Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Aug 17, 2020 at 1:17 PM
    #1381
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    engine cutaway
    hi/lo range
    full machine
    final drive
    hydrostat
  2. Aug 17, 2020 at 1:53 PM
    #1382
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Thanks. I'll look into it before I go the beet juice route.
  3. Aug 17, 2020 at 2:02 PM
    #1383
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Rim guard is non corrosive so I question your tire place. Calcium is corrosive and will eat stems and rims. Over time the tires leak and tubes are needed. Washer fluid is a cheaper alternative if you don’t have freezing issues but not has heavy at RG.
    six5crèéd[OP] likes this.
  4. Aug 18, 2020 at 4:30 AM
    #1384
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Just price. I could get a Bad Boy with the specifications I was looking for and pay less money. I've been pleased with it so far.
    Babybluetaco[QUOTED] likes this.
  5. Aug 18, 2020 at 11:38 AM
    #1385
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    That was me that posted that. I know it's not corrosive (hence the name Rim Guard) :) I questioned it as well, but they said it eats the valve stem seals. I also noted that I did not know the legitimacy of the statement, just something that he might want to check out before spending all that money on the RG.
    My calcium filled wheels lasted from 1964-2019, eventually leaked out of the valve stems and ate the wheel. It was a pretty good run, though. I'm with you, as far as cost I think that the washer fluid is the best bang for the buck.
  6. Aug 18, 2020 at 12:37 PM
    #1386
    jester156
    Cumberland, RI
    Nice run for sure. 10 years with RG and no issues on my machine.
  7. Aug 19, 2020 at 5:03 AM
    #1387
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
  8. Aug 19, 2020 at 5:04 AM
    #1388
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    :spy:
  9. Aug 19, 2020 at 5:05 AM
    #1389
    uploadadventure
    Dixon, Mo
    Recently, I’ve been on compacts and mowers... so right up this alley (ish)
  10. Aug 19, 2020 at 6:56 AM
    #1390
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    So I looked into this a little more. Found a lot of reports of rimguard dissolving the adhesive that holds the brass insert into the rubber valve stem. Typical case is that it works fine, until it's dissolved enough that the next time you take the valve cap off, the core breaks and/or comes out with the cap and is unable to be fixed. Apparently this has only become a problem in the last 10-15 years after updates to the adhesive used in the stems. If you use a proper metal valve (even better if it's one rated for air and liquid), then there's nothing in there for the rimguard to dissolve.
    Seems silly that they don't just include metal valve stems on all tractor tires.
    I'm planning on having the stems in the rear tires swapped out for metal. Now just debating between rimguard at $4/gallon, or RV antifreeze for ~$3 (which seems a little safer than washer fluid).
  11. Aug 19, 2020 at 10:24 AM
    #1391
    jester156
    Cumberland, RI
    Rim guard is 11lb/gal. Not sure what rv is but probably around 8lb similar to water. Do you want to save a few coins or pay for the added weight benefit
  12. Aug 22, 2020 at 4:31 AM
    #1392
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got the gangs done on the miniature disc. Now to attach them to the frame.
    Rick323, Bushed, po35042 and 2 others like this.
  13. Aug 22, 2020 at 5:41 AM
    #1393
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    That is way cool. Fantastic work!
  14. Aug 22, 2020 at 6:49 AM
    #1394
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Loaded the tractor on the trailer to do some scraping. Used the hand hole on the fender to get on and off. Noticed this bees nest after I got off on the trailer. I’ve already sprayed and knocked one nest off there this summer.
  15. Aug 22, 2020 at 7:01 AM
    #1395
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Wasps.
    Bees are good.
    Wasps are evil.
  16. Aug 22, 2020 at 10:46 AM
    #1396
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  17. Aug 22, 2020 at 7:42 PM
    #1397
    Steve Urquell
    I fabbed a 2" receiver hitch out of a bumper hitch, mounted it to my 3205 so I could test it out brush hogging. Make sure all leaks are fixed before putting the body on.
    My road frontage was 3ft tall and I had rats running out in front of me. 3205 and Swisher hog ran great. 3205 steering is tight. I figure it's got a bad bearing at the tilt mechanism or something that needs to be addressed.
    I also picked up some ATV tires to mount on it. $20 for the pair. They have about 1/2 of the tread gone but plenty of life left for a GT. I cut sipes in the worn tread to give more traction.
    20200822_151539-1.jpg 20200822_154253-1.jpg 20200822_165728-1.jpg 20200822_201053.jpg 20200822_201117.jpg
  18. Aug 23, 2020 at 7:01 PM
    #1398
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got some pics of me bush hogging yesterday. The bottom picture, I’m on the tractor but look like a ghost.
    Steve Urquell likes this.
  19. Aug 24, 2020 at 5:52 AM
    #1399
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    My BX never ceases to amaze me. I removed a tree that fell in my yard from the tornado two weeks ago. I wanted to get permission from the adjacent landowner to access the tree from their property so it took a while. It was a pretty big tree, but I had it cleared in about 5 hours. I was working with the mower deck attached and I was even able to mow the area where the tree had fallen once it was removed. This little machine was manhandling the piles of brush and holding up sections of the tree so I could buck them in to firewood sized logs. The guys on the adjacent land called it a "bad mother fvcker" :rofl::rofl:
  20. Aug 24, 2020 at 7:07 AM
    #1400
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    parkman likes this.
