Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    46.7%
  2. After
    56.7%
  3. Neither
    13.3%
  4. I weed whack while someone else mows
    6.7%
Multiple votes are allowed.
  1. May 19, 2025 at 6:44 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    i have one and put a Oregon 14” bar and chain on it. I fell and bucked three 50’ maples with it. Trunks were all 12”-14”. Think I have three 5ah and two 6ah batteries and it was a constant rotation of batteries cooling and 2-3 chargers going. I did it in the cold of December but I kept the batteries inside until time to use so they were somewhat warm. I did toast one of my 6ah batteries. It was brand new so Dewalt did replace it. Not sure if i ran it too hard or just a bad battery. I would not recommend that big of a job for it but it did it and held up just fine. I think it would make a great option for a trail saw if you have a handful of batteries.
    Photos of two of the 3 felled trees, one after I limbed the closest one in the first photo. Then the last one after i bucked it.
  2. May 19, 2025 at 9:34 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    K-582
  3. May 20, 2025 at 11:23 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I mounted the display to the hood using the magnets and lower bracket from a Starlink Antenna Dish mount. The magnets are VERY strong, but can be removed if I come up with something better. I still need to run power to the display. Planning to use a Tap-a-Fuse from the fusebox shown at the lower right in the picture. The display is removable for storage by a single thumbscrew from under the center of the display bracket.
    20250520_110003.jpg 20250520_114624.jpg 20250520_105453.jpg 20250520_105440.jpg20250520_114616.jpg
  4. May 20, 2025 at 4:05 PM
    TVphotog97
    TVphotog97 Well-Known Member
    Codie
    Upstate South Carolina
    2019 White Tacoma SR5
    Well, I feel as though I’m eating crow a little today. Did all that maintenance Saturday on my mower and went to cut this afternoon….turned on the blades and something didn’t sound right. Shut it down and checked to make sure the blades were tight. They were, so I tried again and got the same result, this time I heard a very brief metal-on-metal grind that had to come from the blades.
    Checked it out again and found a chunk of the deck belt missing. Perhaps I should’ve considered replacing the belts already, but they didn’t show any prior visible signs of cracking that I could see. I got 4 years and 200 hours out of it. Now looking up part numbers to check prices and get everything ordered. I figure it would be a good idea to replace the other two belts as well while I’m doing this one.
    My question is, could that one belt issue cause the metal grind I briefly heard? Maybe the spindles weren’t spinning like they should? I rotated the blades by hand and it seemed fairly smooth. Sorry if that’s an ignorant question but I’m not too sure on that stuff in particular. Not easy to get photos with the deck attached, but here’s one below of the belt culprit. Any advice is greatly appreciated! Thanks.
  5. May 20, 2025 at 4:19 PM
    ralfnjan
    ralfnjan Well-Known Member
    You guys sometimes make me feel embarassed.
    I have a 30-40 year old Murray mower. I put new blades and belts on it, fresh hytrans fluid in the transmission (about $150). Worked much better, until I trailered it to my model flying club field. The engine would start and run, but when the clutch was let out it would die. Good thing there was a mower already there.
    Brought it home and looked up what it might be. Start with the easiest, seat safety switch. Already disabled. Found the clutch/brake switch. Double throw (2 contact sets), one on and one off, when closed the functions changed. Head scratcher. I jumpered the set that eliminated the clutch safety. But the deck wouldn't run then, same thing, engine dies. Figure that there's a switch hidden somewhere.
    Found a little panel by the operator's knees, I'd never seen before. Inside I found the switch on the mower lever...at least 4 wires going in and out. Figured what the hell, took it out, used a zip tie to hold it in the closed position. Engine keeps running, mower operates. No schematics, no safeties. I'm the only one who uses it, so I know to still use the clutch/brake and not start it in gear (hydrostatic) or with the blades engaged.
    When you're given stuff, and it's old but it works, whatever keeps it working is acceptable. At least to me.
  6. May 20, 2025 at 4:39 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Some belts have metal braiding in them. Are there grease zerks (nipples) on those spindles? Also, are your blades right side up? A loose or torn belt can make quite the racket. Get a new belt put on there and see what happens. Check back then
  7. May 20, 2025 at 5:02 PM
    TVphotog97
    Codie
    Yes, there are zerks on the spindles, and just serviced on Saturday. I thought about the blades being incorrect but double checked again and they are correct. Yeah, Ill know maybe a little more once a new belt is on.
  8. May 21, 2025 at 4:25 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    If you still hear metal on metal, check it in the dark, that'll tell you where the sparks are coming from, if there are any :anonymous:
    wilcam47, Drainbung, sdk1968 and 2 others like this.
  9. May 21, 2025 at 6:45 AM
    Kbar
    Western WA
    22 OR
    Happy hump day
  10. May 21, 2025 at 7:11 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    I like it! Magnet mount is good on older Kubotas.... All the new ones are plastic hoods! Then ya gotta go with the suction cup mount.
    Now find more grinding to do & get that practice in! :yes:
  11. May 21, 2025 at 7:25 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    On mine the part over the instrument cluster is plastic, but the hood is steel. :thumbsup:
  12. May 22, 2025 at 5:23 AM
    Kbar
    Western WA
    22 OR
    Happy Friday Jr
  13. May 22, 2025 at 8:13 AM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    I thought I was done burning wood after I sold my last house but I'll be damned if the one I bought has a wood burner in it. Talking to my new neighbor he said he had a bunch of trees down at his other property and I was welcome to go cut up what wasn't already cut and use myself. What he didn't tell me was that whoever cut the wood before me thought it would be a good idea to throw all the cut-up pieces on to the logs that weren't cut. Which of course made things immensely more difficult.
  14. May 22, 2025 at 5:26 PM
    SomeTacoDude
    So I cut this with a Stihl 361. Had a 28" bar on it the dealer said I could upgrade to. And it preformed well but bogged at times. Also the oil pump struggled to keep the bar oiled. So I downgraded to a 25" bar for this and it went through some rather large logs like butter. Stihl dealer here is Rural King. Wanted an over the top amount for the bar. Got this from Amazon for less than the bar at RK.
    https://www.amazon.com/dp/B094ZF4QR5?ref=ppx_yo2ov_dt_b_fed_asin_title
  15. May 22, 2025 at 5:35 PM
    sdk1968
    03 Taco TRD
    Yeah that's a lot of bar for that saw, especially in hardwoods.
    I only run the 24/25bar on the 391 to avoid the bog. & do run the yellow chain.
    six5crèéd[OP], Drainbung and Kbar like this.
  16. May 22, 2025 at 8:44 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Added a cheap canopy.
  17. May 23, 2025 at 3:50 AM
    Kbar
    Western WA
    22 OR
    It’s Friday!
  18. May 23, 2025 at 3:50 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have a 25" for my 036, it does good but I also got a 20" for it for when I'm not cutting large stuff. The 20" is real nice and has plenty of power!
  19. May 23, 2025 at 3:51 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That is...................nice o_O
  20. May 23, 2025 at 3:53 AM
    Kbar
    Western WA
    22 OR
    What’s that saying go?
    If it works it ain’t stupid….?
