Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    48.4%
  2. After
    54.8%
  3. Neither
    12.9%
  4. I weed whack while someone else mows
    6.5%
Multiple votes are allowed.
  1. May 26, 2025 at 12:14 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
  2. May 26, 2025 at 3:57 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    That beats the heck out of a grinder, gets it done right now. :thumbsup:
    :transformer:
  3. May 26, 2025 at 4:22 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Thats cool!
  4. May 26, 2025 at 7:33 PM
    SomeTacoDude
    I'd like to think I'm a pretty open-minded guy. I can't tell you how many times I've been at work around a skid steer with auger attachment and never put two and two together. After watching that video it's like how the f*** did I never think of that.
  5. May 26, 2025 at 9:53 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Well, I finally got spark back on my '55 Ford 640. Battery, plugs, and plug wires. Those were old and needed replaced anyways. Coil because I was getting funky readings (turned out bad dmm wire). And finally ignition module because nothing else gave me spark back.
    The only problem, she still won't run. She will try to start and spit and sputter for 1-2 seconds then die. #1 almost TDC with rotor on #1 post. If I advance or retard it a couple degrees it doesn't even try to start.
    I found the gas gas a very weak smell. When I dump the fuel bowl on the ground and light it, it burns but not as violent as I'd expect with lighting it immediately. Tomorrow, I am going to test the gas for ethanol and water (which I am seeing a bit of clouding and separation in the fuel bowl).
    Who knows, maybe the world gave me a FU and took out my ign module at the same time as the bad gas hit after I dumped a fresh 5 gallons in it from a can.
    On a lighter note, I can't leave good enough alone. Adding a fan to the Kubota. I'll set it up as a puller so it blows straight down. Going to wire it to the 12v plug in the glove box.
  6. May 27, 2025 at 4:22 AM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    That fan on the canopy is a good idea, I could have used that bush hogging many times!!!
  7. May 27, 2025 at 4:23 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That is cool!
    That is a nice machine as well, if I tried that with mine it would probably flip it cause it's not big enough for something like that :rofl:
    sdk1968, Drainbung and Kbar like this.
  8. May 27, 2025 at 2:46 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Hi guys,
    I have a 'baby garden tractor' question. It's on my 2001-ish crapsman GT ( no numbers after the GT) Hydrostatic, V twin Kohler 46" deck.
    It will turn a stupid sharp left hand turn and it needs 2X the space to make right hand turns. When the wheels are pointing straight ahead, it looks like the steering gear is pretty much centered on the rack gear. ( Sorry if I'm not using the correct terms for the steering gear parts)
    Did these rigs just turn very sharp to the left in order to get the edge of the cutting deck close to obstacles or is something amiss?
  9. May 27, 2025 at 3:34 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Kinda like this??
    https://www.mytractorforum.com/threads/gt5000-turning-problem.140769/
  10. May 27, 2025 at 5:16 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Have y'all ever used this stuff? My buddy's wife's brother swears by it... and he managed to get my seized toplink freed up (after I gave up and bought a new one). His dad used to own a welding and metal fab shop, and he's good with working with metal.
    Anyway, I bought two cans of this pricey stuff... one for me and one for my buddy..
    wdb, 2ndhandTacoman, ACEkraut and 6 others like this.
  11. May 27, 2025 at 6:57 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Never used the stuff myself but I heard good things about it. I personally use the PB Blaster penetrant but I got some pretty big fuckin hammers and wrenches and torches and plasma cutters so no flimsy top link is stupid enough to try my patience :rofl:
  12. May 27, 2025 at 7:32 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Yep. Stuff works good.
  13. May 27, 2025 at 7:39 PM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Yep always got free at work. Awesome stuff in air tools & nut soaking.
    That's a fancy new can style though. We always had those old orange cans that leak off the propellent cause the stuff is so penetrating it cant even keep the aerosol in the can.
  14. May 28, 2025 at 4:38 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I've heard good things about it, never used it though.
    My go to is the hot wrench :anonymous:
    sdk1968, jester156, wilcam47 and 4 others like this.
  15. May 28, 2025 at 5:42 AM
    Kbar
    Western WA
    22 OR
  16. May 28, 2025 at 7:39 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    What in the world is this? It wanted to be a gooseneck but changed it's mind :confused::confused::confused:
    sdk1968, Kbar and wilcam47 like this.
  17. May 28, 2025 at 10:15 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I have heard of it and that it works but not used it myself. Check out this YouTube channel for testing of penetrating oils and how well they work. The guy does a great job with product evaluations.
    https://www.youtube.com/c/projectfarm
  18. May 28, 2025 at 11:07 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Yikes!! Kroil was the WORST performer in that guy's test. I guess that serves to CONFIRM what I had been thinking. Me and my buddy LOOSENED the thing before the wife's brother ever got his grubby hands on it.. :D:D:D
  19. May 28, 2025 at 11:38 AM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    I like that he does the testing for many things in a practical way for application and that he's not sponsored (according to him). I'm so tired of these so called "influencers" who are basically straight up lying and spewing such bs. Go get a real job I want to tell them. Just because there are a few who are very successful doesn't mean you get to ride off their coat tails and think you are too. For every 1 successful influencer there are probably 478,081 others who fail. ok...off my soapbox. Sorry for the rant. I just happen to notice I get suggestions now that include those from influencers and I personally think they're all just losers that don't want to get a job but want to tell others what to do. It's not generational....it's ego maybe.
  20. May 28, 2025 at 4:39 PM
    Kbar
    Western WA
    22 OR
    Yea been watching project farm for years and he’s a keeper. All the time he puts into non biased comparisons is to be commended. Good apple that one
    sdk1968, ACEkraut, wdb and 3 others like this.
