Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Jun 20, 2024 at 4:16 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    My B7100 is pretty easy. What I've been doing is turn off the fuel petcock and pull the filter bowl wipe out the inside of the bowl, put filter in and fill with fuel let it sit and add a little more screw on and turn on fuel. It fills up and so far I've not had to bleed air
  2. Jun 20, 2024 at 6:00 AM
    Tiedie
    David
    WFOY
    Fired up the irrigation pump looks like the hose gasket is not the problem, still spraying out :confused:. Might have to move up to the 5/8 hose and see if it gets better.
    Started a fire today
    IMG_20240620_085209556_HDR.jpg on that stubborn stump we'll see.
    KRAMERICA, sdk1968, 308savage and 3 others like this.
  3. Jun 20, 2024 at 6:13 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You should dangle some meat and smoke it up.
    Get 2 jobs done at the same time.
    I'm betting @Kilo Charlie could give you some ideas.
  4. Jun 20, 2024 at 6:17 AM
    Kilo Charlie
    Kilo Charlie Disruptor
    Iowa
    2017 Inferno Off Road
    What flavor of tree is it?
  5. Jun 20, 2024 at 6:39 AM
    Tiedie
    David
    WFOY
    Smoking Blue birds see house on power pole.:nuclear:
  6. Jun 20, 2024 at 6:40 AM
    Tiedie
    David
    WFOY
    Some sort of cherry.
    KRAMERICA, sdk1968, wilcam47 and 3 others like this.
  7. Jun 20, 2024 at 6:42 AM
    Kilo Charlie
    Iowa
  8. Jun 20, 2024 at 7:08 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    The pump looks like the inlet is about 3 times bigger than the outlet, all that pressure/volume has to go somewhere as it can't push it out the sprinkler fast enough.
  9. Jun 20, 2024 at 7:14 AM
    Kilo Charlie
    Iowa
    Agreed!
  10. Jun 20, 2024 at 7:19 AM
    Kilo Charlie
    Iowa
    With that size of pump, you should actually consider irrigation ditches instead of a sprinkler. solve all the problems with the pump and the dry dirt
  11. Jun 20, 2024 at 7:23 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Hang a pork shoulder in there;)
  12. Jun 20, 2024 at 7:27 AM
    Tiedie
    David
    WFOY
    Up until this year everything was fine for the past 20 years I think that the hose repair end is shot it's pretty loose at the connection.
    I also don't run it full blast, gonna try a replacement I have in the shop. If that doesn't work then it's time for a bigger hose, which I have everything on hand. Try what you got on hand then see what else needs to be done.
  13. Jun 20, 2024 at 7:29 AM
    Kilo Charlie
    Iowa
    You do you bro, but know there's more than one way to skin a cat. (or in this case, get the cat wet)
  14. Jun 20, 2024 at 7:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Since you have so much water coming out you could add more sprinklers. Or do what Charlie said and dam up the ends of the rows and flood it. I've seen my dad do both and both were effective :thumbsup:
  15. Jun 20, 2024 at 12:06 PM
    Tiedie
    David
    WFOY
    Been looking at another sprinkler like you said flooding would get me no help with the weeds.:rofl::rofl::rofl:. We only water when there's no rain in sight every other day.
    Thanks guys for the insight :thumbsup:.
    sdk1968, wilcam47, Drainbung and 2 others like this.
  16. Jun 20, 2024 at 5:16 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    going to sell the tacoma soon to buy an old chev and tractor. ;) may just jump. 70 chevy 4x4 4spd. like my dads;) 10k for an ok one. i guess im in!
  17. Jun 20, 2024 at 5:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    your garden area is something worth being envious of. looks great.
  18. Jun 20, 2024 at 6:15 PM
    Tiedie
    David
    WFOY
    Thanks it's got lots of weeds! We try, it's just the start of the growing season.
  19. Jun 20, 2024 at 7:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im waiting for heat for my stuff to pop. im going to get a greenhouse. clima-pod makes what seems the best. need more sun in the PNW!
    need a go fund me....
  20. Jun 20, 2024 at 8:09 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Weeds are eternal!:rolleyes:
    RustyGreen, sdk1968, wilcam47 and 4 others like this.
