Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Jul 11, 2024 at 6:34 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    have a pic of my pops with one like that. its only a bad day if it was your last.
  2. Jul 11, 2024 at 6:36 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    maybe modify one for a truck. got one on jeggs for a previous truck.
  3. Jul 11, 2024 at 6:38 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    @koditten may have an idea.
    sdk1968, shaeff[QUOTED] and wilcam47 like this.
  4. Jul 11, 2024 at 6:59 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have no issue with them. I've only seen 1 in the last 5 years.
    I've never installed one, but it would be an easy job. I know what you mean about the manufacturer not giving a shit about ease of maintenance. Some of those filters are impossible to remove without making a mess.
    I honestly have a love/hate relationship with the oil coolers. The engine builders always use the shittiest hose clamps, then the hose leaks and makes a hot mess.
    If a person keeps up on oil changes, the cooler really isn't going to gain you much.
    sdk1968, shaeff and Drainbung like this.
  5. Jul 11, 2024 at 9:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  6. Jul 11, 2024 at 9:45 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    Yeah the universal ones might be the easiest route to take. I actually have one and some -6AN line from my old Supra. I should check to see if it'll fit and if I still have the different threaded adapters to make it work.
    The original Kawasaki 23hp filter was easier to reach than the Briggs I replaced it with. Avoiding the mess will be a secondary benefit, I can't hardly reach the damn thing as it sits. It's one of those things I overlooked when I did the motor swap.
    I'm a big fan of T-bolt clamps. I'm a bigger fan of -AN lines for things like this, and may explore that further. I don't need some big honkin PH8A sized filter on this thing, I just need it accessible. :rofl:
  7. Jul 11, 2024 at 9:50 AM
    koditten
    Kirk
    Central Michigan
    Yep, as long as the filter has the same pipe thread and same size "o" ring gasket, you got lots and lots of filter choices. Often bigger is cheaper and it allows you to put in more oil when you change. More oil is always a benefit.
  8. Jul 11, 2024 at 10:21 AM
    shaeff
    Hudson Valley, NY
    Right on. Time to do some poking around, I'll be due for a change probably by the end of August.
  9. Jul 12, 2024 at 9:08 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    Tractor-related funny...or humorous.... :)
    450527227_7772369806150326_1462978068228_5e267028b8204cf9378ede8b4d4d3ec44e9901f4.jpg
  10. Jul 12, 2024 at 9:26 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Alright y'all I helped and played on the neighbors trackhoe today and cleaned out the creek branch
    IMG_20240712_083354056_HDR.jpg IMG_20240712_083407132_HDR.jpg IMG_20240712_083404586_HDR.jpg IMG_20240712_100625031_HDR.jpg
    All done in 2 hours.
  11. Jul 12, 2024 at 10:17 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Sweet toy, I could definitely do some damage with that!
  12. Jul 12, 2024 at 10:57 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Looks like a B5 ..
    Fun fun fun.
  13. Jul 12, 2024 at 11:26 AM
    Tiedie
    David
    WFOY
    Yep B50
  14. Jul 12, 2024 at 1:02 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I got to use our mini excavator today too! Stump removal and clearing a bit of overgrown land to reclaim as lawn hopefully.
  15. Jul 12, 2024 at 1:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I'm going with a MechMaxx or PowerKing.
    But I'll not be ordering it until the last week of September.
    Where I'm dropping the trees is in the main yard. And I don't have time to get them up in a week.
    I want to keep the yard mowed. So......until then, I'm keying an eye on the prices and "hoping" one of them goes on sale.
  16. Jul 12, 2024 at 2:31 PM
    sdk1968
    03 Taco TRD
    Wow! You guys all have bigger/heavier machines! Those are in that near 10K lb range.
    Are you using dump trucks to move them? Or Dually's?
    had a VIo 25 Yanmar 6,000lb, now have the 302.7D cr CAT (close to 6k lbs)....
    These are still 3/4 ton friendly.
    You guys got way heavier toys!
  17. Jul 12, 2024 at 2:40 PM
    Tiedie
    David
    WFOY
    One I use is my neighbor's, if its next door and I ask he brings it over. His son moves it with a F350 dually.
    Hahaha after we got done I looked over and he was walking it up the road about a mile.
  18. Jul 12, 2024 at 2:46 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Not me. I don't have anything resembling those machines. Just the tractor I bought in March, and my two Zero turns. And I guess the Mule that's been giving me trouble lately. :angrygirl:
    And I'm not the "most Guys" they talk about on those Particle commercials either...
    https://youtu.be/jSd5WurgQoc?si=DRAyvClqrgRsCDy7
  19. Jul 12, 2024 at 2:52 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Most guys don't give a shit...:poking:
  20. Jul 12, 2024 at 2:58 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    EXACTLY! How F'n hate-able is that commercial?!?
