Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    25.0%
  2. No, stop living in the past
    16.7%
  3. Wanted, but not yet acquired
    33.3%
  4. Have mirrors, need tractor
    25.0%
  1. Apr 18, 2025 at 5:17 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    That....is great news to hear. Congrats!
  2. Apr 18, 2025 at 5:33 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    yours mounts a bit different than mine does. mine has little clips on the top & slides right on, then just has a bolt on either side. what width is that one? (mines 60")
    yes they are quite "mean"... you can clear brush/briars real friggin quick.
  3. Apr 18, 2025 at 8:33 AM
    virginiamarine
    Northern Virginia
    Call me lazy, but I would think that you would have to spend a lot of time pulling brush and such off each bolt too?!? I dunno, I don't have any experience with this type as I also have the bar that attaches on the sides with a bolt and the face of the bar is flat and smooth with nothing protruding.
  4. Apr 18, 2025 at 8:56 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I got the "Pro" model (not because I'm a Pro) because my bucket already had a flat bar that was drilled with 10 holes along the bottom of the bucket. This one ~should~ bolt right on to replace the flat bar.
    As far as the "teeth".... when you look at the pictures on the BXpanded site almost every picture is different as far as the cutting edge goes. The length of this one is 66.75", the same as the flat bar it replaces.
  5. Apr 18, 2025 at 11:17 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    For anyone interested, this is a pretty good deal.
    The same model tractor CK3510SE I bought for $21K, 7 years ago, today for $23.5k or 329mo. Adjusting for inflation it's a few thou less than I paid, that's an awesome deal.
    https://youtu.be/zNRsr8ZyrIA?si=vurfFpONgge8e87S
  6. Apr 18, 2025 at 12:06 PM
    sdk1968
    03 Taco TRD
    Yeah I've got factory bolt on cutting edge... Mine slides over it.
    Nothing wrong with what you have. It's just a bit different from the same people. Will grab ya a pic head on of mine next time out there.
  7. Apr 18, 2025 at 4:03 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I installed it, but didn't have time to try it out.. :(
    Right after the install it was time (3pm) to go out for the afternoon ball session with Boxer (the Weimaraner). :) :)
    Then immediately following that it was out to mow the "Back Forty".. :cool: :cool:
    But here are some pics. I don't know why it is shifted a quarter inch to the driver side.... my measurements I gave them or their fubar.. :confused::confused: And I did have to ream out 4 of the holes a bit, but that wasn't too bad since the bar's holes are countersunk.. I just had to drill a smidgen of the thin part under the base of the bolt head.
    20250418_143506.jpg 20250418_143510.jpg 20250418_143523.jpg 20250418_143529.jpg 20250418_143540.jpg
  8. Apr 18, 2025 at 4:56 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Are those nuts threaded on far enough? Why is that thing offset to one side?
  9. Apr 18, 2025 at 5:19 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    'Cause we in the U.S., not GB...
  10. Apr 18, 2025 at 5:20 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    The shift is either an error in the measurements I gave them, or an error on their part. I haven't had time yet to try to find out. The nuts are about flush with the end of the bolts. I ~may~ be able to get another half turn or full turn if I set my impact on full blast. One of the measurements they ask for is the bucket thickness where the holes are, so I assume the BXpanded people expect the fit to be flush.
  11. Apr 18, 2025 at 5:35 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Good luck getting some sleep tonight.
  12. Apr 18, 2025 at 6:05 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I got the belt routed in the right way, then tried to do something about the broken bolt. I'm going to have to make a hole on the side of the frame to pass the new bolt through, I'm not dropping the transaxle to get to it.
    I could also cut back that casting where the bolt goes through, it looks like it only has to catch the housing to the metal mount that loops back to the frame.
  13. Apr 18, 2025 at 6:07 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Does the off set move to the other end if you flip the bar?
  14. Apr 18, 2025 at 6:27 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    You asking me??? :confused::confused::confused:
    I was working by myself. The Bar weighs about 70 pounds. :militarypress:
    In September 2023 I developed a recurrence of the double hernia that I had surgery for in 2017. :annoyed:
    I keep putting off another surgery cuz I can't find a "good" time to do it. :anonymous:
    And if swapped end-for-end then the straight edge will be facing forward.. that's what I already had with the original bar. :facepalm:
    And it can't be "flipped over" because then the countersunk holes on the bar are on the wrong side... :boink:
    So... the answer is I need to wait until I measure it . . . :hattip:
  15. Apr 18, 2025 at 6:32 PM
    VTCAL
    2021 Sport
    I was just trying to off a diagnostic regarding the hole placement on the bucket vs the hole placement on the new bar.
    for 1/4 inch, it's not worth going to a lot of troubles to find out something that could be ascertained with a tape measure.
    I believe that bar will do all it's designed to do in SPITE of that 1/4 inch!
  16. Apr 18, 2025 at 6:40 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    I know you were just offering a suggestion. The 1/4" is not a big deal, but it's STUPID... whether it was my measurement or their error. I do have a record of all the numbers I sent them on their order specification sheet. It may be next week until I really get time to measure.
  17. Apr 18, 2025 at 7:22 PM
    Kbar
    Western WA
    22 OR
    It’s unprofessional and I’d be inquiring with BxPanded about which pot head punched this thing out on a Friday afternoon.
  18. Apr 19, 2025 at 4:14 AM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Well my Friday went ok??? First thing I weed wacked around the house side of the creek. Then mowed, plowed the garden with the new box blade and tilled it too.
    Then lunch:hungry:. That's when things took a turn. Went out to change out the master cylinder on the BMW motorcycle. Had to remove more than anticipated, wait no I didn't :goingcrazy:. Anyways the master cylinder was nasty inside but it wasn't my issue. Next up brake caliber rebuild both sides o_O. Already watched yt video, I got this. Parts ordered and shipped ✓. Today is weed whacking the other side of the creek where the shop is and mowing. Then motorcycle oil change and drive shaft, final drive, tranny gear oil replacement.
    Busy schedule today :D.
    Hope everyone has a good and safe day today.
  19. Apr 19, 2025 at 4:22 AM
    lynyrd3
    Bill
    East Central Upstate NY
  20. Apr 19, 2025 at 5:57 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    :pccoffee:
