Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    42.3%
  2. Mow and weedeat, yes
    34.6%
  3. Pants all the way for me
    23.1%
  1. Aug 29, 2024 at 5:28 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    I can't see whats above. That's a really steep grade so runoff is going to have a profound effect on it. There is a saying in government (yes I work there), "there's never enough money to do it right, but there's always money to fix it".
    joeyv141, Drainbung, sdk1968 and 2 others like this.
  2. Aug 29, 2024 at 6:28 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    That looks identical to the one I'm running on mine. Didn't have to cut anything off.
    Your tractor is almost identical specs to mine & KR's.... Just be patient & when it gets here you will know pretty quick. As long as it doesn't bottom out it doesn't need cut. Make sure you don't have a bind point & set your top link at "level".
    What it is is the rear arms on the 3 point is longer on the bigger tractor which should be enough to get ya by it.
    When your grinding with this.... Be sure to take those pivot pins out & pin the legs up. This will let you see just enough pressure against the wheel for the unit to do a slight tilt forward. If it tilts a lot?
    You are taking too big of a bite. :)
    Get that camera ordered if ya want to be ahead of the game.
    https://www.amazon.com/Wireless-Sys...9958201&mcid=cdd3f1f4a69e3fb1a68fa48013281120
  3. Aug 29, 2024 at 6:31 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Anyone have a good tutorial on rebuilding a hydraulic cylinder?
  4. Aug 29, 2024 at 7:24 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    water bars go a long way at preserving material.
  5. Aug 29, 2024 at 7:37 PM
    VTCAL
    2021 Sport
    Pat's Quick hitch is an option.
    https://www.patsquickhitches.com/
    I have them on a couple of smaller tractors so the PTO shaft fits for the chipper shredder, along with the larger tractor.
    Happy with the way they work across a variety of attachments. Still fiddly however.
  6. Aug 30, 2024 at 3:54 AM
    SomeTacoDude
    six5crèéd[OP] and sdk1968 like this.
  7. Aug 30, 2024 at 4:03 AM
    w.adventures
    Nowheresville, SC
  8. Aug 30, 2024 at 4:22 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Most are the same. I like the Abom79 ones he has done. Some of the older ones he shows measuring for seals and stuff too. But I watch him anyways so bit biased towards him. He has done some tractor cylinders that I can remember for his step dad's tractor so those are probably the ones I'd go for.
  9. Aug 30, 2024 at 5:21 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    They aren't that hard to rebuild, just messy. Some of the inner seals/packings can be hard to get in. I've found soaking them in hot water softens them up a little to make install easier.
  10. Aug 30, 2024 at 6:00 AM
    w.adventures
    Nowheresville, SC
    Awesome thanks! So many crappy YouTube videos out there and didn’t want to waste my time clicking on random ones. I knew you guys would have some good info and tips.
  11. Aug 30, 2024 at 6:18 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I've been trying to sell a ridgid 300 machine for less than 2k, brand new they're about 6k. Nobody wants to spend money these days and its understandable
  12. Aug 31, 2024 at 12:48 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    They are generally fairly simple luckily. Unscrew the....retaining part thingy and just pull out the shaft. Replace seals and slide shaft back in and tighten the retaining thingy back up. But always nice to watch someone else do it too!
    And yeah it can be messy but trying to hold it horizonal with the end over a five gallon bucket should catch most of the fluid.
    Here is one he did on a Kubota cylinder....just know it involved repairs but the assembly/disassembly part should be what you need. He also has ones he did for a Mahindra tractor too https://youtu.be/xf4greJbPqo?si=B8_2MlgYPx4y1nWO
  13. Sep 1, 2024 at 2:59 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Ran the tractor today. No more overheating. Mostly ran between 155-165 degrees
  14. Sep 1, 2024 at 3:15 PM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Cleared a path to the Brute Force lift w/ the x27
    Tomorrow we'll use the Brute Force to split the large rounds
  15. Sep 2, 2024 at 5:30 AM
    sdk1968
    03 Taco TRD
    Good to read! Should be good till fuel filter change now! Enjoy!
    six5crèéd[OP] and Drainbung like this.
  16. Sep 2, 2024 at 10:27 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That’s great!
    sdk1968 and Drainbung like this.
  17. Sep 3, 2024 at 5:01 PM
    Tacoma Mike
    Southern Maine
    I would never start another restore after the GT is done but, this thing would twist my arm to the max
  18. Sep 3, 2024 at 5:14 PM
    VTCAL
    2021 Sport
    I started out this morning "just looking" into the condition of my L2172 Six foot snow blade. Thinking of the winter ahead. I bought the unit "sight unseen" , and although it never saw use , it has sat out and rusted.
    I got the pivot frame off and have done an electrolysis de-rust on that piece. I has cleaned up quite well. The "trip frame pivot was rusted solid, but with the help of a floor jack and a five foot pinch bar, a bit of PB blaster and Marvel Mystery oil, That joint is now moving. I still need to figure a way to get the two pivot pins out. Might take the "smoke wrench". I want those pins out and cleaned up/ Then to be coated with Never-Seeze on reassembly/
    I went over all the blade back side surfaces with the side grinder and a flap wheel, Lots of blistered paint.
    Any suggestions as to the best "rusty metal primer" to put over the rust spots? It's a long way down to bare metal in many places. Rust=oleum" has always worked, I've never known how well.
  19. Sep 3, 2024 at 6:09 PM
    w.adventures
    Nowheresville, SC
    I’m going to go with this stuff when I do my camper frame. They make a platinum version as well. https://www.eastwood.com/eastwood-rust-encapsulator-plus-quart.html
    sdk1968 and six5crèéd[OP] like this.
  20. Sep 3, 2024 at 7:44 PM
    VTCAL
    2021 Sport
    But you have not used it yet?
    I first tried POR- ?? back in the 90s. I'm not sure it is any better than Ziebart. Ecapsulation, But "Rust never Sleeps".
