Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    43.6%
  2. Mow and weedeat, yes
    32.7%
  3. Pants all the way for me
    23.6%
  1. Aug 14, 2020 at 3:34 PM
    #1361
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Well, we did it:
    Lots to learn. But already putting the loader to work on the landscaping duties.
  2. Aug 14, 2020 at 3:36 PM
    #1362
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Working on the Cub 3205 rear diff. Got everything cleaned up, seals in the bearing blocks, diff bolts removed, red loc-tited, and torqued to 23ft lbs. I changed the diff lock shaft seal while I was at it. Getting ready to put it all together with a new gasket and Ultra black sealer. Will let it dry till tomorrow sometime. Maybe 24hrs before I put oil in.
    It had a collapsed axle seal and i think someone beat it too hard installing it and ruined it on install. Also several long bolts in shallow holes weren't even touching the cover so the blocks were probably not seated. I welded a nut to a broken off bolt and got it out. It was bottomed in the hole hard so they just kept trying to seat it till it broke off. Whoever took this apart before was an idiot.
  3. Aug 14, 2020 at 3:37 PM
    #1363
    Steve Urquell
    Congrats man! Great looking rig. Git Sum!
    six5crèéd[OP] likes this.
  4. Aug 14, 2020 at 4:00 PM
    #1364
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That’s nice!
  5. Aug 14, 2020 at 6:44 PM
    #1365
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
  6. Aug 15, 2020 at 8:03 AM
    #1366
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Nice! If you didn’t already, I’d recommend you get the rear tires liquid ballasted. It’ll allow you to get closer to maxing out your lift capacity.
  7. Aug 15, 2020 at 8:40 AM
    #1367
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Nice mower. I looked at those a little while back but decided on a Bad Boy. I just changed the oil after the break-in period.
  8. Aug 15, 2020 at 9:35 AM
    #1368
    Steve Urquell
    Yep, gotta ballast for a loader or it'll be hunkered up like a dog trying to lift anything
  9. Aug 15, 2020 at 9:42 AM
    #1369
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    My big ass and a box blade make for good counter balance when in “loader” mode.
    One bucket load of #57 stone will let you know quick where you stand on ballast
    cosmicfires and six5crèéd[OP] like this.
  10. Aug 15, 2020 at 11:22 AM
    #1370
    Blkvoodoo
    Kevin
    Near Clayton NC
    So if you have that one machine. That you’d like to track hour usage on but it doesn’t have an actual Electrical system....$9 and comes in different colors 6CA4E2A6-3310-40DE-A8B4-6FFDD331233E.jpg
    Uses an induced current signal from spark plug when running.
    And small enough you can tuck it out of the way
    Kick ass little generator for the $$$
    and of course it starts raining in the middle of install....
    po35042 and six5crèéd[OP] like this.
  11. Aug 15, 2020 at 3:34 PM
    #1371
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Planning on it. I put washer fluid in the tires of the lawn tractor we replaced with this kioti. I think that's an option again this time, but I've talked to a local rimguard dealer, and they're willing to sell me product bulk that I can bring home and fill tires myself. Thinking I might go that route, it's not much more expensive than washer fluid that way.
  12. Aug 16, 2020 at 7:41 PM
    #1372
    Steve Urquell
    Got my 3205 rear diff back together and running. No leaks so far. Replaced all the fuel lines and the 2 fuel filters. The rear one was just a screen and was really plugged. Also drained and filled my scaled up radiator with RO water and flush.
    Gonna put my gas tank and hitchplate back on and pull my brush hog with this with all the tins off so I can check everything for leaks and let the flush circulate for 6hrs then do it again. I may paint all the sheetmetal while it's off but it is gonna be a bear. Someone can bombed over the factory powdercoat w/o sanding it and it's peeling. May have to strip it all off.
    po35042, shaeff and six5crèéd[OP] like this.
  13. Aug 17, 2020 at 6:13 AM
    #1373
    shaeff
    Hudson Valley, NY
    Nice. Just watch the valve stems with Rim Guard. The place I had swap my tire onto a new wheel last year told me that the RG will eat the seals in the valve stems. I'm not sure how true this may or may not be, but keep it in mind.
  14. Aug 17, 2020 at 6:14 AM
    #1374
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    Spreads so much nicer with a blade than with a bucket. Looks great.
    Looks a lot like my BX. Nice ride. I'd like to put one of those next to my BX and see the differences.
  15. Aug 17, 2020 at 6:19 AM
    #1375
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Hmm interesting. What's the solution to that? Don't use rimguard? Different valve stems?
  16. Aug 17, 2020 at 6:20 AM
    #1376
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Me too. They seem extremely similar (in my limited experience)
  17. Aug 17, 2020 at 6:31 AM
    #1377
    Blkvoodoo
    Kevin
    Near Clayton NC
    They are similar but different
    Kioti Daedong is a Korean machine
    Their distribution hub is about 10miles from my house and I’ve been there several times working on their forklifts and scrubbers. Interesting place.
    They’ve got a cutaway of one of their tractors in the lobby, I have pix somewhere, they seem to be pretty well built.
  18. Aug 17, 2020 at 10:09 AM
    #1378
    fdb03taco
    Danny
    SOMD!
    I've never run a Kioti, but one of the guys I watch on YouTube (letsdig18) has a bigger one and from what he says they're pretty nice. Good quality compared to the other orange tractor :D I don't think they were around or they were harder to find when we bought our Kubota in 2015ish
  19. Aug 17, 2020 at 11:21 AM
    #1379
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    What turned you away? I’m
    Loving mine so Far. Changed the oil at 10 hours. Currently has 18 on it.
  20. Aug 17, 2020 at 12:10 PM
    #1380
    shaeff
    Hudson Valley, NY
    No clue, maybe they make valve stems with silicone seals on them or something? Maybe RimGuard would know? The tire place I dealt with says they won't touch it, they use washer fluid, RV antifreeze, or calcium.
