Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Oct 8, 2024 at 8:38 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    The Makita/ Dolmar is a good saw for the money.
    I run a Husky XP , Commercial grade, but light weight.
  2. Oct 9, 2024 at 4:05 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Stihl is the best overall, even their homeownee grade ones are great. Echo and Husqvarna are also very good, they have homeowner and commercial grade as well. Any of the Stihl saws should be running in 15-20 years as long as you do basic upkeep, for Echo and Husqvarna I would recommend getting a commercial grade saw if you want it running in the same time.
  3. Oct 9, 2024 at 4:12 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Got most of the weeds wacked yesterday and mowed the yard at the house. Then I looked over at the garden and see the wife digging taters. I go over and said hey how about I put the middle buster on the tractor and we make it easier. She kindly agreed, we got probably 2 bushels. We have brussel sprouts growing now and red and green cabbage. The cabbage are getting eaten by bugs but the brussel sprouts are not. So I guess we sacrifice the cabbage o_O.
  4. Oct 9, 2024 at 4:51 AM
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    Thanks for the info, I want a commercial grade saw but dont want to spend $1,500
  5. Oct 9, 2024 at 4:52 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Does your trailer have a ground wire from the plug to the trailer tongue/frame or is it grounded through the hitch? I've seen that pose a problem if no ground wire from the plug to the trailer frame.
    sdk1968 and Drainbung like this.
  6. Oct 9, 2024 at 4:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have a Stihl MS290 and it's a great all around saw, gets heavy limbing but it's big enough to cut decent size stuff. If you just need something for storm cleanup, the MS250 like Kirk shared would be a good one too.
  7. Oct 9, 2024 at 4:55 AM
    TacoMTga
    Brian
    I was thinking of maybe the Stihl 261
  8. Oct 9, 2024 at 4:57 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I forget they've changed the numbers now. That would probably serve you well :thumbsup:
  9. Oct 9, 2024 at 5:01 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I reckon I need to put the skidsteer in the shop and tear into it. I ask my son to level out where we burnt the brush pile Monday. (10 minute job)
    He and I ran the machine about 20 hours when we cleared the food plot with no problems and it's been sitting in the shed for over a month.
    He was on it less than 3 minutes and he walked up to where I was at the shop. He said the right side control stick wouldn't move but a tad.
    I went down and was hoping he just didn't have the seatbelt latched good cause you can't run it without it hooked. That wasn't it.
    It would move about 3' front or back and lock up. Left side was fine, I kept messing with it and something popped inside and it worked fine. Not sure if a wheel bearing went bad or something to do with the drive chain from wheel to wheel. I suspect a wheel bearing.
    sdk1968, Drainbung and koditten like this.
  10. Oct 9, 2024 at 5:04 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've never tore into a skid steer, but always wanted to.
  11. Oct 9, 2024 at 5:07 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    They really aren't that bad on the axles, had to put some axle bearings in the Case I had years ago and also repair the chain. It broke once, #60 HD chain. Biggest one I've ever messed with. Kinda like working on a mower to be honest, just heavier.
  12. Oct 9, 2024 at 6:09 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    A great all around saw is the farm boss
    https://www.stihlusa.com/products/chain-saws/farm-and-ranch-saws/ms271/
    My neighbor has one and it rips.
    It’s not a pro saw but a good saw. I have the 311 and it does everything I want it to but it’s heavy. Most folks when they got alot of wood to deal with get 2 saws. One big and one small. But a solid all rounder you can’t beat the farm boss
  13. Oct 9, 2024 at 6:44 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I run a Stihl 029 Farm Boss that I bought in 1997 - still runs great. I had to replace the electrical module once - only issue I've had with it.
    I just replaced the bar (18") and got 2 new chains. I'm good for another 20 years!
    Oh, and I always run non-ethanol gas in it.
    KRAMERICA, sdk1968, Drainbung and 2 others like this.
  14. Oct 9, 2024 at 11:30 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    261 or splurge for a 462 if you want pro line.
  15. Oct 9, 2024 at 11:32 AM
    jester156
    Cumberland, RI
    Fixed. Simple loose ground on the trailer harness. Oddly it’s the back of the battery box screw which I don’t feel will be a solid connection as the box is plastic through the frame. Something to keep an eye on
    sdk1968, Drainbung, Kbar and 2 others like this.
  16. Oct 9, 2024 at 11:45 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Glad you found it and it was something simple :thumbsup:
  17. Oct 9, 2024 at 12:10 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Bought the same set a week or so ago, definitely beefy. Took them to the local mower for sharpening. Bring on the leaves!
  18. Oct 9, 2024 at 12:40 PM
    jester156
    Cumberland, RI
    That was the issue. Nut came loose.
  19. Oct 9, 2024 at 2:36 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    You funny. That's a big boy saw for sure. NOT for the faint of heart or wallet.
    I actually have the 250 & 291 both. They are great saws.
    That 250 is great for limbing or other medium to light stuff.
    The 291 is good for all kinds of stuff for the non pro. It does get heavy pretty quick though.
    500i or 880i are like taking a vette to a go cart race.
  20. Oct 9, 2024 at 5:03 PM
    VTCAL
    2021 Sport
    The weight of the 500i would wear me out.
