Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Apr 14, 2025 at 12:44 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Lots of outside stuff going on today. Did some fun stuff & some chore stuff.
    Drainbung and six5crèéd[OP] like this.
  2. Apr 14, 2025 at 3:41 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Mowed and weed eated the yard for the first time this year, needed it last week but it was too wet. Thankful for the rain we’ve gotten.
    sdk1968, Drainbung and Casper66 like this.
  3. Apr 14, 2025 at 5:02 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    So you are thankful for the rain that washed you drive out? I'm confused, did I miss something?
    sdk1968 likes this.
  4. Apr 14, 2025 at 5:16 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Went to the dealer and they looked the mower over. They fixed the bar that keeps the belt from coming off but was actually pressing hard enough to damage the belt. For the squeal, they said that is normal, as is the excess slack in the belt. I will use it as is for now. Maybe the belt and pulleys being new just need to wear in a little bit.
    They wouldn't cut the welds and make the adjustable bracket adjustable. So, I guess I will do that in a few years after the warranty is up.
    Unfortunately, while I was there, I checked out the 1025R and went down the road to Kubota to check out the BC23S. Both equipped with a backhoe. At $25k, I'm wondering if I can figure out how to get my '55 Ford 640 to be skinnier to fit where I need to do some ground work......
  5. Apr 14, 2025 at 7:29 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Mole patrol
    upload_2025-4-14_19-28-7.jpgupload_2025-4-14_19-28-22.jpgLittle bastiches!
  6. Apr 14, 2025 at 7:51 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I might have missed your reply. Did you have any issues with the motor after the oil was coming out the air filter?
    sdk1968, six5crèéd[OP] and Kbar like this.
  7. Apr 14, 2025 at 8:14 PM
    Kbar
    Western WA
    22 OR
    Nope. I removed the 90 elbow and run straight pipe to the silicon hose. Still runs like new. I don’t run it on choke like that anymore. All I did was clean out the foam filter with starting fluid and the air box. Runs like a champ
  8. Apr 14, 2025 at 9:11 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    I need to do that. Have a few holes in the grass.
  9. Apr 15, 2025 at 3:04 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Spf, hail, and rain protection.
  10. Apr 15, 2025 at 3:58 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'm thankful I have a drive that can wash out. Coming where I came from with houses everywhere, I'm thankful to live where I can't see houses. I'm also thankful for the rain we've had recently with all the fires everywhere.
    I guess the moral of the story, be thankful no matter where you are or what is going on.
  11. Apr 15, 2025 at 4:23 AM
    koditten
    Kirk
    Central Michigan
    That looks to be a $400 piece of Delrin:eek:
  12. Apr 15, 2025 at 4:28 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Very true! I know I certainly take many things for granted
    308savage, Drainbung, Kbar and 2 others like this.
  13. Apr 15, 2025 at 4:30 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    Lexi works good for that you can still see overhead loads pretty well with it depends on the lift truck though
    Drainbung, Kbar, sdk1968 and 2 others like this.
  14. Apr 15, 2025 at 4:50 AM
    Tiedie
    David
    WFOY
    I have no idea what it is. And most of the stuff I carry is banded coils on pallets.
  15. Apr 15, 2025 at 6:30 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    can't go wrong with the bx23s. That backhoe has come in handy so many times for me already. And, it has allowed me to dig up literally 12-18 tree stumps (at least 4-6 big ones that weighed over 400 lbs) and clear the land flat.
  16. Apr 15, 2025 at 8:23 AM
    Kbar
    Western WA
    22 OR
    A few turn into the cascade range. Get after em early and you might not need a back brace to mow
  17. Apr 15, 2025 at 9:10 AM
    Tiedie
    David
    WFOY
    Found out it's the stuff from the stalls in restroom. They took a piece and cut it down.
  18. Apr 15, 2025 at 12:34 PM
    virginiamarine
    Northern Virginia
    I'm not sure if I should give you a weird side eye look or say good use!
    To be honest with you, I recall breaking down the bathroom stall partitions when I was in somalia (the stadium) to use as floors while living under the stadium seats (they were marble). So it couldn't be that bad to use it as top cover!
  19. Apr 15, 2025 at 2:20 PM
    Tiedie
    David
    WFOY
    :rofl::rofl::rofl:these were left over from the new installation after the the Helene flood. They tore out the entire restroom and redid it from scratch.
  20. Apr 15, 2025 at 5:14 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Sooo remember how we were talking about burning and brush fires and crap a few weeks ago?
    Well they burned off the field in front of our house (around 160 acres) on Friday. Thought they did a good job...disc the perimeter 3 runs, had plenty of guys out monitoring it and all that. It burned off just fine. Well come Saturday around 1pm and the wind started picking up. It got dusty and looked a bit smokey out in the field. Around 230 the wife calls me and says "I think the telephone pole" is on fire. We both stared a bit (this is a good half mile away mind you) before I said Ill grab the fire extinguisher and go check it out.
    And in the couple minutes it took to grab the extinguisher and hop in the truck things got worse. Luckily a different neighbor had come to investigate as well and we both arrived about the same time. He called 911 (as did my wife at that time). The fire jumped the highway and caught the brush on the other side of the road on fire which is also a business (an auto body shop). It spread fast and started burning some of the cars BUT I was lucky and we noticed it had just jumped over by the yellow dump truck/old bus thing (in the right of the photo) so I ran over there with the extinguisher and was actually able to get that area put out but used all the water I had. That pretty much put out the fire on that side luckily.
    Told the neighbor Id go refill and be back. Which I did and it took like 5 minutes. By that time.....pretty much all the cars directly in front were in some stage of burning so wasnt much I could do there. The fire chief/head officer guy had arrived by that time but not the actual fire department. Gotta say he kind of pissed me off as I got out of my truck on our side of the highway and started spraying down some areas still burning/smoldering just to keep it from burning further down that side of the road. But as im doing this he just came up to me with an attitude asking what i was doing and if this was my field and blah blah. just being aggressive. All I told him was i was just spraying down the hot spots over here so it stops spreading till the brush trucks got there. Annoyed me at the time.
    Anyways though once the fire department arrived I just stood back for a minute or two then went back to the house and got the tractor with the back blade on. Since the FD was mostly focused on the business and cars burning, I just set out on our side in the field turning over the smoldering/small fires. At one point on of the other fire officers came up to me and asked if anything seemed to be in danger (there were a few other buildings in the area) and I told him no and was just turning over the hot spots I did find. He thanked me for doing that and just said to flag down one of his guys if anything got bigger.
    but you can kind of see the buildings further down that we were a little worried about. Where I took the picture from was our driveway and had it jumped there too it could have run down the road and there were more buildings and farm equipment not to far down that way.
    As for damage....thankfully the cars that burned were mostly all scrap. There were two tractors parked there that im not sure on the damage. And one box truck was parked along the other side of the cars on fire and took some heat damage (charred paint and the plastic front bumper partially melted). So nothing to bad. That initial area I put out....we went and looked at that and that had the potential to have gotten real bad. To the right of that picture it just turns into a big field of parked scrap cars in grass.
    As for the cause? Our best guess is old leaves or something from the corn piled up in the pivot tracks must not have fully burned. Then the wind picked up, got them hot again and eventually blew them out of the tracks till the found the dry grass
