Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Oct 14, 2024 at 2:06 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    What the heck is fuel dryer? Like Stabil?
    sdk1968 and six5crèéd[OP] like this.
  2. Oct 14, 2024 at 2:12 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    its methanol alcohol. it helps obsorb/evaporate water in fuel. i mix it with windshield washer fluid for my injection system.
  3. Oct 14, 2024 at 2:20 PM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Sounds similar to K100 fuel treatment, yes you can burn it
  4. Oct 14, 2024 at 3:45 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It just makes the water " missable". In short, it helps the water mix with the gasoline instead of separating and dropping to the bottom of the tank.
    Non ethanol fuel separates very quickly from the water, water is much heavier than gas and it settles to the bottom of the tank because of its greater density. After a while, that water level will rise above the fuel line intake. Now you are feeding straight water to the carb.
    I have no issue with ethanol gasoline, the ethanol allows the gasoline and water to blend and burn.
    As long as you are not storing ethinol gasoline for more than 2 years, ethanol fuel is just fine for most uses.
    The vented, non sealed gas tanks are the ones that have the biggest issue with ethanol gasoline.
    The tanks heats up in the daytime, then cool in the nighttime. The cooling creates a vacuum and draws in the moist nighttime air. The water in this air condenses and sinks to the bottom of your gas tank. After many cycles you are left with much water in the tank. Enough that it may be above your fuel line intake. (Not many gas tanks have the fuel line coming directly off the bottom). Now you are feeding pure water to the carb. No engine runs very good on water.
  5. Oct 14, 2024 at 3:50 PM
    joeyv141
    Virginia
    Deleted part that isn't relevant for my response.
    This is interesting, I've never thought of a gas tank doing this, is this why contractors use metal gas cans that are sealed so they don't do this when in the sun all day?
  6. Oct 14, 2024 at 6:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    best i try is keeping fuel cool. its more potent, less vapors too. ive got a little shade shed for fuels.
  7. Oct 14, 2024 at 6:44 PM
    koditten
    Kirk
    Central Michigan
    That, and the EPA doesn't want those fumes being pushed to the atmosphere.
    We paid for that gas, we don't want it sent out into the air where it does no good.
    This is why we are seen more and more small engines with evaporative fuel systems. The gas tank is not vented like the days of our youth.
    The unburnt fuel vapors are stored in a charcoal chamber. The next start up, the fuel vapors are pulled into the intake to be used for combustion. Of course I'm simplifying the procedure, but it is the general procedure.
  8. Oct 15, 2024 at 7:15 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    He said fix it.
    Kbar, 308savage, sdk1968 and 3 others like this.
  9. Oct 15, 2024 at 7:16 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    It aint got no compression;):rofl::rofl::anonymous:
    Kbar, sdk1968, w.adventures and 2 others like this.
  10. Oct 15, 2024 at 7:30 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    That’s impressive!
    Kbar, sdk1968, wilcam47 and 2 others like this.
  11. Oct 15, 2024 at 8:31 AM
    w.adventures
    Nowheresville, SC
    Curious what the final bill will be to fix a crappy ryobi blower
  12. Oct 15, 2024 at 8:42 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    He's buying the piston and jug, I'll probably cut him a deal and charge him 50-60 :D
    Kbar, 308savage, Drainbung and 3 others like this.
  13. Oct 15, 2024 at 9:19 AM
    wilcam47
    Will
    Bourbon state
    Parts was actually cheaper than i thought they would be
  14. Oct 15, 2024 at 11:17 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    believe my atv tank vent is causing that. it didnt run real smooth after sitting a couple weeks. ran it hard and all seemed fine. maybe ill try keeping the tank topped off to help.
  15. Oct 15, 2024 at 1:01 PM
    StihlToyota
    StihlToyota Well-Known Member
    Mark
    No. Idaho panhandle
    2001 SR5 4x4 2.7L, 2015 DBCB Sport
    Crown Royal arrived.
    Huge fire box & door
    w.adventures, Kbar, sdk1968 and 3 others like this.
  16. Oct 15, 2024 at 1:07 PM
    StihlToyota
    Mark
    No. Idaho panhandle
    Just enough room to slide the big Osburn Horizon 3500 into the front door of the northern Idaho house
    Going to lift it 18 inches with a stone hearth surround
    Kbar, sdk1968, wilcam47 and 5 others like this.
  17. Oct 15, 2024 at 7:42 PM
    Kbar
    Western WA
    22 OR
    How much for the top end on that Cryobi?
    wilcam47, six5crèéd[OP] and sdk1968 like this.
  18. Oct 16, 2024 at 5:57 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    $43
  19. Oct 16, 2024 at 6:43 AM
    Kbar
    Western WA
    22 OR
    All this gook came off one wiper blade when I cleaned them last night.
    upload_2024-10-16_6-41-25.jpgThe drivers side had a couple small boogers on it I had to use my finger nail. Used them this morning and they were like new. Summers over and I wanted to clean all the bug guts and road grime off. Used a couple hand wipes from my tub o towels
  20. Oct 16, 2024 at 6:49 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    They don't make wiper blades as good as they used to. Seems like they don't last long at all.
