Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you mow in shorts?
  1. Mow, yes, weedeat, no
    42.6%
  2. Mow and weedeat, yes
    33.3%
  3. Pants all the way for me
    24.1%
  1. Dec 7, 2024 at 10:28 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    And least messy, cracking a cylinder line to move them works too. Just messy.
  2. Dec 7, 2024 at 10:40 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Thanks guys. Party over. Heading outside shortly to give it a go. I will report back.
  3. Dec 7, 2024 at 11:19 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I got them from Amazon, just as you see them. They were on sale and I had been looking at them for a while. I'm pleased with the look and feel, and they provide a decent view. On my L3901 they stick out almost exactly the same distance as the outside edge of the rear wheels. They were $21.99 for Cyber Monday....
    https://www.amazon.com/gp/product/B0CGHX7DYG?ie=UTF8&th=1
  4. Dec 7, 2024 at 6:38 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    That's a reasonable deal. I suggest you be extra careful whenever you get near any brush until you're confident in how well they will hold when the meet a errant limb or two. I've knocked mine about quite a few times.
  5. Dec 7, 2024 at 8:58 PM
    ACEkraut
    Aaron
    Durham, Maine
    The good news: Mounted the plow and hooked the connections up. Everything made the right noises. Bad news: The lifting hydraulic cylinder did not move but the hose was clearly kinked and collapsed. Time to replace the hose and see if that does the trick. Thanks for the suggestions!
  6. Dec 7, 2024 at 9:44 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Rubbin’s racin. I mounted mine on my canopy for just that reason.
  7. Dec 9, 2024 at 2:54 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Stopped by the parts/repair shop to get some primer bulbs. A sea of snow covered machines out back. Asked ‘em how busy?
    He said he’s cuttin’ off residential work at Christmas. Just contractors after that.
  8. Dec 9, 2024 at 7:36 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Added benefit of my barn cats. They love voles! It was entertaining watching one of the cats in the yard yesterday playing with a vole. It was throwing it up in the air having a blast with it. Found the vole in the yard afterwards ripped in half.
    2ndhandTacoman, sdk1968, Kbar and 5 others like this.
  9. Dec 9, 2024 at 9:29 PM
    ACEkraut
    Aaron
    Durham, Maine
    Plow update: Not good news. New hose in but the hydraulic ram still does not move. Seems silly to ask but does it matter if one side or the other is connected? In other words, will it not extend the ram if the “wrong” is attached? I did have to heat the end that has the two screws on the top quite a bit to get the bolt out.
    sdk1968 and six5crèéd[OP] like this.
  10. Dec 10, 2024 at 1:18 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    The two hoses on the cylinder have to be connected to the correct ports, if they are backwards then the control will do the opposite, ie down button will raise and up button will lower.
    sdk1968, Drainbung, Kbar and 2 others like this.
  11. Dec 10, 2024 at 3:51 AM
    ACEkraut
    Aaron
    Durham, Maine
    I only replaced one hose so the connections are the same as before I replaced part of the frame. And the left and right directions work on the plow so the pump is functioning correctly.
  12. Dec 10, 2024 at 4:49 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  13. Dec 10, 2024 at 4:50 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It gets worse the longer you stare at it o_O
  14. Dec 10, 2024 at 4:53 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    :amen:
  15. Dec 10, 2024 at 5:18 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Just think of the bolt as a safety release.
  16. Dec 10, 2024 at 5:37 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    What you towing???:wink:
  17. Dec 10, 2024 at 5:38 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Not, sure maybe his battery cart??
  18. Dec 10, 2024 at 5:40 AM
    Kbar
    Western WA
    22 OR
  19. Dec 10, 2024 at 4:35 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    The quickest way to fuck up a truck is to put a plow on it. What caused you to hate your truck?
  20. Dec 10, 2024 at 7:37 PM
    ACEkraut
    Aaron
    Durham, Maine
    :rofl:
    You probably are being serious but your comment strikes a chord of humor for me. I had a 1994 Mazda B4000(Ford Ranger) with a plow on it that I bought off my Aunt when my Uncle passed unexpectedly and tragically. It was a good truck but the Snoway plow and Maine salted road winters took a toll on the truck. Amongst many other issues the final straw was the front axle housing breaking half from rust. Shit, that WAS a beefy part. And it happened, you guessed it, while plowing.
    Fast forward to 2014 and my purchase of my black DCSB OR. Six and a half years later my Dad passed and left me his 2009 Tacoma, with 48k gentle miles on it and a gently used plow. For me in Maine it is needed tool that I use carefully and sporadically. The plow is a Fisher Homesteader. Light duty but plenty for what I need.
    The truck is green and the plate reads SARG-E7 as a tribute to my Dad and his 20 years in the Army, retiring as a Sargent First Class, rank E7. It shall be mine as long as I live.
    And that is how I became a two 2nd Gen Tacoma owner and why a plow makes a bit more sense for me.
    308savage, sdk1968, Kbar and 5 others like this.
