Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    44.8%
  2. After
    58.6%
  3. Neither
    13.8%
  4. I weed whack while someone else mows
    6.9%
Multiple votes are allowed.
  1. Dec 14, 2024 at 2:17 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Dealer was like tappin’ his foot waitin’ for you to chime in. :laugh:
    Like buyin’ a canoe & sayin’ I’m good for paddles.
  2. Dec 14, 2024 at 2:47 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Dealer was pretty worthless except to get me a contract with Deere. I had to do all the legwork cuz he woulda screwed up the order
  3. Dec 15, 2024 at 1:19 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Plow update:
    It works! I was finally able to get some time in the daylight to work on it again today. Started by loosening the hydraulic line at the top of the lift ram first. Activate the pump and no change. Loosened the bottom line and fluid leaked out. Activated the pump and fluid shot out. Removed all hydraulic lines from the lift ram and removed the ram. Took the ram inside to my workbench. Drained the remaining fluid and cleaned the ram up a bit. Put a socket extension through the bottom bolt hole on the ram and stepped on either side then put another socket extension bar through the top and pulled. Hydraulic fluid shot everywhere as the lift ram extended. Cleaned up the mess and went out and installed the lift ram, connected the hoses and the rest of parts, tested the operation and it works! I will still need to replace a few hoses, aim the headlights, replace the rubber torsion bar, zip tie the electrical wires in place and repair a ground wire. But I am happy to have it working and happy I do not have to spend $200 plus on a new lift ram. Thanks to all who offered advice and encouragement.
  4. Dec 15, 2024 at 6:11 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Any of you guys as sick to death of this Gravite' commercial as I am ???
  5. Dec 15, 2024 at 8:29 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Our cable pukes dropped the "TV" feed a month ago and I'm not missing that commercial or the "eye bag" guy.
  6. Dec 16, 2024 at 1:39 PM
    Kbar
    Western WA
    22 OR
    First time ever seeing it.
  7. Dec 16, 2024 at 9:28 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    So it's been raining here leaving the ground very soft. I managed to get my truck stuck in the field out by my barn. For some reason the 4WD wasn't working, and I had to get the tractor out to pull it back to the house. It took quite a few pulls, but I was a little impressed that a 4.5K# tractor was able to pull a 6k+# SD up a muddy hill. I was on my own so I had to put the truck in neutral, turn the truck wheels the direction I wanted it to go and pull it with the tractor. I took me over an hour to go less than 100 yards, but she got it done. :thumbsup:
    While I know this tread sucks without pictures, and I didn't get any pics of the recovery, but I did take a couple of the mud all over the tractor when I was done.:rolleyes:
    308savage, sdk1968, Drainbung and 8 others like this.
  8. Dec 17, 2024 at 3:18 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Good morning y'all did some leaf blowing yesterday but on PVC pipe not leaves although there's mud and some leaves o_O.
    Back at it again today.
    308savage, sdk1968, Drainbung and 3 others like this.
  9. Dec 17, 2024 at 4:45 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Glad you got it out, be careful with that by yourself pulling stuff out. My dad did that once with his flatbed truck, when he got to where he wanted to go he stopped the tractor and the chain came off the truck. The truck wound up further from where it was and the bed was against the cab when all was said and done because of the tree that stopped the truck :eek:
  10. Dec 17, 2024 at 6:57 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I was certainly concerned about it running into something while the truck was unoccupied. I had to navigate an obstacle course of parked trailers, RR ties, garden, and the chicken coup to get to the gate and level ground. Every time it would start heading in the direction of something I didn't want it too, I crossed my fingers and hoped it would stop before it got there. :fingerscrossed::fingerscrossed:
    Tiedie, 308savage, Kbar and 4 others like this.
  11. Dec 17, 2024 at 7:21 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    That's why, even though I don't 4wheel, one of the first things I did was put a winch on my truck. It's just cheap insurance.
  12. Dec 17, 2024 at 10:27 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    that's right.... KIOTI power!!
    They are damn fine tractors.
  13. Dec 17, 2024 at 11:07 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Easy fix for this sir! Never loan out your equipment!!! My buddy on Johns Island SC lent his kubota out to his neighbors and they returned it empty on diesel and dirty. Nope, never, ever going to lend my tractor or tools out. Kinda like the military....they'll find a way to break things because it's the rental car mentality.
    sdk1968, DES2009, Kbar and 3 others like this.
  14. Dec 17, 2024 at 11:09 AM
    FastEddy59
    Eddie
    That’s just disrespectful. To the owner & the equipment.
    sdk1968, 2ndhandTacoman, Kbar and 2 others like this.
  15. Dec 17, 2024 at 12:15 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Steel bumpers and a winch are on my to list for this truck. It'll probably be a while, but I'm glad Ford includes good heavy duty tow points on the front of their trucks!
  16. Dec 17, 2024 at 1:15 PM
    Kbar
    Western WA
    22 OR
    Yea next time just take the tractor down to the barn :rofl:
    Nice work getting the truck out
    sdk1968, KRAMERICA, wilcam47 and 3 others like this.
  17. Dec 18, 2024 at 4:58 AM
    virginiamarine
    Northern Virginia
    I had to learn the hard way of course! I lent my grinder out to my neighbor and he never returned it. Sure, it's an old $50 grinder I bought on sale, but that isn't the point is it.
    I went out and bought a new one and reminded him of the one he still had. Told him to keep it. And now don't bother talking to him or offering help. It's their loss in the end folks. If anything, it's a cheap way to learn my lesson and identify those who would take more than they would give.
  18. Dec 18, 2024 at 6:11 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    The stuff you see on the internet :eek:
  19. Dec 18, 2024 at 6:15 AM
    Kbar
    Western WA
    22 OR
    Yea I got a neighbor like that. Begged me to help level out his front yard. He had a mess of it. When I finally had time to go over there I asked about the stuff he used to spray his gutters and he said yes he’d hook me up. So I went over and spent a couple hrs straightening out his grades and left him to rake it out. When I was done he hands me this empty spray bottle of simple green and says “this is the stuff” like he was doing me a favor. Now I’m not a petty guy but if someone did me a solid like that I wouldn’t hand him an empty spray bottle. Plus I have simple green anyways
  20. Dec 18, 2024 at 7:19 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Thats actually cool! I wouldnt do it but it is cool
