Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. May 11, 2024 at 3:27 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  2. May 11, 2024 at 3:42 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    You can see right past it the road is washing out. That might help, but the steeper the grade the shorter the intervals will need to be. In a heavy rain runoff will go right over that.
  3. May 11, 2024 at 4:42 PM
    Tiedie
    David
    WFOY
    I know but we only had 2" of rain and this hasn't been touched in quit awhile. And there is 2 more up hill. About 100' apart as suggested. Good thing this is not my responsibility. And as you see below it's not washed too bad.
  4. May 11, 2024 at 4:47 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  5. May 11, 2024 at 6:04 PM
    SomeTacoDude
    Yes I can see how it works. It forces the water up an over it. Just saying the steeper the grade the more often they will have to be installed.
    six5crèéd[OP] and sdk1968 like this.
  6. May 11, 2024 at 6:44 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Swapped blades and sharpened the old one
    Kbar, Drainbung, bkhlrTaco's and 5 others like this.
  7. May 11, 2024 at 6:47 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Me, too. Customer wanted to try out some Gator shredders.PXL_20240511_202227541.jpg
    Kbar, KRAMERICA, Drainbung and 6 others like this.
  8. May 11, 2024 at 8:50 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    that geo- filter grate stuff ive seen in rolls. it was used in gravel paths on a slope and allows drainage and gravel to stay put. i think its slick. get a driveway just high enough and cover that with a layer of gravel. id think it would be the best one can do.
    KRAMERICA, Drainbung, sdk1968 and 3 others like this.
  9. May 12, 2024 at 4:30 AM
    Tiedie
    David
    WFOY
    :popcorn:
    sdk1968 and six5crèéd[OP] like this.
  10. May 12, 2024 at 4:41 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Love my gator mulcher blades, only blades I use now.
  11. May 12, 2024 at 4:50 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    How do they work with just regular grass mowing? I know they work good with leaves.
    Drainbung and sdk1968 like this.
  12. May 12, 2024 at 5:02 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    My neighbor gave me his mulching guard for a 42" JD. Installs inside the front of the deck. (like this)Screenshot_20240512_065823_Amazon Shopping.jpg
    Night and Day difference over the regular mulching cover.
    Leaves hardly anything behind!
  13. May 12, 2024 at 5:57 AM
    koditten
    Kirk
    Central Michigan
    They work fine on regular grass, but they do require a mower with HP to spare. They take more power to do the extra chopping.
  14. May 12, 2024 at 6:06 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Speaking of mowers....
    I'm looking for tractor lug (R1) tires for my ZXT & cant find them in the right size...
    Need 26x14x12 anybody see them?
    Everybody has 26x12x12.... Can't find any 14's
    six5crèéd[OP] likes this.
  15. May 12, 2024 at 7:26 AM
    joeyv141
    Virginia
    They do great with regular grass, even grass about 6 inches tall just requires one pass, slower speed using walk behind in this case. Large amounts of leaves like magnolia leaves do take two passes to cut up small enough.
    I have the G3 on my self propelled and G5 on my zero turn.
  16. May 12, 2024 at 10:09 AM
    sdk1968
    03 Taco TRD
    Got the front done!
    Still gotta do both ends & get dirt against it, but there is progress.
    wdb, Delta09, RustyGreen and 8 others like this.
  17. May 12, 2024 at 11:32 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    On the blade topic.
    I like using the 3-in-1 blades.
    They do pretty good all around when kept sharp.
  18. May 12, 2024 at 12:35 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    can you sharpen blades with an angle grinder? im not really picky about how well it cuts but i figure a vast improvement over unsharpened 3 yr old stock units. its a pos walk behind.
  19. May 12, 2024 at 12:37 PM
    Tiedie
    David
    WFOY
    Yeah why not.
  20. May 12, 2024 at 12:40 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    With the curve in the 3-in-1, it's actually easier using the angle than the bench grinder.
