Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Mar 29, 2025 at 2:25 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Usually its just a tab you gently bend. On the float internally
  2. Mar 29, 2025 at 2:55 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Got these two leaking cylinders apart, hopefully I can fetch some seals Monday.
  3. Mar 29, 2025 at 2:58 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    If you search YouTube there are a lot of how to videos on float adjustment :thumbsup:
  4. Mar 29, 2025 at 4:20 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yeah. wanted to fix the tiller carb 1st but uneasy on buying correct part. thought this (easy) one would gain some confidence.:bananadead:
  5. Mar 29, 2025 at 4:29 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  6. Mar 29, 2025 at 5:03 PM
    koditten
    Kirk
    Central Michigan
    I'll be honest.
    The cylinder rebuild is not the most notable part of this pic that impressed me.
    The fact that the fire extinguisher is within reach is the most important thing I noticed.
    I won't lie. My biggest fear is a fire.
    I won't leave the shop until 30 minutes after welding or torching.
  7. Mar 29, 2025 at 7:11 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    I respect that, I'm the same way.
    If I can I do that work outside on the paved forecourt.
    At my work the shop rule (mine) was "no welding after lunch" unless it was a production emergency.
    If something was going to sit and smolder I figured it would be discovered before the end of the day.
  8. Mar 30, 2025 at 5:22 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    We have to fill out fire watch paperwork at work doing any welding. It used to be a 30 minute watch, but something must have really gone down as now it's an hour o_O
    We usually get alerts for arms caught in equipment in our email, but I think I've missed the building on fire one.
    I did almost catch a power curve on fire welding back in a support bar. All was going good till I decided to get one last weld in. Hot spawl got on some grease and "poof"! Not much paperwork for discharging a fire extinguisher, but it was a mess to clean up :anonymous:
  9. Mar 30, 2025 at 8:56 AM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Mini skidsteer is running low on hydraulic fluid. What do you guys usually run?
    six5crèéd[OP] and sdk1968 like this.
  10. Mar 30, 2025 at 9:57 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    reason i own a chipper and dont burn my tree slash. dont want to burn down the county.
  11. Mar 30, 2025 at 11:00 AM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its common by me for both farmers and just homeowners to do "controlled" burns. Farmers of their field and home owners of irrigation ditches. Even the county will burn the irrigation ditches every so often.
    And every year its amazing how many times the fire department gets called for burns that got out of control. So many people end up with half burned yards and crap.
  12. Mar 30, 2025 at 2:49 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Been so many out of control burns this year around here. Every time I'm in the garage the scanner is going off for one it seems. I got a pile of scrap lumber and tree limbs I need to burn off, but there's no way I'm gonna attempt it right now.
  13. Mar 30, 2025 at 5:34 PM
    koditten
    Kirk
    Central Michigan
    Been playing around with this zero turn.
    I picked it up 2 years ago. It was litterally a bucket case. It's been sitting besides the shop until now.
    With my random parts I'm hoping able to cobble it together with all my random parts.
    I scrapped out out an Exmark unit last year. It had a good hydro system, but everything else was shot. Exmark and Toro are the same company, just different factories.
    I'm gonna "Frankenstien" the Exmark system to work in a toro chasis. We will see if it works. Don't we all love a mystery?
    Standby...
  14. Mar 31, 2025 at 2:56 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Morning y'all, serviced the JD mower Saturday. All was good till I checked the drive belt, it's loose so that's on the way. Figured that since I'm changing that one I might as well change the deck belt also and hold onto both as backup until the next time they are changed.
    Got my filters motor oil and hydrostatic oil for the B7100 big maintenance. Probably in the next couple of weeks.
    koditten, Drainbung, sdk1968 and 3 others like this.
  15. Mar 31, 2025 at 4:19 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Depends on what kind of machine it is, there are several different grades available.
    What kind of machine do you have?
    Drainbung and sdk1968 like this.
  16. Mar 31, 2025 at 4:51 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have several hanging in several places around the shop. There are 2 sitting on the work bench, I moved some stuff and haven't hung them back up yet. They won't be far when I do hang them.
    sdk1968, Drainbung, Delta09 and 2 others like this.
  17. Mar 31, 2025 at 5:51 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    I have to do most of my welding and fab work in my garage attached to my house. I can’t lie it makes me nervous everytime I do it I’ll work outside when I can. I’d do a lot more of it if I had a dedicated shop
    NmapFE, Kbar, virginiamarine and 3 others like this.
  18. Apr 1, 2025 at 2:57 AM
    Tiedie
    David
    WFOY
    Planing on buying 1 this year, but gotta wait on some medical bills first.
    Not uncommon for us to burn brush.
    We are in a NO BURN BAN because of how dry and how so much timber fell from the hurricane. Got some bad wildfires going on right now.
    Kbar, sdk1968, Drainbung and 3 others like this.
  19. Apr 1, 2025 at 3:02 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The township decided a couple days to lift the ban and told people to "use common sense". THAT didn't go very well :rofl:
  20. Apr 1, 2025 at 4:12 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Virginia burn law says from February 15th through April 30th you can burn from 4pm until midnight. However, there may be a full restriction at the moment.
