Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Apr 30, 2024 at 7:33 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I've had the basket for about 2 weeks. Finally got some suitable U-bolts and got it mounted to the tractor this morning. Still need to figure a good way to remount the triangular reflector....
    20240430_091050.jpg 20240430_091108.jpg 20240430_091118.jpg 20240430_091128.jpg
  2. Apr 30, 2024 at 7:37 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Looks great :101010:
  3. Apr 30, 2024 at 9:12 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Might have to add to the thread title.
    He gonna pay me more to fix this than it's worth.
    Still thinking on how I want to tackle it.
  4. Apr 30, 2024 at 9:18 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    yeah man i like that basket a lot! looks real good!
  5. Apr 30, 2024 at 10:42 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I'd try moving the reflector mount to the middle of the baskets.
  6. Apr 30, 2024 at 1:05 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  7. Apr 30, 2024 at 2:20 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    IDK, I guess it depends on what you use the tractor for. When I had mine I was often installing and removing implements on the 3 pt hitch. I can see a situation where parts of my hair and scalp could have been forcible removed from my body and left on that basket, causing me to retaliate.
  8. Apr 30, 2024 at 2:37 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I understand. But currently I don't have anything that attaches to the rear. I did go back and add some reflective tape to it though, to keep from walking into it. Walking from bright sunlight to where the tractor is under the overhang I quickly learned that the basket could be hard to see. :eek:
  9. Apr 30, 2024 at 2:41 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Just go buy some d.o.t. tape or just get a SMV sign. (Slow moving vehicle).
  10. Apr 30, 2024 at 3:38 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That was a boat, right?
    What did they do, drag it through a quarry?
  11. Apr 30, 2024 at 3:41 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That D.O.T. tape (Conspicuity tape) is surprisingly expensive. :eek:
  12. Apr 30, 2024 at 4:14 PM
    koditten
    Kirk
    Central Michigan
    Close.
    Night fishing on the Au sable. Too many roadie's. Boat slid out of the back of the truck. Drug it for a 100 yards hanging out the back.
    At least he was honest.
  13. Apr 30, 2024 at 4:26 PM
    SomeTacoDude
    I'm thinking more getting involved in attaching an implement, raising my head up in frustration, and BAM.
    sdk1968 and six5crèéd[OP] like this.
  14. Apr 30, 2024 at 4:38 PM
    koditten
    Kirk
    Central Michigan
    Don't over think it.
    Zip tie a pool noodle to it to protect yer noodle.
  15. Apr 30, 2024 at 4:39 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I get what you're saying. It's something I thought about, but since I don't actually have any implements for back there I don't know if the basket sticks back far enough (and low enough) to be a hazard.
    sdk1968, six5crèéd[OP] and Tiedie like this.
  16. Apr 30, 2024 at 5:11 PM
    Tiedie
    David
    WFOY
    On the subject of boats going on 1 in the morning.
  17. Apr 30, 2024 at 5:22 PM
    SomeTacoDude
    Believe me it sticks back there enough to be a hazard, to me and the way I used my tractor. But maybe not to you. And that's cool. To each there own.
  18. Apr 30, 2024 at 6:37 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  19. May 1, 2024 at 5:21 AM
    sdk1968
    03 Taco TRD
    Backing up to your basket thing.....
    It looks like if you had the top link on it would be in the way of fitting in the lock. But you can always move the catch point on that.
    It doesn't look like its in the way for most things you would have back there, hog, box blade, blade, plow, tiller.
    It IS in the way though if you reach under to hook up the PTO. You would need to be aware before raising your head up or you would hit it for sure in the situation.
    Still its a nice looking basket & we all use our tractors for different things.
    For me my tractor does everything at any given time.... along the lines with KR in usage,
    but for other people they are just a FEL machine or a mower.
    Making the tractor work for YOU is the most important part.
    six5crèéd[OP], Clark27 and DES2009 like this.
  20. May 1, 2024 at 6:15 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I had the same thought process. I like the look and it’s a good amount of space there but I think it would be difficult for me when using the rear PTO and attachments. I’m struggling to find a good solution otherwise though to be fair.
