Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Nov 19, 2024 at 5:13 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    i used to run a large gas powered Genny on an outdoor plug... Feed it backwards & then kill the main breaker. Did this for years & it was great at the time.
    But as our electric/home needs changed so did the generator needs. Once you go to a whole house Genny? You will probably never do anything else.
    We have lived at our new location for about 10 years now & first thing my wife said was if it doesn't have a whole house Genny... She ain't buying the house. It did. She did.... Fast forward to last year & we had to get a bigger system. All the added things outgrew the original set up. It can happen.
    If you are someone in this thread? Its likely. We all have garages or shops, toys, welders, mills, lathes & the wife has her hot tub & heat/AC no matter the conditions outside.
    In a world where power grids are old & suck with lots of huge trees.... Its the best way to be.
    We have talked about it many times: if the power was gonna be off for DAYS or weeks like it has been here before? Id still cycle run & not just let it run 24/7.
    Running for an hour will cycle all my fridges, freezers, HVac, hot water & so on. Shut her down for 4-6hrs then do again. That takes you down to 4hr run time a day.
    We keep a 90 day supply of propane on hand at 24/7 usage, so that would get you really close to a YEAR in cycle mode. Just saying a little "prep" can get you thru a lot of situations.
    NO we are not preppers in that other sense. Had a critically ill child that had to be ready for anything.
  2. Nov 19, 2024 at 5:25 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Standby generators are great until they aren't.
    I had a mouse nest in mine. Thought I had it cleaned out, the genie engine overheated and granaded the lower end.
    Had to replace the motor.
    Check the rubber grommet that the fuel line feeds the regulator. Mine rotted away and allowed the little shits access to the inside of the genie enclosure. I now have stainless steel wool encircling the fuel pipe. No way they gonna like chewing thru that!
  3. Nov 19, 2024 at 5:28 AM
    Tacoma Mike
    Southern Maine
    I “cycle run” also..
    I’ll go out and shut it down, and shovel and snow blow if necessary.
    Or shut it down at night. Sleep and restart in the am (or sooner).
    Don’t need to run it just to use 5/amps waiting for stuff to cycle.
  4. Nov 19, 2024 at 5:54 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
  5. Nov 19, 2024 at 6:18 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    All this talk about generators and transfer switches. I need to run 80’ of 10/2 to a 30amp pedestal for my RV hookup. Tired of running a cord over the driveway.
  6. Nov 19, 2024 at 6:23 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I got to figure out what I'm going to do when our power goes out. Had a generator plug put on the house when we moved in last year. The well pump is on the shop breaker box and has a separate meter from the house. It's about 100' away.
    FastEddy59, sdk1968, Delta09 and 4 others like this.
  7. Nov 19, 2024 at 6:53 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    This is all I have to say . . .
    I don't have any pics of the transfer panel. And it's raining outside. Again.. :annoyed:
  8. Nov 19, 2024 at 6:54 AM
    Tacoma Mike
    Southern Maine
    Show Off
    LOL
    Awesome
  9. Nov 19, 2024 at 6:57 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    It was here when we bought the property last year. It's diesel, with 150gal internal tank and that 250gal external tank. We have propane here, but no natural gas service. So I guess diesel is probably the best option.
    Kbar, sdk1968, Delta09 and 4 others like this.
  10. Nov 19, 2024 at 8:05 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    What in the world? Why? What do you (or previous owner) need 100+kVA of 480v 3ph for?
    Kbar, sdk1968, 2ndhandTacoman and 3 others like this.
  11. Nov 19, 2024 at 8:07 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  12. Nov 19, 2024 at 8:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Kbar, sdk1968, Delta09 and 2 others like this.
  13. Nov 19, 2024 at 8:32 AM
    SR-71A
    Zack
    Southern Maine
    Id hate to be the guy filling the diesel tank lol
    Kbar, sdk1968, FastEddy59 and 4 others like this.
  14. Nov 19, 2024 at 9:01 AM
    golfindia
    Yes.
    pickup truck
    Yeah. An engine of that power output would suck up around 3gal/hr.
  15. Nov 19, 2024 at 9:26 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    We had them topped off before hurricane season. The internal tank took about 75gal and the external took about 125.
  16. Nov 19, 2024 at 9:30 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I don't have first hand experience. The prior owner told me it'll run for a few weeks if both tanks are full. The generator inspector told me that when it runs the fuel consumption will be almost identical no matter the electrical load. I don't know how much if any downtime the previous owner included in his "few weeks" comment.
  17. Nov 19, 2024 at 9:40 AM
    SR-71A
    Zack
    Southern Maine
    Again why? Im genuinely curious.
    Is there more than just residential loads on site? Is that genset feeding a whole neighborhood?
    Maybe the previous owner just wanted to show off haha
    Yeah, thats best case scenario under light load conditions
  18. Nov 19, 2024 at 10:21 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Every home needs 3 phase! :rofl:
    We have a 16 cylinder Cat diesel generator at work that will power just about everything. 14 out of 16 sorters will run off of it. Once they try and start #15 shtuff starts dimming :laugh:
    Kbar, sdk1968, SR-71A[QUOTED] and 3 others like this.
  19. Nov 19, 2024 at 10:24 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    *sigh*
    Nothing like a flat tire to start your day!
    Ah-ha!
    Yep...
    The culprit? A frickin' thorn! o_O :annoyed:
    Also decided it might be time to dig out the snow blower. Fired right up first pull on last winter's gas :yes:
    Kbar, RustyGreen, sdk1968 and 5 others like this.
  20. Nov 19, 2024 at 10:35 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    :anonymous:
