024 at 4:45 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    I know three different people who have the ego mowers for personal use and they really like them, they definatly dont have the power of a larger gas engine but two of them cut about 2-3 inches off the top when they mow.
    six5crèéd[OP] and sdk1968 like this.
  8. Apr 27, 2024 at 5:49 AM
    sdk1968
    03 Taco TRD
    Wife wants an battery mower for her Catio area.... She cant pull start the push mower & there's not enough room to get the Zero in there.
    But dang the pushmower we have is almost 12yrs old & still looks new, so it might be a while, which means I get to keep starting it for her & then she says : well since you started it, you might as well just mow it for me.
    six5crèéd[OP] and Toyko Joe like this.
  9. Apr 27, 2024 at 6:07 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Maybe see if something here fits?
    https://www.briggsstrattonstore.com/briggs-and-stratton-electric-starter-kits/
  10. Apr 27, 2024 at 8:21 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    That was where my biggest issue with it was though. It was 2-3" taller than the highest setting and it...sucked to be honest. But the grass was also a bit wet. But I was lucky to get 15 minutes of battery run time which meant it took basically all day to mow it between the recharging of batteries. Dont really have that concern with maintaining it now though. And of course depends on yard size too....i hate mowing grass so spending an 1-2 hours a week doing it isnt fun to me lol
    six5crèéd[OP], sdk1968 and koditten like this.
  11. Apr 27, 2024 at 10:42 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I don't know if it's a reason not to, but you'll get a bit of a dig from the front tires when turning sharply. When doing that on the lawn or the driveway, it will tear things up a bit. I personally switch mine between 2wd and 4wd as needed. If I get a little wheel spin while in 2wd, I'll stomp on the RW locking diff. If I get a lot of wheel spin I put it back in 4wd.
  12. Apr 27, 2024 at 12:08 PM
    joeyv141
    Virginia
    Out of curiosity what blades are you running? Are they sharp? Yeah evening cutting 3 inches of wet grass will bog gown my gas toro timemaster.
  13. Apr 27, 2024 at 1:07 PM
    Tiedie
    David
    WFOY
    Weedeated around the house and mowed 3 yards today. After walking Mal 4 miles now sitting in the shade in the front yard.
  14. Apr 27, 2024 at 1:09 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Guess you’re not sharing with the WagWag. :cheers:
  15. Apr 27, 2024 at 1:12 PM
    Tiedie
    David
    WFOY
    Nope! That dog is spoiled rotten
  16. Apr 27, 2024 at 4:54 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    The ones that came with it. Sharpened them up the little they needed. It cut just fine just would big down under any sort of load. Now that everything is cut and dried out a bit it cuts great
    But that's the thing I miss with gas...it might bog down but you just kept going. Grew up mowing a almost always wet field and the yeah, sometimes had to slow down but never had to stop
    I'm not knocking the electric by any means. More just point out some of its faults. It works great for maintaining the yard now.
  17. Apr 27, 2024 at 5:20 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I have a Makita 18 volt string trimmer, the smallest model.
    Maintaining is where it shines, for heavy clean up the gas trimmer is far faster however for the weekly trim the electric works great and is very convenient.
  18. Apr 28, 2024 at 8:50 AM
    koditten
    Kirk
    Central Michigan
    Customer contracted me to install lumber in the middle of his open center car hauler.
    Of course the cross members were too high and had to be lowered 1.5". It needed a couple more cross members as well.
    Still need to screw it down, but the bulk of the work is over.
    I'm not sure what cars will fit on a 12' trailer. I know it would be awesome for a side by side utility vehicle.
  19. Apr 28, 2024 at 9:39 AM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    We, in Missouri, just this last fall, now have 3 of the "ying-ling" beers distributed in our state. It has become my favorite -especially the lager. Hoping sometime we will be able to get all of their products in our area
  20. Apr 28, 2024 at 9:59 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Yuengling lager is the best beer out there IMO. It’s to bad not everyone can get it.
