Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jul 28, 2024 at 6:11 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Got it from the guy I bought my place from. Gas powered, change the oil (1qt) annual, grease the pulley and let it rip. It makes short runs like a golf course, occasional drunk run back down the driveway which explains the headlight....
  2. Jul 29, 2024 at 11:50 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    PXL_20240729_162007712.MP~2.jpgBeen clearing woods like a madman lately.
    Its about 100 feet to that target stand way in the background
    Kbar, sdk1968, Delta09 and 7 others like this.
  3. Jul 29, 2024 at 3:41 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I started after work today, got to get some sunlight in here.
  4. Jul 30, 2024 at 6:07 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    I want one lol
  5. Jul 30, 2024 at 6:24 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I liked the steel plate operator cage.
  6. Jul 30, 2024 at 6:27 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Yep same here.... My woods are way overgrown. Wife wants them left alone.
    Keep telling her that we could selectively clean it up & help the other trees out..... But she wants that wall of creepyness all around our property. :)
    KRAMERICA, Kbar, Drainbung and 2 others like this.
  7. Jul 30, 2024 at 6:28 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :eek::eek:zombie chopper
  8. Jul 30, 2024 at 8:27 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Had another flat tire on the B7100:confused:. I would imagine that the front tires are a least 20 years old along with all the thorns in them:rolleyes:, that keep popping the tubes. Sooo ordered 2 new 6x12's 6 ply and tubes. Will drop everything off as soon as they arrive. :thumbsup:
    VTCAL, sdk1968, Drainbung and 4 others like this.
  9. Jul 30, 2024 at 8:57 AM
    Kbar
    Western WA
    22 OR
    I think it’s just a canopy with a plywood/cardboard/foam back plate contraption?
  10. Jul 30, 2024 at 9:12 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    A 1000 ways to die in the west...
  11. Jul 30, 2024 at 9:16 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Have you thought about taking your tires to the CO-OP to have them pump some sealant goo? Around here blackthorn trees are a an issue, my leak issues abated quickly once I did that.
  12. Jul 30, 2024 at 9:59 AM
    Tiedie
    David
    WFOY
    Yes. But the guy we use has tried everything. Pounding the thorns out. The biggest thing is the wheels/rims are rusty from being over 40 years old so we have to use tubes. Plus the tires are kinda worn out and 4 ply. Upgrade will be nice.
  13. Jul 30, 2024 at 12:14 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Have you tried sanding and repainting the wheels?
    Mine would hold enough air to be useful for about 3 weeks, then if you didn't refill it, the pressure would drop low enough to pop the bead. I tired bead sealant thinking it was a bent rim issue. When I finally took my tire down to the co-op, they found at least 6 pin holes in the tire. Pretty annoying issue!
    six5crèéd[OP] and sdk1968 like this.
  14. Jul 30, 2024 at 12:34 PM
    Tiedie
    David
    WFOY
    Their pretty bad inside my tire guy has tried sanding. I hope I can watch him change em out. The tires on it now are 4 ply and only about 1/2 inch on the bars the new ones will be 6 ply, I'm gonna try this first to see how long it lasts. Last resort is gonna be new rims which are available for double the price of tires each.
    He even asked me if I wanted to load them, but I reminded him I have a FEL he laughed and said ok just carry some rocks around. He's pretty cool all he works on is tractors OLD ones he restores. The tires are a side thing. Next time I go there I'll try to get some pictures of stuff he's working on. Should be in the next couple of days.
    I really need to invest in tire tools.
  15. Jul 30, 2024 at 12:43 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Some dedicated tire tools would be nice to have, but I can't justify the dollars. So far I've managed to get by with some crowbars and large screwdrivers.
  16. Jul 30, 2024 at 2:56 PM
    koditten
    Kirk
    Central Michigan
    Them Kohler coils ain't gonna change themselves:boink:
  17. Jul 30, 2024 at 3:21 PM
    sdk1968
    03 Taco TRD
    Hey if the rims are rusty to the point of pinpoint holes?
    You can always solid fill the tires.... If you don't want weight.... You can foam a fill them.
    six5crèéd[OP], Tiedie and KRAMERICA like this.
  18. Jul 30, 2024 at 6:49 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I foam filled some wheelbarrow tires for my Aunt Shirley a couple years ago. It's worked pretty good but she doesn't move a lot of weight. I'm not sure how it would hold up under the weight of a tractor w/FEL.
  19. Jul 30, 2024 at 7:38 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    when a small kubota has a 1000hrs is that 20% use? i figure 5000hrs to be service time big time. whatcha think?
    bx2230 9k with accessories.
    sdk1968 and six5crèéd[OP] like this.
  20. Jul 30, 2024 at 7:58 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    With the recent conversation regarding Kohler ignitions, Perhaps someone can help on this issue.
    A K582 23hp flat twin is fitted to my Bolens HT-23. That engine is a points/ coil design with a single coil. A "wasted spark" setup. That means, one of the plugs sees a coil polarity the wrong way. And it shows, with hard starting in cold weather, and one spark plug "fouling out" before the other. I've gotten into the program of swapping plugs with the seasons, but I still have quite a collection of dead plugs.
    I've not seen anywhere on the net an ignition upgrade for these old engines.
    Maybe it's just poor electrical connections in general. Heck, Honda ran single coil setups on multi-cyclinder motorbikes without issues... (I think ;-)
