Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.2%
  2. After
    57.7%
  3. Neither
    15.4%
  4. I weed whack while someone else mows
    7.7%
Multiple votes are allowed.
  1. Aug 8, 2024 at 4:28 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Not bad! Do you think it held up better than gravel would have?
  2. Aug 8, 2024 at 6:05 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    you fellas back east get hammered with weather. im pretty lucky getting light weather most of the time.
  3. Aug 9, 2024 at 4:26 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    No, I’m not to impressed with the asphalt millings on the hill. It’s easy to spin on them if you aren’t careful. They are great for flat areas.
    sdk1968, Drainbung, wilcam47 and 2 others like this.
  4. Aug 9, 2024 at 6:10 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Good to know this.
  5. Aug 9, 2024 at 7:32 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Gotta get them sprayed with oil. Call your local asphalt outfit to come and spray it. Soaks into the millings and helps them adhere to eachother in the heat of summer. Also, it’s not very eco friendly. With the rains we get out here they won’t sell it to residential customers anymore due to the runoff. I worked for a guy who had a mile long driveway of millings and had his sprayed every summer if only to keep the dust down. Asphalt millings get real dusty when they dry out.
  6. Aug 9, 2024 at 8:33 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    A key point there is that you get light weather nearly all of the time. :rain:
  7. Aug 9, 2024 at 9:37 AM
    Kbar
    Western WA
    22 OR
    Very true. We get 9 months of soggy days with barely the sun popping out. Winters are wettest and during El Niño November through February gets lots of rain. Not a lot of snow in the lowlands though. Where he loves out on the Olympic peninsula, they have a stretch called the banana belt where it gets less rain. This is usually the areas East and Northeast of the Olympic mountain range. They call it the rain shadow. I however live at the foot of the cascades and get more rain.
  8. Aug 9, 2024 at 9:44 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I know, I spent 18 years living in Puyallup. I remember it well. I probably get the same rainfall annually in TN, but it comes way more sporadically and in heavier doses. So you usually have time to dry out between storms.
  9. Aug 9, 2024 at 3:00 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Concrete grinding is done. All toe catchers removed!
    Now its on to the next project in the AM. Gonna get that outlet culvert in the pond & start rocking it up.
  10. Aug 9, 2024 at 5:34 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    Water carved out the Grand Canyon. The golf course I work on has a bunch of culverts. Every one of them is eroded around the edge's. Weren't put in right and water found a way. When installing drainage you cannot make a mistake or cut a corner. You will suffer the consequences.
  11. Aug 9, 2024 at 6:22 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    You ain't stopping water. Just have to work with it.
  12. Aug 10, 2024 at 5:31 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Someone on here told me water doesn’t hurt anything, it’s moving water.
    And that’s what we’re all fighting.
    sdk1968 and Drainbung[QUOTED] like this.
  13. Aug 10, 2024 at 5:35 AM
    Tiedie
    David
    WFOY
    :eek:
  14. Aug 10, 2024 at 6:35 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Of course there are exceptions. Like when slow moving water fills a bowl (like New Orleans), and then the water sits in the bowl for a month in a lot of places (like after Katrina). :eek::eek::eek:
  15. Aug 10, 2024 at 10:00 AM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Anyone looking for a B7200 HST with a front mounted snow blower? (Quick Hitch)
    It's in the shed behind the replacement.
    Kbar, w.adventures, Drainbung and 4 others like this.
  16. Aug 13, 2024 at 11:33 AM
    sdk1968
    03 Taco TRD
    Its done!
    The brush hog head for the mini excavator is ordered!
    Did all my hogging with the tractor today & my wife said: did you order that for the excavator yet?
    Nope was my reply & after the asschewing stopped I put the order in. Supposed to be here in 2 weeks. :)
  17. Aug 13, 2024 at 12:36 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so.....was she in favor of you buying new toys?
  18. Aug 13, 2024 at 12:41 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm not tracking...the implement or your new ass will be here in 2 weeks...?
  19. Aug 13, 2024 at 12:59 PM
    sdk1968
    03 Taco TRD
    Yes she wanted me to get it.
    Yes the implement is on its way.
    She thinks it will be safe & easier to get into places that SHE wants me to brush hog verses places I already do.
    NO she isn't paying for it.
  20. Aug 13, 2024 at 1:10 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    but shes supportive!:bowdown:
