Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. Mar 20, 2025 at 10:28 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    The ones from oreilys are what Ive been running. Havent had any issue with them. Their basic line.
    Used to always do NAPA but the past three batteries we had all failed within 2 years. 1 was in wifes car that was driven daily, 1 in our SUV that got driven every other day, and 1 that was in my MR2. The MR2 one sat on a trickle charger a lot so thats a wash but the other two were disappointing.
  2. Mar 20, 2025 at 1:18 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    In my line of work the subject of batteries came up often. I had a salesman tell me that he had worked at a manufacturing facility when he was younger. He said the batteries would come off the assembly line and hit conveyor belts that went different directions. The conveyor belt they ended up on determined what manufacturers labeling was attached to them.
  3. Mar 20, 2025 at 2:37 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    There are only like 3 battery manufactures in the US. But just like how Gas and Oil all "comes from the same plants", they can be different still. I know also at one point Wal marts batteries were from different plants. One tier would be one plant, while the next tier was a different one.
  4. Mar 20, 2025 at 4:14 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    In my experiance brand doesn't honestly matter as long as its not to cheapest option. You are paying more for the warranty then the battery. My fleet mainly uses napa batteries and when we get a pallet you can tell that the same exact battery has been made by more then one manufactor. Personally I use to run NAPA batteries for about a decade and while I never had a issue with them I have switched over to Costco interstate cause the napa store near my old job closed but the biggest perk is its got a 3 year warranty with the sale date attached to my membership.
    I recall seeing a Advance Auto battery label peel off and loo-and-behold underneath was a CarQuest label.
    Of course if you are going offloading with heavy loads and/or long periods I do recommend buying a high end battery.
  5. Mar 20, 2025 at 6:00 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm normally an East Penn/Deka guy, but powersport batteries? I'll just get one up the road at Tractor Supply or if I feel like buying other stuff Rural King.
  6. Mar 20, 2025 at 6:03 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My own equipment I don't bother buying a new battery when it gets week. As long as the small engine stator and voltage regulator are fine, I just use my lithium ion jump pack to start the machine. They so small, can fit in a coat pocket.
  7. Mar 20, 2025 at 6:05 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I was doing that at the end of the past season and honestly it got real old quick. It actually almost wanted to start a couple weeks ago after sitting months, but I had to go back in the house, grab my keys, and grab the jump pack out of the truck :annoyed:
  8. Mar 20, 2025 at 6:13 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Well I found out today (the hard way) that my winch on my tractor isn't working.
    Good news is I had a chain, so did it the hard way........ Chain to tree & to FEL, curl bucket... Moved 18"... Get off reset... Do again. After about 6 of those series it was unstuck.
    Tomorrow will start in to see what's up with the winch.
  9. Mar 20, 2025 at 7:42 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I don't know why, but I never really thought about putting a winch on the tractor. What size is and how did you install it?
  10. Mar 21, 2025 at 2:56 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Maligator sniffs em out.
  11. Mar 21, 2025 at 3:05 AM
    Tiedie
    David
    WFOY
    Morning y'all, they have moved the pressure washing stuff outside again for the production crew. Stupervisor keeps saying it won't be long before pressure washing is finished. I tend to believe him since I heard something from the bosses mouth about hiring a crew to get it done.
    I forgot I got my QCH for the B7100. Will be installing tomorrow morning I hope.
    Y'all have a great day and be careful.
  12. Mar 21, 2025 at 4:19 AM
    sdk1968
    03 Taco TRD
    KR:
    Its a 4500lb winch. I here the solenoid clicking from pushing the button... Nothing visually wrong.
    We'll see here after while. Will jump it direct.
    Think it's a Viper brand.
    Yeah on my hills even this 4wd Kioti needs a winch if it's not dry.
  13. Mar 21, 2025 at 4:37 AM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Might not have enough juice?
  14. Mar 21, 2025 at 7:53 AM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    ive just got a basic badlands 5000 "atv" winch in a hitch mount bracket thingy. Then I just plop it in my weight rack/hitch receiver for the 3 point. The wiring is usually pretty janky but I rarely use it so havent spent the time to fix it.
  15. Mar 21, 2025 at 11:18 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Well, got a little done today, changed oil on mower, mowed some patchy spots that decided to grow better than rest of the area.
    sdk1968, Drainbung, 308savage and 2 others like this.
  16. Mar 22, 2025 at 4:37 AM
    ralfnjan
    ralfnjan Well-Known Member
    Mowing already!? ralph's rule #1, never mow before may. Not to mention I'm day 2 after lithotripsy up the wazoo! No bouncing thank you. I got up this morning and asked if it was tuesday yet (stent gets removed then)
    Rule #2 never cut longer than 30 minutes (not at a time, the whole lawn)
    Rule #3 Never cut more than once per week
    Have had to break all these rules since the spring comes earlier every uyear.
  17. Mar 22, 2025 at 6:29 AM
    wilcam47
    Will
    Bourbon state
    May? Id have a field of hay by then...
  18. Mar 22, 2025 at 8:28 AM
    KRAMERICA
    Middle Tenn
    '18 F250 Super Duty
    Hmmm, 4500lb winch on a tractor that's 4500lbs. That's a bit undersized for the application. You might want to consider going up in size to something like an 8k winch.
  19. Mar 22, 2025 at 12:49 PM
    sdk1968
    03 Taco TRD
    Good catch. & Memory on what my setup weighs!
    Yeah its right there number wise, but its never really pulling that much. Usually block/tackle it.
    When not, its just as a bump while in the seat with the wheels turning & out of the soft spot.
    Then there's that its what I had on the shelf thing. :-0 (still got another one NIB)
    s
  20. Mar 22, 2025 at 12:50 PM
    Tiedie
    David
    WFOY
    Welp got out the B7100 out to stretch it's wheels.
    Tried out the BB with the Speeco QCH today, did a little road work and moved some soil in the garden.IMG_20250322_114224114_HDR.jpg
    Thinking about putting the 5 ft. Scrabe blade up for sale.
