Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.5%
  2. After
    57.6%
  3. Neither
    12.1%
  4. I weed whack while someone else mows
    6.1%
Multiple votes are allowed.
  1. Jun 5, 2024 at 6:15 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    All my commercial Hustlers have had grease fittings below the deck in the spindle. YUP have had them break the nub off before too. And man the Hustlers hold a lot of grease in those hubs.
  2. Jun 5, 2024 at 9:25 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Haven't been to my cabin to mow yet this year. Might do it this weekend as the grass must be 3ft high by now lol.
    Might not go too because, well, lazy.
  3. Jun 6, 2024 at 9:53 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  4. Jun 7, 2024 at 9:53 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  5. Jun 8, 2024 at 1:16 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    hey fellas, i need small engine help. changed oil on chipper. ran it 2 min to warm up for fast drain. topped off tank with good eth free gas. used napa 30w and checked 5x. thing would kinda run when choked but died when turned down. plug is dry and clean. im wondering if its a carb linkage issue but manually tinkering dint work. throttle adjust doesnt operate the spring much. makes me wonder if some goofy spacer broke and fell out. any ideas? oh. air filter is in top notch shape and my atv running the same batch of gas is aces today running.
  6. Jun 8, 2024 at 3:24 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I wouldn't think changing the oil would cause an issue. But just making sure it is a 4 stroke engine?
  7. Jun 8, 2024 at 4:23 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I’d say carb needs cleaning or has water in the gas tank.
  8. Jun 8, 2024 at 5:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Was that gas from the bottom of the gas can? Those last 4" can really get you in trouble. Water sinks in liquid gas and separates quite fast. If your unit is a gravity feed with the tank above the carb, the 1st thing to get to the carb will be the water you may have just poured in the tank.
    Odly enough, ethanol gas will allow the water to mix ( missable) with the gas and still support combustion. Quite a lot of water and it will still run, but pretty crappy.
    I'm guessing if you pull the bowl and drain a half cup into a mason jar, you will see the water separate. Once flowing only gas, reassemble and fire it up.
  9. Jun 8, 2024 at 6:33 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thanks guys. fuel is not old, or bottom of tank. so it did run for a while after i got it going. im thinking some linkaged is messed up. full choke and full throttle it ran fine. what would cause that?
    btw this is a 250cc b&s 7hp. maybe 100hrs.
  10. Jun 8, 2024 at 6:38 PM
    wilcam47
    Will
    Bourbon state
    Check your fuel bowl jet. Might have had something get into it
  11. Jun 8, 2024 at 6:39 PM
    koditten
    Kirk
    Central Michigan
    Then you have a dirty carb. There are 2 circuits in a carb. The low speed circuit has very small passages that easily become partially blocked. Running with the choke on will allow it to stay idling, but it's gonna run like shit.
    You can try cleaning it, but I've never had good luck with that. I usually replace a lightly varnished carb.
    Some have tried running acetone in the gas to break down the varnish. Sea foam is mostly acetone.
  12. Jun 8, 2024 at 6:46 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    this sounds like what i guessed. ill hope to get it blasted out soon. thanks guys!
  13. Jun 9, 2024 at 1:45 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    This. You can find aftermarket carburetors on eBay for almost everything. Also, I've found shutting down infrequently used engines by using the fuel shut off is preferable to the kill switch.
  14. Jun 9, 2024 at 3:33 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    45 hours and I replaced mine... :anonymous:
  15. Jun 9, 2024 at 1:19 PM
    wilcam47
    Will
    Bourbon state
    :eek:
  16. Jun 9, 2024 at 1:21 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Fun fact, if you suck up and mow over a conveyor belt it shortens the lifespan... :anonymous:
  17. Jun 9, 2024 at 4:41 PM
    wilcam47
    Will
    Bourbon state
    I hope i dont have to change mine
  18. Jun 9, 2024 at 7:38 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im going to drain the carb bowl and assume all is well. it ran top notch before re-fuel. it has never given me grief. ill start there and go further if i must.
  19. Jun 9, 2024 at 8:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so.... changed oil in chipper and then the carb got complicated. today just changed the oil in my honda element. went back out and the windshield is cracked in half. dammit, im going to pay for this now on.
    Lt. Dangle, KRAMERICA and sdk1968 like this.
  20. Jun 9, 2024 at 8:13 PM
    koditten
    Kirk
    Central Michigan
    No " likes"!
