Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jun 9, 2024 at 8:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    what am i doing wrong? i recycle my oil like a good boy.
  2. Jun 10, 2024 at 4:28 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Bro, that bad luck is following you. Think you need to put more money in that collection plate each Sunday, or maybe sage the whole house :rofl:
  3. Jun 10, 2024 at 6:27 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    I liked this anyway... Just because life likes to kick ya in the nuts.....
    Not because you busted the windshield.
  4. Jun 10, 2024 at 6:48 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    When replacing or sharpening your blades over torquing the bolt during reassembly can cause premature failure.
  5. Jun 10, 2024 at 6:50 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Don't throw in the towel just yet! Try and try again until you get right. Besides paying other people to do your work gets rather expensive...:rolleyes:
  6. Jun 10, 2024 at 6:52 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Those things have a torque spec???o_O I've always thought Ugga Dugga was the standard...:rolleyes:
    308savage, sdk1968, wilcam47 and 6 others like this.
  7. Jun 10, 2024 at 6:54 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yeah. however in recent years my wrenching mistakes cost dearly too. im just having a laugh on my expense. i tried putting custom cams in my tacoma last year. 12k$ mistake. that was just to put the stock ones back, ruined hipo cams, and other parts. ooffff!
    sdk1968, six5crèéd[OP] and koditten like this.
  8. Jun 10, 2024 at 8:19 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Those pesky engineers always manage to throw in a torque spec. Something about bearing preload comes into play.
  9. Jun 11, 2024 at 6:24 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Getting other people to work is also a difficult task...
  10. Jun 11, 2024 at 4:37 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    You must do oil changes differently than I do lol.
    You should really stop. Your luck sounds like mine.
  11. Jun 11, 2024 at 4:45 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Finally hit over the 50 hour mark (well actually closer to 60) so need to do the "50 hour service". It doesnt call for hydraulic oil change but always hear different opinions on that....kind of like changing engine oil after 500 miles or so type thing.
    So opinions? Change the fluid or just the filters? (filters are called for)
  12. Jun 11, 2024 at 5:52 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I would change the filters and the engine oil.
    six5crèéd[OP] and sdk1968 like this.
  13. Jun 11, 2024 at 6:01 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Filters and oil are included. More just the hydraulic fluid
  14. Jun 11, 2024 at 6:07 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I did not change my hydraulic oil.
  15. Jun 11, 2024 at 6:24 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You drop the hydro filter, just about all the oil in the resivior fallows it. Better have hydro oil on hand.
  16. Jun 11, 2024 at 6:30 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    With the Kioti he shouldn't loose more than a quart or two. He shouldn't need to buy the 5 gal pale quite yet.
  17. Jun 11, 2024 at 6:32 PM
    koditten
    Kirk
    Central Michigan
    I do need to ask what kind of machine we are referring to?
    Zero turn mowers, the filter comes off and mist if the oil comes too.
    So I was referring to zero turn unit, to be clear.
    Been off the site most of the day, so I'm a little behind.
  18. Jun 11, 2024 at 6:35 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    That's where I'm leaning, was more just curious. Long as it looks fine changing the filter of course
    I might have forgot to mention it's the tractor :anonymous:
  19. Jun 11, 2024 at 6:36 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'm pretty sure he has the Kioti CK2610, but I don't remember if it's the standard or HST transmission. There will be an extra filter on the later version.
    six5crèéd[OP] likes this.
  20. Jun 11, 2024 at 7:30 PM
    sdk1968
    03 Taco TRD
    KR: I did change the hydro oil & everything else at 50hrs on mine..... Since then its only had the filters changed on the hydro's @250hrs.... Did oil at 250hrs also.
    But man I'm running thru fuel filters about every 100hrs & air filters about every 50hrs .... The CEL light has come on every time.
