Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jan 18, 2025 at 5:02 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    One of the tricks the scut boys in the JD forums is to purchase and install a second adjustable lift link for the 3 point hitch. Then, with dual wielding adjustable lift links, suck them up on the threads gaining lift height for n attatchments. There’s one on the right for ditch grading and whatnot but having both lets you crank the lift height. At a buck thirty for a second adjustable link I figure I can achieve the same thing by just chopping the stationary link
  2. Jan 19, 2025 at 1:47 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Howdy all, Got the truck stuck again, the 4wd is definitely not working right. Barely on the sloping ground and it started to spin, got no help from the front end. Last time I was much further down the hill by the tree line facing to the right when I got stuck. With that past experience under my belt, getting it unstuck this time was way easier. Only had to reset the steering wheel a couple of times to get back on safe ground and through the gate.
  3. Jan 19, 2025 at 4:01 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Kioti to the rescue!!!
    So you think its the control module?
  4. Jan 19, 2025 at 4:08 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I see the problem.
    It's circled there on the front...
  5. Jan 19, 2025 at 8:32 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    One of the worst experiences of my life. Flushed the Super Doody quickly.
  6. Jan 20, 2025 at 8:14 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I'm doubtful it's a control module, but I don't have a clue yet what's wrong. :notsure: The OBD2 reader doesn't see any problems in the computer. The fact that the front wheels are not moving, while the back ones are hasn't thrown an error code yet.:boom: Either I'm an idiot :rolleyes: and it's user error engaging the 4wd, something physical and not electrical is broke, or IDK. :frusty:
    I need to lift it off the ground and see what is turning underneath when the 4wd is engaged. Right now I'm just thankful it drives just fine in 2wd. I just have to remember to stay out of the fields until I get it figured out and fixed.
  7. Jan 20, 2025 at 8:18 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Does yours have automatic locking hubs or manual?
    sdk1968, 308savage and Drainbung like this.
  8. Jan 20, 2025 at 8:19 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    :luvya:
    I hope my experience doesn't have the same result. I've always loved the SDs. I've wanted one for decades.
  9. Jan 20, 2025 at 8:26 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I remember you telling me you were reading the Bible and you figured out Jesus was a Ford man.
    Would you like to tell everyone how you figured that out?
  10. Jan 20, 2025 at 8:27 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    They are supposed to be both. They are labeled "auto" and "lock". The first time I got stuck before I flipped the 4wd switch so I manually turned the hubs to lock. This time I engaged the 4wd as I went though the gate into the field. So the auto locking should have had plenty of distance to engage.
  11. Jan 20, 2025 at 8:29 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Hopefully it's something simple. I was searching online and there are a number of things it could be. One thing listed was a blown fuse for an actuator. That may be the simplest place to start since you've tried the hubs in both positions.
  12. Jan 20, 2025 at 8:53 AM
    Kbar
    Western WA
    22 OR
    Might be too cold for the solenoid. Did you manually lock them at the hub to confirm you get 4WD?
  13. Jan 20, 2025 at 9:11 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    The first time I did manually lock them and I did not get any power at either wheel. This time I didn't manually turn the hubs or do any additional testing. When things warm backup and dry out, I'll do some testing. I'm going to check the fuses and see watch some YT vids on 4wd issues other people have had. For now it's to damn cold to bother with it.
  14. Jan 20, 2025 at 9:17 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    This is a handy website for info on your fuse boxes. Looks to cover most vehicles for the last 25+ years
    https://fuse-box.info/
  15. Jan 20, 2025 at 9:34 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    On a Toyota forklift today only had 4 people from my department show up today.
    Been moving pipe around, going to start flipping bundles over and see if I can blow em out. Gotta stay close to the plant and not in an icy spot since I'll be by myself.
    sdk1968, Delta09, koditten and 4 others like this.
  16. Jan 20, 2025 at 9:46 AM
    koditten
    Kirk
    Central Michigan
    Lol.
    He walked everywhere...
  17. Jan 20, 2025 at 10:01 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :rimshot::rofl:
    sdk1968, RustyGreen, Delta09 and 4 others like this.
  18. Jan 20, 2025 at 1:34 PM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    I checked the fuses for the 4wd and all were good. Next I think I'll need some warmer/dryer weather. To check for correct vacuum, lift it off the ground and verify the hubs are actually locking or not, is the front driveshaft turning etc.
  19. Jan 20, 2025 at 4:59 PM
    sdk1968
    03 Taco TRD
    oh now thats just not right. i was a chevy man for decades... then they went to shit & Ford got me.
    ok on F150's(newer) they are auto on the hub. you do still have to engage the switch though.... & yes those switches & the actuator do have a history of going bad.
    oh man i love my super dutys. had a bunch of them & for us "farm haulers" they are just hard to beat.
    chev's can pull pretty good in the right set up.... but they cant stop what they can pull... without warping the rotors & cooking the brakes.
    dodge... well they got a good diesel motor.... but you cant keep the body on them & the brakes are ugh too & they ride crap.
    Fords? still tough to beat the ole 7.3 for durability, but im a huge fan of this 6.7 & 6spd set up. They haul, they stop & they ride better when they are empty.
    UNLESS its a dually & then it rides like a stagecoach until you get a few tons on it. They will just beat you to death.
    everybody has their thing when it comes to trucks. i cant knock the 150's when you do what they are designed for.
    but then again i was in a 2025 6.6 gas GMC crewcab yesterday that was pretty friggin sweet!! & it was only $78k~~!!
  20. Jan 20, 2025 at 8:41 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I can't "like" this, it sucks and it's keeping you from using the truck. Does your ferd use their idiotic vacuum locking hubs? My buddies son has a 2000-something F250 that had that issue, it took 3 of us to scratch our heads to troubleshoot it then fix it.
    I'm sure that you know this, but you can set the e-brake to drag just enough to keep the truck from rolling into the tractor while you do the 1 man tow.
