Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Mirrors on your tractor?
  1. Yes, have them and love them
    20.0%
  2. No, stop living in the past
    10.0%
  3. Wanted, but not yet acquired
    40.0%
  4. Have mirrors, need tractor
    30.0%
  1. Apr 27, 2025 at 5:52 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Gave her an oil change and a diaper. She's old, so not too surprising that she leaks.
    Her little sister on the other hand, no leaks.
  2. Apr 27, 2025 at 5:58 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    2 great tractors !
  3. Apr 27, 2025 at 6:06 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I removed and old apple tree from the the back yard
    a buddy want the wood for his smoker
    made some new trellises for cucumbers wife has been wanting them for a couple years
  4. Apr 27, 2025 at 6:08 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Mowed the lawn
  5. Apr 27, 2025 at 11:01 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Haven't put the Kubota to work yet, the oak trees are still in the way. But, the Ford got a lot of use the last few days. I ordered a set of brush forks for it so I can haul more brush per trip. Should be here at the end of the week. Neighbors are happy, I used the blade to smooth out the driveway where all the rock got washed out by the flood. No longer bouncing my head off the roof driving up.
    I'm keeping the Kubota, but decided to give the Ford and my HF backhoe to my dad.
  6. Apr 28, 2025 at 5:18 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Never seen a tractor with a diaper on! lol
    Delta09, sdk1968, Casper66 and 4 others like this.
  7. Apr 28, 2025 at 5:20 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Me either :rofl:
  8. Apr 28, 2025 at 5:22 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does the tractor cry or get pissy when it needs changed?
    Delta09, sdk1968, Casper66 and 5 others like this.
  9. Apr 28, 2025 at 5:25 AM
    virginiamarine
    Northern Virginia
    Did a quick 20 minute job (that's what I tell the wife all the time) in the backyard.
    When I had the concrete poured the below ground drain pipe got buried under the gravel, so I dug it out and extended it 10 more feet to drain properly.
    Measuring the distance I would need.
    Back hoe to the rescue!
    Extended pipe.
    covered again. I added a stainless steel mesh over the opening and put a large rock below it to help divert any water run off.
    Delta09, sdk1968, 308savage and 7 others like this.
  10. Apr 28, 2025 at 5:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    An auctioneer I know, when he sells an old tractor he always says "she smokes and drinks a little but she won't run around on you" :rofl:
    Delta09, sdk1968, 308savage and 9 others like this.
  11. Apr 28, 2025 at 7:23 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Just saw this online for felling trees the way you want with no wedges, it's actually not that stupid as long as you get the anchors drove in top and bottom.
  12. Apr 28, 2025 at 7:29 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Theres a sign in town at local vape shop looks like that...but its using straps to hold it up.and its leaning towards the building. I see it on the way to lowes
    sdk1968, 308savage, Casper66 and 2 others like this.
  13. Apr 28, 2025 at 9:32 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My FIL told me he bought an auger then ask me why it wouldn't cut. I said order these and bring it to me, lol.
    Delta09, RustyGreen, sdk1968 and 6 others like this.
  14. Apr 28, 2025 at 10:57 AM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I use the brush forks n my tiny Kubota and really like them for brush and splitting wood
  15. Apr 28, 2025 at 12:10 PM
    Kbar
    Western WA
    22 OR
    Not that stupid
    :rofl::rofl:
  16. Apr 28, 2025 at 3:03 PM
    Tiedie
    Tiedie Well-Known Member
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    [QUOTE="Casper66,
    [/QUOTE]
    Showed this to the wife and asked what are the dimensions of this?
    So what are they?
    Was planning to make 1 but just venturing into the cucumber trellis thing.
  17. Apr 28, 2025 at 5:11 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    So what are they?
    Was planning to make 1 but just venturing into the cucumber trellis thing.[/QUOTE]
    These are 5” x 16’ I have the posts about 5 1/2’ apart for the arc you could go wider or shorter
  18. Apr 28, 2025 at 5:15 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Moved some wood today...... This was the 2nd largest piece. Screenshot_20250428_171038_Gallery.jpg
  19. Apr 28, 2025 at 5:28 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    If its a big enough tree to need a jack? You just cut the pocket out inside the tree.. no need for the straps...
    Put the wedge cut where you want it to go & have at it.
    Haven't done a tree that needed the jack treatment in a loooong time.
    Most of the time I can just use the FEL on the tractor to put a little pressure on it at about the 10' up location & give it the saw treatment.
    But hey if it worked for em? Power on!
  20. Apr 29, 2025 at 3:59 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    How did it steer carrying this piece? :D
    I know them old Fords were hard to steer without a loader, unless they had power steering :D
