Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jun 21, 2024 at 5:06 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I have had good luck with one of the Harbor Freight torches that hook up to a 20lb propane tank. Works well and lasts a surprisingly long time. And, there is the fun factor. Works really great around rocks, cracks and crevices. Not good around landscaping and plants.
    Edit: Added bonus. If don't like chemicals or applying them is tricky then this method is safe, fast and effective.
  2. Jun 21, 2024 at 7:57 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I don’t know of any thing, but there is another chainsaw thread. You can check there, there are some serious chainsaw enthusiasts over there, they might know of something.
    https://www.tacomaworld.com/threads/what-chainsaw-do-you-run.314274/
  3. Jun 21, 2024 at 7:59 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I must have weeds on steroids...ive burned them and they come back...
  4. Jun 21, 2024 at 8:00 PM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    Am looking at a 2006 Kubota B7610 with fel tomorrow; it's not exactly what I want, but anyone think it'd not be able to fart-around on a few acres; spreading gravel, hauling feed for chickens/sheep, back-drag/fill some rough spots in the land, or push around maybe 8-10ft, 12" (max) diameter logs?
  5. Jun 21, 2024 at 8:34 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    It a sub-compact model, but I think it would do all the things you mentioned. It might struggle with the logs, but with the proper techniques it can be done.
    https://www.tractordata.com/farm-tractors/001/8/6/1861-kubota-b7610.html
  6. Jun 21, 2024 at 8:36 PM
    DetroitDarin
    York County PA
    Thanks - tracking all. I won't push it too hard (thatswhatHEsaid). If logs look too stuck or big, i'll run a snatch block and winch it out of the way w/ the tacoma :)
    Thanks much!
  7. Jun 22, 2024 at 3:47 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Unless you are a chainsaw master....... There's really nothing you do to a good running sthil. If you need more power? You get a bigger saw.
    Like he said the green is called the safety chain & I throw those away. Yellow is the go to chain for most people & red is supposed to be the danger/expert level chain.
    These are a nice little machine. Good HP for the size. Will they drag a good size log? YES.
    Pushing it is a little tougher cause the machine isn't real heavy. But they are a fine little machine if you get a good price on them.
  8. Jun 22, 2024 at 4:33 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    You'll be fine as long as the price is right. I have a B7100 which is 16 HP and 13 at the PTO. Weight is about 1100#'s with the FEL and ROPS (thanks @LTdangle ). I drag the road dig, lift and plow
    @KRAMERICA is right I move a fair amount of things with the right tools and techniques.
  9. Jun 22, 2024 at 5:20 AM
    DetroitDarin
    York County PA
    Thanks Gents - an online KBB type page says they are asking about $500 over “retail value” so I have some wiggle room - it’s the first tractor I’m going to look at so want to be reasoned and not only excited to get one.
    Through this process I find it weird most shops around (and this one is 90 mins away) are barely open on the weekends. Frustrating too.
  10. Jun 22, 2024 at 9:39 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
  11. Jun 22, 2024 at 9:58 AM
    DetroitDarin
    York County PA
    Just back from viewing the tractor. Fuel gauge inop, some early dry rot on one back tire, everything else seems to work fine. Oil is dark though: likely ready for a service. Will make and out the door offer + delivery and see what he says.
  12. Jun 22, 2024 at 10:00 AM
    Tiedie
    David
    WFOY
    What does it have, front end loader or any attachments? Pictures?
  13. Jun 22, 2024 at 11:01 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I have the same exact tractor. Got it from my father in law when we bought our property. Paid him 7500 for the tractor with FEL. We never really talked about all the other attachments but it’s a far where between the two of us we own most things we could need. It’s been great for me. Moving dirt and small rock. Mowing. Snow in the winter. Of course like anything else I’ve found myself wanting a bigger tractor or more power but it’s really been great.
  14. Jun 22, 2024 at 12:15 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I wouldn’t be concerned with the oil being black, I can change it in my Ford and it’ll be black in no time. If you get it I’d change it to be safe though.
    sdk1968, Lt. Dangle, Tiedie and 2 others like this.
  15. Jun 22, 2024 at 12:20 PM
    DetroitDarin
    York County PA
    Thanks guys - what kinda expense for new hydronic lines for the loader? I saw some dry rot and cracking on one of the lines up by the controller/manifold/box.
    The asking price is about average retail, but I think I will ask for the allowance on the inop fuel gauge and a line or two.
  16. Jun 22, 2024 at 12:21 PM
    Tiedie
    David
    WFOY
    You can put fresh oil in a diesel engine and as soon as you crank it up it's dark period.
  17. Jun 22, 2024 at 12:23 PM
    Tiedie
    David
    WFOY
    4WD?
  18. Jun 22, 2024 at 12:23 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    safety suit you had!
  19. Jun 22, 2024 at 12:24 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    This is full synthetic Rotella, has 4 hours on it.
    Delta09, sdk1968, Lt. Dangle and 4 others like this.
  20. Jun 22, 2024 at 12:24 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    It all depends on size and length, they aren’t super expensive but not cheap either.
