Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Oct 27, 2024 at 9:57 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i get that. in 3 years i changed the oil twice and air filter tooabout 30$ and 30min. total. pretty cheap.
  2. Oct 27, 2024 at 11:02 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    It's not too bad but I'm thinking about space saving. If I can use the B7100 then it's worth it. I'm pretty rural so if I need something it's a 30 minutes to the store and 30 minutes back. So roughly 90 minutes or more for a trip.
  3. Oct 27, 2024 at 11:15 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    same. dr stuff is all shipped. gets here quick too.
  4. Oct 27, 2024 at 12:29 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Space saving you still gotta store the pto version when not in use. I almost got one but pulled the plug remembering I can just burn my deadfall. I still might someday because it’s free mulch
  5. Oct 27, 2024 at 12:39 PM
    Tiedie
    David
    WFOY
    That's my reason free mulch. Got tons of fall along with debris from the storm.
  6. Oct 27, 2024 at 1:19 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  7. Oct 27, 2024 at 1:38 PM
    Tiedie
    David
    WFOY
    Sorry,
    I just didn't mention if you knew anything about this mackissic company. They make merry tillers and such.
  8. Oct 27, 2024 at 1:39 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Oh, no need to be sorry, I just might not have too much info :fistbump:
    Ironically I've heard of the company, but haven't seen anything of the like here in Pennsyltucky :laugh:
  9. Oct 27, 2024 at 4:27 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    mulch with a chipper by yourself is not cost free. gas, beating on my body more, and machine. i just dont prefer burning slash here. either too wet or dangerous.
  10. Oct 27, 2024 at 4:42 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    I’ve looked into the chippers but I think my tractor is a bit small for them. The price of full size tow behind chippers is insane though so I’m also most of the time just burning brush.
  11. Oct 27, 2024 at 9:54 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Looks like a nice piece of gear and from a Pennsylvania company too. :oldglory:
    I have the giant DR chipper, it can turn a huge pile of blow down into chips just about as fast as you can feed it in.
    You really need a 3 man crew to run it efficiently:
    1) To feed the machine
    2) Keeps machine man stocked with branches
    3) Rakes/shovels the chips away from the machine discharge
  12. Oct 28, 2024 at 3:06 AM
    Tiedie
    David
    WFOY
    That's why I'm looking at this particular one because it's supposed to work with 10-30 hp at the PTO. As I get closer I will reach out to every manufacturer to make sure it'll work for me.
    I have a Kubota B7100 with a 3 cylinder 16 hp diesel and 13 hp at the PTO.
  13. Oct 28, 2024 at 4:01 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Had PTO chipper for a while.
    Wife wanted to do her own mulch.
    MANY posts about this in this thread & over at OTT.
    only took a couple of times & she decided it was too much work.
    It set on the shelf a while & I sold it.
    Was a Bx42s. & yes they say you can run it with 15hp...... But that's not really enough.
    You need 20hp @PTO minimum to not bog it down with anything more than branches.
    NO. your B7100 is not enough for one of these. Just too hard on the little workhorse tractor.
    wilcam47, Tiedie, Drainbung and 2 others like this.
  14. Oct 28, 2024 at 5:17 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I can solve all those problems for ya. Just drop it off at an undisclosed location here in Franklin County, Pennsylvania :anonymous:
  15. Oct 28, 2024 at 5:19 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I can see the allure of making your own mulch, but without a treatment product that might get ugly. I have hard enough trouble with termites around here; that would add a whole 'nother level of insanity :rofl:
  16. Oct 28, 2024 at 5:51 AM
    Kbar
    Western WA
    22 OR
    You might think about renting a larger pull behind and trying it out. The benefit here is more power than your pto can handle. Also I hear hydraulic auto feed is the new bees knees. A standalone pull behind you can set it up and use your tractor to haul/move brush to the chipper. I know a guy on 12 acres who rents one a couple times a year and makes massive piles of chips in n a weekend. Think he paid around 400 for the weekend. If you have limited pto hp and don’t want storage or maintenance maybe a rental could be the ticket. Anyways I’ve heard good things about the Mighty Mac and also look at Woodland Mills. They make solid chippers
  17. Oct 28, 2024 at 6:23 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    :fistbump:
    I really appreciate the offer, however I would need a tractor trailer (or 3) to haul all that brush down to you... :D
    308savage, sdk1968, Drainbung and 2 others like this.
  18. Oct 28, 2024 at 6:24 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Oh you little... :rofl:
    You knew EXACTLY what I meant, but yet twisted that around on me :rofl:
  19. Oct 28, 2024 at 6:51 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Rusty 1
    Adam 0
    :rimshot:
  20. Oct 28, 2024 at 6:53 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
