Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Nov 10, 2024 at 7:06 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i do like the idea of a stand alone unit not dependent on phone for this .
  2. Nov 11, 2024 at 5:36 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Depends on how far gone it is, you can patch them with sheet metal and stretch the life a tad longer.
    Kbar and Drainbung like this.
  3. Nov 11, 2024 at 5:38 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Caroline's. Rust Bond
    Our painters use this in the plant.
    It seals, stops, prevents rust. It's hard to even drill thru, dries super smooth slick. Lasts for many years on the bottom of mower decks & bush hogs.
    You can put a good epixy paint right over it.
    Done several mower decks & hogs with it. Never had it wear thru.
    DES2009, VTCAL, Clark27 and 7 others like this.
  4. Nov 11, 2024 at 8:57 AM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Carboline? I’m guessing you meant that and it changed the word.
  5. Nov 11, 2024 at 10:36 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    They have RC lawn mowers why dont they have a Roomba for lawns?? :anonymous:
  6. Nov 11, 2024 at 10:49 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @RysiuM show us that tractor you have over here :thumbsup:
    sdk1968, RustyGreen and Drainbung like this.
  7. Nov 11, 2024 at 10:51 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    They have them. Never seen one in person but watched variouse youtube videos cause its interesting. Seems like most of them you bury a electric fence showing the roomba mower where not to go be it the property line, a garden, tree, play set, other. The roomba mower can only cut off a little bit as the motor does not have high torque and basically has spinning razor blades for cutting. It covers the same area every two or three days so it doesn't get to high, this means for a much larger property the mower may be running 12 hours every day. A lot depends on who installs the electrical bounded fence, pro installers know how tight of curves to make and how much room to leave around obstacles. They don't leave a pretty manicured lawn with nice straight lines as they kind of wander all around just like a roomba does.
    I could see them becoming more popular with people not in the city who have large properties that they just need kept from overgrowing.
    https://www.husqvarna.com/us/robotic-lawn-mowers/
  8. Nov 11, 2024 at 10:54 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  9. Nov 11, 2024 at 11:31 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    I got a similar one for about the same price a few years ago. It’s amazing the things that you find to scope now. Found an exhaust leak on my outboard using it earlier this year. Also found an excuse to replace the anode rod in my water tank just so I could scope it. The neighborhood didn’t think free colonoscopies was a good idea though
  10. Nov 11, 2024 at 11:40 AM
    wilcam47
    Will
    Bourbon state
  11. Nov 11, 2024 at 3:16 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I got tagged, so here you go :)
    Farm Tractor 1966 Ursus C-328, The model says it is the the third variant of Tractor by Ursus factory, 28 horse power. 2-cyl diesel engine, water cooled. 3-speed forward 1 reverse transmission and transfer case (which makes it total 6 speed forward, an2 reverse).
    Registered and road legal. :thumbsup: This is when I bought it:
    Original body parts are gone, the previous owner put body from C-330, which was the later model. By the way the funny part is that 328 and 330 have very similar engine and 330 gained 2 HP just because they raised the max rpm from 2500 to 2800rpm.
    After I bough it I did some repairs of stuff that did not work (like rebuilding the entire pneumatic system), replacing leaking seals and of course change all fluids. I have also added the original cabin, so I can have some roof over my head (soft top). Here is how it stands now:
    Among many cool and simple (almost primitive) solutions in that machine is a speedometer.
    The needle is a ful diameter of the dial (like a compass needle). The top arc shows rpm, the bottom shows the speed. Six arcs at the bottom show the speed at each gear. All driven just from the engine rpm.
    Speaking of simplicity, the pneumatic in this tractor is used only for brakes in attached trailer. So if trailer is not attached there is no need to run a compressor. Factory manual says to disconnect compressor you just remove a v-belt going to it. As simple as that. :thumbsup:
    Drainbung, DES2009, sdk1968 and 5 others like this.
  12. Nov 11, 2024 at 3:22 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That is cool, thanks for sharing :thumbsup:
    Drainbung, DES2009, sdk1968 and 3 others like this.
  13. Nov 11, 2024 at 5:39 PM
    sdk1968
    03 Taco TRD
    Yes & evidently it did it twice. :)
  14. Nov 11, 2024 at 5:51 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    So I picked up my Stump Bucket this afternoon from the Fastenal location a few miles from where I live. CRI ships with Blue Line Freight, and if you can pick up at Fastenal (which is somehow associated with Blue Line) the shipping is "free". Woulda been another $225 to have it delivered to my house :eek:.
    Looks really nice! Got it too late in the day though to really do anything with it. Maybe tomorrow.. :)
  15. Nov 11, 2024 at 6:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    :popcorn:
  16. Nov 11, 2024 at 6:41 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Interesting product. I might just order some and throw it on in the spring and see how it does
  17. Nov 11, 2024 at 6:43 PM
    Kbar
    Western WA
    22 OR
    Pics or it didn’t happen :D
    Congrats!
  18. Nov 12, 2024 at 3:01 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Alrighty we now have our own pressure washing station, took a little time but we got it together and after starting 2 hours later we got 6 bundles of pipe cleaned up. I hope today we get more.
    308savage, Drainbung, DES2009 and 5 others like this.
  19. Nov 12, 2024 at 6:15 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Well... woke up to 60% rain chances today, along with a steady drizzle to prove the 60% outlook correct.
    So... NO STUMP BUCKET PICTURES TODAY. :annoyed:
    But here's a pic of my inside project that I finally started about a week ago. Getting the TV mounted and the audio system hooked up.. after procrastinating for 15 months since we moved here . . .
    I haven't yet figured out a way to use my existing center channel speaker. But there is a recessed speaker in the ceiling directly in front of the fireplace. I need to pull the grill off and see what it actually is to determine if it's suitable.
  20. Nov 12, 2024 at 6:17 AM
    sdk1968
    03 Taco TRD
    It goes on like runny snot... But man does it get hard.
    They coat all the beams in the chemical plant with it then battleship gray epixy paint over it.
    Makes the bottom of your mower deck pretty slippery.
