Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Aug 24, 2020 at 7:10 AM
    #1401
    parkman
    parkman Well-Known Member
    Park
    2024 Ford Ranger XLT
  2. Aug 24, 2020 at 7:14 AM
    #1402
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    What do you intend to use it for? Yard size?, Snowplowing, pull a cart, cultivator?
    six5crèéd[OP] likes this.
  3. Aug 24, 2020 at 7:18 AM
    #1403
    parkman
    Park
    Mowing about one acre and towing a little cart for general yard work.
  4. Aug 24, 2020 at 7:19 AM
    #1404
    Steve Urquell
    Do you have hills? Flat yard?
  5. Aug 24, 2020 at 7:22 AM
    #1405
    parkman
    Park
    Pretty much flat. I own five acres basically about one is grass rest is woods. Front yard is perfectly flat the backyard a little lumpy but no hills at all.
  6. Aug 24, 2020 at 7:28 AM
    #1406
    Steve Urquell
    OK. Those little lawn tractors are decent at mowing flat yards ~ 1acre or less. Where they come up short is in the transmissions. They won't tolerate any heavy use. The trans has a very small oil capacity and can overheat if overused drastically shortening their life.
    I always said if I needed a little riding mower I'd change the hydro oil to synthetic ASAP to get the most life out of it as they have dino oil that doesn't take heat very well. This May void the warranty though.
  7. Aug 24, 2020 at 1:07 PM
    #1407
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    My parents had a John Deere riding mower like that one from HD. Did fine on their few acres of mostly flat area.
    I had stepped up to a X300 model but the trans was slipping before I could finish my own 3 acres of hilly area. I had to exchange it up to X500 (has locking diff). Going on like 9 or 10 years with it now I think and still doing great. Thought it had a problem earlier this year but then realized I hadn't done maintenance for over 2 years.:facepalm:Plugs, filters, engine oil, diff oil, belts, etc and it's running like new again.
  8. Aug 24, 2020 at 1:36 PM
    #1408
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I just sold an xt1. We had it for a little over 2 years. It was a good little machine. I definitely wasn’t gentle on it. We used it almost exclusively for snow removal on our steep asphalt driveway. It did that surprisingly well for what it is. I’m sure I would have worn out the trans had I kept using it for that application, so we moved up to something stouter with 4wd.
    But for flat-ish mowing, I think it would do well for you.
  9. Aug 24, 2020 at 1:40 PM
    #1409
    parkman
    Park
    My wife’s uncle just bought a the exact John Deere I’m looking at. Loves it and had whatever the equivalent model from six yrs ago just gave it to his son
  10. Aug 24, 2020 at 1:51 PM
    #1410
    parkman
    Park
    did you have any belt issues with it? I read some stuff about drive belts kept snapping or falling off. I know my dads mentioned the belts breaking more recently on his Cub GT2042 And says they are cheaper made but that’s a different series.
  11. Aug 24, 2020 at 3:24 PM
    #1411
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Didn't have any belt issues on mine while I had it. Only work I ever did on it was scheduled maintenance.
  12. Aug 24, 2020 at 4:35 PM
    #1412
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    I hear a lot of folks comment about belt breakage when the machine has an electric PTO clutch. It works same as AC clutch, and the engagement is very abrupt, an aged belt doesn’t have a chance. Nor do low quality belts.
  13. Aug 24, 2020 at 4:44 PM
    #1413
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Interesting. Mine had the manual pto engagement lever
  14. Aug 24, 2020 at 5:15 PM
    #1414
    Blkvoodoo
    Kevin
    Near Clayton NC
    Manual levers and pedals release slower, if the operator isn’t a complete dolt....
    My Kubota has a 60” deck and 3 blades, I engage at low rpm then throttle up, belt is 10 years old, I saw that it had a chunk out of it this last spring, it’s replacement is waiting....
  15. Aug 24, 2020 at 7:09 PM
    #1415
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    The man I bought my 4630 from, I went over to get a round bale of hay for our goats today and got a few pictures of some of their tractors (he and his brother are in together). I don’t even know how many they have for sure.
    This is a 1990’s 3930, one owner.
    148D9E68-8FF0-403B-BEE5-FF537D786C37.jpg BE9F50C9-E894-47A6-A9DC-00F7F7E4C40B.jpg
    A few of the others and his 15’ batwing bush hog.
  16. Aug 25, 2020 at 6:00 AM
    #1416
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Found this picture of an unstyled John Deere B I restored for a friend, my dads 1970 JD 1020 he bought new, and a JD 2555 I had several years ago. And also our Jon boat that hasn't been wet in 8 years.
  17. Aug 26, 2020 at 6:18 AM
    #1417
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    currently in the shop getting worked on
  18. Aug 26, 2020 at 6:22 AM
    #1418
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Just a guess, 60? I see it has power steering, don't think the 50's did.
  19. Aug 26, 2020 at 8:18 AM
    #1419
    uploadadventure
    Dixon, Mo
    It’s a 50
    Probably mid 50’s. Guess is 55ish
  20. Aug 26, 2020 at 8:20 AM
    #1420
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Learn something new everyday :thumbsup:
