Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Mar 15, 2025 at 10:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Much easier to just buy the tire/rim combo. Faster, too.
    If you feel like fixing the original for a spare, there is that option as well.
  2. Mar 15, 2025 at 10:04 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    was not confident getting the #s to match before buying. btw re- fixing the spring loaded pull start is no fun. it works....sometimes now.
    six5crèéd[OP] and sdk1968 like this.
  3. Mar 15, 2025 at 12:54 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    I take it the old carb is shelacked?
  4. Mar 15, 2025 at 2:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im not sure whats up. got this last fall put gas and oil in it and first pull it lit up like brand new. now its got nothing. new plug, has spark as it bit me, and seems fine. not sure. about the most primative carb ever. dont know whats up.
  5. Mar 15, 2025 at 2:21 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    looks like this. just dont want to buy the wrong part. its almost easier to throw it away and buy another. Screenshot_20250315_141945_Amazon Shopping.jpg
  6. Mar 15, 2025 at 5:05 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Diaphragm type carb? Pull, replace the diaphragm, they cost me about buck each. One tiny crack is all that is needed for them not to work. Ethanol will dry it out and ruin them.
    six5crèéd[OP], sdk1968 and Kbar like this.
  7. Mar 15, 2025 at 5:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    it isnt even that. seems like no parts, 1 jet.
  8. Mar 15, 2025 at 5:42 PM
    fxntime
    I'm still running a 1972 Simplicity snow blower, other then 2 belts, it's just needed a couple diaphragms over the years. Last time I bought a couple and stuck the spares in a sealed plastic bag.
  9. Mar 15, 2025 at 5:59 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Crocs and socks, HAH Crocs and Carharts!
  10. Mar 15, 2025 at 8:04 PM
    Kbar
    Western WA
    22 OR
    When I got my BB I watched some videos and this one helped me with setup and operation. Dave knows his stuff.
    https://youtu.be/wYXcMN7tBjQ?si=5LR9NWQ5DrykRzid
  11. Mar 16, 2025 at 6:41 AM
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I've changed tires on mowers and wheelbarrows and so on. A pair of tire irons, some kind of lubricant, and a bit of patience is what you need. I tend to not even bother trying to get them to seal and just put a tube in right away.
  12. Mar 16, 2025 at 8:43 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i dont think its a diaphragm carb. its an aluminum tube with a straw to the tank and a needle jet. not that ive removed it and put it back it has a slight intake leak. you can see a little fuel weep after a few pulls.
  13. Mar 16, 2025 at 8:53 AM
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    You may be able to pay a motorcycle or scooter shop like $10 to do it.
  14. Mar 17, 2025 at 3:00 AM
    Tacoma Mike
    Southern Maine
    Drop it by the house. I have a manual lawn tractor size tire machine.
    I use it for the snowblowers I fix. Seriously, you can do it yourself. Couple of flat bars and some “rim ease”.
  15. Mar 17, 2025 at 3:00 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Tractor supply should have everything you need.
    But I would have a spare kept it the shed/shop just in case.
  16. Mar 17, 2025 at 3:06 AM
    Tacoma Mike
    Southern Maine
    I made a couple of tire spoons out of bigger old screwdrivers. Worked great. I was a nice guy and now I don’t have them.
    sdk1968, Kbar, Drainbung and 3 others like this.
  17. Mar 17, 2025 at 3:09 AM
    Tiedie
    David
    WFOY
    That's what happened to my ECGS tools sent out to a member in Tallahassee and radio silence since October.
    sdk1968, Kbar, Drainbung and 2 others like this.
  18. Mar 17, 2025 at 3:10 AM
    Tacoma Mike
    Southern Maine
    That is lower than low…
  19. Mar 17, 2025 at 3:17 AM
    Tacoma Mike
    Southern Maine
    If I had room for an old stove/oven in the garage, I’d be doing it. My buddy did a shitload of car parts and smaller car rims(I think) with his…
  20. Mar 17, 2025 at 3:19 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    There's only one person that is allowed to borrow my personal tools, and that's the way I like it.
    At work it can be a PITA to track down my tools. Even though my employer pays for all tools (and they let you get good stuff too, Knipek, Klein, Proto, etc.) I engrave my initials or wrap stuff in pink electrical tape, I still manage to have to track them down if there's a bunch of tools out on a break down. I haven't lost my grease gun yet though. I ordered a new one and promptly sanded down and spray painted it purple. All the guys made fun of me, but I can keep good track of it :rofl:
