Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Sep 19, 2020 at 8:04 AM
    #1581
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Well, here's what 90 tons of recycled asphalt looks like.
    My lines don't look nearly as good from above :rofl:
  2. Sep 19, 2020 at 9:03 AM
    #1582
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sheesh!
    six5crèéd[OP] likes this.
  3. Sep 20, 2020 at 4:17 PM
    #1583
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Heat stripped the fender and seat pan on my 3205. Plan to repaint with catalyzed implement paint. I really hate paint and body. I can do it well but hate it. I'd rather be fabbing something.
  4. Sep 20, 2020 at 4:25 PM
    #1584
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Wow... I also hate body work and well unlike you, I don’t do it well ;-)
  5. Sep 21, 2020 at 5:16 AM
    #1585
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
  6. Sep 21, 2020 at 5:16 AM
    #1586
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Did some splitting with brother joe yesterday and his dogs.... good day for it as it was in the brisk side
  7. Sep 21, 2020 at 10:25 AM
    #1587
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Got my starter replaced Saturday, guy gave me a spare engine with the mower and I used the one off of it. Hopefully it last a while.
    Tacoma tailgate test with the jumpbox, it worked!
    Had 2 helping and waiting to test drive it for me.
    Then on with the vacuum system.
    What they did while I replaced starter.
  8. Sep 21, 2020 at 12:15 PM
    #1588
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Picture dump. Did my first ever removal of a reasonably big stump. Think it went rather well. Doesn't go fast with a sub compact, but if you're patient, it gets the job done.
    IMG_20200921_133414.jpg IMG_20200921_133402.jpg IMG_20200921_133354.jpg MVIMG_20200921_140209.jpg
    Should have taken a before picture.
  9. Sep 22, 2020 at 7:09 AM
    #1589
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Question, if that's your float plane at the water (I assume it is from your avatar), how did you get the tractor to your location? :D
  10. Sep 22, 2020 at 7:14 AM
    #1590
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Hoping it's this, just for the photos:fingerscrossed:
  11. Sep 22, 2020 at 7:15 AM
    #1591
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    What does everyone use for diesel fuel treatment leading up to winter?
  12. Sep 22, 2020 at 7:44 AM
    #1592
    Bushed
    Kenora, ON
    Well, I could make up a story about having it choppered in, or as an external load on a float plane, or even piece by piece in my little plane. Maybe by ice road? But the truth is, my property is road accessible. I just trailered it home.
  13. Sep 22, 2020 at 7:49 AM
    #1593
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I use 2 stroke oil at a rate if 200:1 from Walmart in a blue jug, it's probably not the best thing but I have a sticky FPR in my 2003 Duramax and it helps with lubricity, as long as I add it then it doesn't stick. My diesel tractor is a 1993 so it helps lube it as well, I don't think I can recommend it for the newer stuff and doubt it helps with algae, etc.
  14. Sep 22, 2020 at 7:50 AM
    #1594
    RubenZ
    RubenZ Well-Known Member
    South Texas
    2020 Cement Tacoma TRD Off-Road DCSB
    Thats a nice one!!
  15. Sep 22, 2020 at 7:57 AM
    #1595
    RubenZ
    South Texas
    Hey guys. Any of you Garden Tractor Motorheads know what might cause my JD 345's Fuel to stop pumping. I already replaced the Fuel pump and it worked fine for a while and then even the new one stopped pumping which leads me to believe it could be something more internal. My Tractor uses the FD590V Kawasaki Motor which according to my tractors year has the Plastic Gear. I wonder if it could be that.
    po35042 and six5crèéd[OP] like this.
  16. Sep 22, 2020 at 8:00 AM
    #1596
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I'd look for an obstruction in the tank to make sure something isn't moving and blocking the connection, may or may not be that. Does it have a fuel filter?
    RubenZ[QUOTED] likes this.
  17. Sep 22, 2020 at 8:10 AM
    #1597
    Gregthespy
    Gregthespy Well-Known Member
    Greg
    Orlando
    2015 Blue Ribbon Metallic TRD Sport 4X4
    ^ This. I have a friend who scored a free mower from his neighbor because he exhausted almost every option with a fuel starvation issue. My buddy took the tank off and found a small piece of gravel was randomly getting sucked over the tank outlet and causing it to die. :facepalm:
  18. Sep 22, 2020 at 8:13 AM
    #1598
    RubenZ
    South Texas
    Yes i have a clear fuel filter on it so I can at least see if it has fuel to the filter. I'm gonna work on it a bit later today so I'll let you all know.
  19. Sep 22, 2020 at 8:18 AM
    #1599
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Also make sure your vacuum line going to your fuel pump isn't sucking air somewhere :thumbsup:
  20. Sep 22, 2020 at 8:52 AM
    #1600
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I use this all year long.
    Bushed, T-yoda and six5crèéd[OP] like this.
