Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Aug 26, 2020 at 6:27 PM
    #1421
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Cool sunset this evening.
  2. Aug 26, 2020 at 6:29 PM
    #1422
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I guess if you had no other way you could hook a drag harrow under your bucket, I’m taking it to the farm tomorrow to start working on a deer food plot. It’s the only way I can get it on the trailer and be able to get it off.
  3. Aug 26, 2020 at 6:38 PM
    #1423
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got the miniature disc finished today. Added it to the miniature collection of things I’ve made over the past couple years.
  4. Aug 27, 2020 at 5:55 AM
    #1424
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Still refurbishing the Cub 3205. I cleaned up my wheels and painted them with Van Sickle Int'l White from Orshelin's. Really good paint and better than TSC Majic. Unfortunately VS doesn't make Cub yellow.
    Mounted the 26x10-12 Rip Saws I picked up which measured out to 24" tall after aired up. Squarest shouldered tires I've ever seen.
    I bought 1" long bronze bushings from Grainger for the front spindles. The factory ones are 3/4" long so these will grab clean spindle and mitigate the wear. Also bought some thrust bearings and washers to do the "poor man's power steering mod". The 1" bushings I ordered have 1/8" flanges vs the factory 3/16" to allow for the thrust bearing mod w/o having a height difference. Froze the bushings to shrink them down for easy install. It has power steering but I just wanted it to steer really easy lol.
  5. Aug 27, 2020 at 7:03 PM
    #1425
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Started on food plot today, I always watch my temp gauge when bush hogging and here’s why. I cut the field twice, needs at least one more time. Trying to beat the rain coming.
    cosmicfires likes this.
  6. Aug 27, 2020 at 7:08 PM
    #1426
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    Love the grill beard.
  7. Aug 28, 2020 at 3:25 AM
    #1427
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Found this old tire pump from the 1950’s at a tractor show a while back. It goes on the PTO shaft and the chain hooks to the drawbar to keep it from spinning.
    MoneyMan55, shaeff, Bushed and 2 others like this.
  8. Aug 28, 2020 at 7:37 AM
    #1428
    jester156
    Cumberland, RI
    That’s wild. Unlike everything new, it even has a zerk fitting
    six5crèéd[OP] likes this.
  9. Aug 28, 2020 at 11:31 AM
    #1429
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    This hydraulic top link is nice. Just jacked the cut away back and got it sitting good on the trailer, from a simple handle :thumbsup:
  10. Aug 28, 2020 at 11:32 AM
    #1430
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got our food plot in, used the 140 with this little spreader. That’s 150 lbs of fertilizer in it, I’m assuming it’ll hold 250.
  11. Aug 30, 2020 at 8:06 AM
    #1431
    CavalryTacoTN
    CavalryTacoTN Well-Known Member
    Lee
    2020 magnetic f150 STX
    Bought this used Draper head earlier this year. Had some hydraulic issues... the center Draper wouldn’t run worried me to death for months. Finally figured it out and now I’m beyond excited to run it. First time I’ve really ever been around drapes we’ve only ever had auger heads.
  12. Aug 30, 2020 at 7:40 PM
    #1432
    Steve Urquell
    My FIL called me the other day and said he knew a widow who was getting rid of her husband's stuff and was going to trash a Lincoln welder. He had told her it was "no good". I got it for free.
    It had a 3 angle blade dryer cord spliced on the factory cord with white black and green hooked, red snipped. I got the proper 2 blade and D ground end, took the back off it to make sure red was snipped and wired in the correct plug leaving the spliced cord off.
    I only had 115V in my garage so I put in a double 50A breaker to give me 230V and ran an 8AWG wire straight down the wall and put a surface mount 230V receptacle 12" up from the floor so I didn't waste welder cord length going up the wall. Got her hooked up, put a 7018AC rod in the stinger and 150A on the welder and ran a bead smooth as buttah' on the first strike
    I was going to work on my brush hog hitch today, lifted it up and put the front of the hog on a jackstand to let me the the hitch down. It flopped way down to the floor.
    Looked and both sides of the drawbar are cracked. I never noticed it before because the hitch always has upward pressure on it which kept the cracks closed. Time to fire up the new welder.
    Ran some 7018AC and 6013. First stick welds since 2009. This hitch has been discontinued by Swisher for being trash. It is flimsy and flexes and twists. I chained it under tension to keep it from bending upward 8" like it has every time I've used it. If it breaks again I'll completely rebuild it.
    20200828_214459.jpg After cleaning up
    20200829_143615.jpg 20200829_143620.jpg 20200830_110443.jpg 20200830_140017.jpg
  13. Aug 30, 2020 at 8:15 PM
    #1433
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    The Tombstone is a great welder for the home gamer shop, you heard the cooling fan when it powered up ( I hope) keep an ear out for it when using it, the one I had the fan blade came off the motor shaft. My dad happened to hear something inside the box while was being used, then noticed he didn’t hear the fan, opened it up and the blade just laying there. It got epoxied back on.
  14. Aug 30, 2020 at 8:36 PM
    #1434
    Steve Urquell
    I pulled the back off of it to verify the wiring. Ran a bead with the back off and the fan kicked right in. This thing runs as good as any of the big AC/DC Hobart units I used to weld on when I worked in truck and trailer shops. I'm surprised that an AC unit runs so well .
  15. Aug 31, 2020 at 3:21 AM
    #1435
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I learned to weld from my dad at 10 years old with that exact same welder in 1985. He still has it and uses it. I had one for many years and sold it last year. Haven’t used it since buying a Miller Bobcat many years ago and made a man very happy by selling it to him :thumbsup:
    Steve Urquell[QUOTED] likes this.
  16. Aug 31, 2020 at 4:12 AM
    #1436
    Steve Urquell
    You hear a lot of bad about AC only units. I expected it to be a PITA to weld with. I was pleasantly surprised when I struck the first arc with it.
    I've been using my FIL's Miller 130XP for a couple years. He pretty much gave it to me cuz he couldn't weld well with it--bad eyes and hands.
    It was really lacking in heat range when I built my loader. I ended up doing a lot of beveling and pre-heating with multi-passes to get it welded right. This thing will burn in deep when needed and I'm happy to have it.
  17. Aug 31, 2020 at 6:28 AM
    #1437
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @MoneyMan55 share some of those hay making and tractor photos with us :thumbsup:
    MoneyMan55 likes this.
  18. Aug 31, 2020 at 7:26 AM
    #1438
    MoneyMan55
    MoneyMan55 Licensed Master Electrician
    Doug
    South Central PA
    2017 DCSB SR5 Blazing Blue Pearl
    @six5creed Thanks for the invite. This is the old Ford we trim and mow around the cabin when the grass gets high early in the season. We don't make hay mowing the fields with the JD, lots of weeds and poison ivy mixed in. We were in a Grasslands program with the government that just expired last year. Were only permitted to mow one time a year in August. Turkeys were normally all out of grass by that time.
  19. Aug 31, 2020 at 4:55 PM
    #1439
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    I have that same old welder too. I admit, I'm not much of a welder.:anonymous:It's not always pretty but it's gonna hold. I need practice. Daddy got it some time in the 70's. It still works fine. Do they make stuff like that anymore??
  20. Aug 31, 2020 at 5:15 PM
    #1440
    Steve Urquell
    It is amazing that there is a product that you can buy once in your lifetime and pass it on to the next generation to use.
    six5crèéd[OP] and Blkvoodoo like this.
