Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Jun 28, 2025 at 7:58 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    Started a little job for a neighbor yesterday.
    His place is like mine, completely surrounded by trees/brush & over the years it has gotten away from him to where he just has a little yard left & a few paths to area's. The rest has been totally taken over by briars & softwoods.
    He's retiring next week & wants to start getting his place back into shape, so he's hired me to clear up some brush & so on.
    Went over with the tractor & the hog .... Started at his front porch area & with the piranha bar started pushing downhill away from his house. Its steep. 15 degrees & more down to a drain out bottom then back up the other side.
    Of course it rained the night before. Told him we would push some down, hog it & then let it dry for a few days & come back .... Push some more. Work our way to the bottom then move over to the other side.
    Sounds simple right? Most of this was 10' high or more. Should of took pix.
    Spent about 2hrs pushing down hill clearing soft woods & briars. Then flipped around & started hogging it.
    Did all the hogging facing away from his house going downhill backwards. Took about an hour to do that.
    At this point the ground was getting too slick for travel & was starting to slide or spin. That's where it was time to stop for the day. It was also where my back had had enough. He was a little disappointed that I stopped at 3hrs ish, but he also could see it was getting counter productive. Told him we would let this dry & do another couple hours next time.
    He did really like how what we did turned out though. Already doubled what he has to mow & its mow ready for his rider when it grows in. Pushed out dozens of soft woods, several of which where near a foot diameter.
    Worked the tractor pretty hard. Later after we run out of tractor able stuff will take the excavator & mini hog on it to try & some detail hard to reach stuff.
    Today is back recovery day.
  2. Jun 28, 2025 at 12:19 PM
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    Got mower running and back in neighbor’s hands. Repairs made:
    Carb rebuild
    New flywheel shear key
    Valves adjusted to spec
    Replaced blown head gasket
    Replace defective Auto-choke thermostat.
    Was able to drill out broken exhaust bolt and broken extractor (my fault) using carbide bits . Installed Heli-Coil.
    Result!
    sdk1968, RustyGreen, Kbar and 5 others like this.
  3. Jun 28, 2025 at 12:41 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Well good afternoon, while mowing this morning broke the almost broken deck belt on the little JD. Good thing I had a new 1 ready for action. But while I had the deck off I put the Gator blades on. Hard to tell but the discharge was farther out. Which I liked.
    Meanwhile somewhere on the creek doing some Helene cleanup
    IMG_20250628_131705244_HDR.jpg IMG_20250628_132519917_HDR.jpg IMG_20250628_140445174_HDR.jpg IMG_20250628_145148690_HDR.jpg
    Not done yet because of thunder.
  4. Jun 28, 2025 at 12:44 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I need to rent one of those 10-12K units
    sdk1968, Drainbung, Kbar and 2 others like this.
  5. Jun 28, 2025 at 12:46 PM
    Tiedie
    David
    WFOY
    I know right, I am prepping the wife for 1. She said we can't afford one of those, my answer was not yet.
    sdk1968, Drainbung, Kbar and 3 others like this.
  6. Jun 28, 2025 at 12:56 PM
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    I planted that seed too, pretty sure it died quick :rofl::rofl::rofl:
  7. Jun 28, 2025 at 1:23 PM
    wilcam47
    Will
    Bourbon state
    Thats a NO!:wink:
  8. Jun 28, 2025 at 1:40 PM
    Tiedie
    David
    WFOY
    It'll happen just need to get the house paid off. That's in a year.
  9. Jun 28, 2025 at 2:35 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Major pruning and overhaul of the front rock garden. I’m too pooped to pop now
  10. Jun 28, 2025 at 2:39 PM
    Tiedie
    David
    WFOY
    Neighbor came back and finished the branch along the driveway.:D
  11. Jun 28, 2025 at 4:51 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    That is the unfortunate truth.. it doesn't take much for the stock leafs to bend the wrong way and ride the bump stops, hence the K2500 for doing hard work.
  12. Jun 28, 2025 at 5:47 PM
    SomeTacoDude
    SomeTacoDude Well-Known Member
    This guy posted a picture of clearing an area for a batting cage. I, having helped my son to get to a very high level of baseball suggested this wasn't a good site. His response is to go out and look up the results of the games, screen shot them here, and make fun of it. I reply there may be a better use of your time. And for that you suggest I'm retarded? Why do you all think you have to one up everyone? Why is it so important to feel you've "dunked" on someone? It's really sad and I feel sorry for some here.
  13. Jun 28, 2025 at 6:13 PM
    Kbar
    Western WA
    22 OR
    Did you go do some weed wacking like suggested?
  14. Jun 28, 2025 at 6:22 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    There IS a better use of my time than to read any more of your whining... IGNORED.
  15. Jun 29, 2025 at 5:42 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Did it better than I did... :anonymous:
  16. Jun 29, 2025 at 6:03 AM
    Groan Old
    Groan Old Well-Known Member
    Ken
    Newton NC
    Black 2011 SR5 4X4,Double Cab, V6/auto
    Once that cage gets finished, the kid will use it three or four times, then he'll discover girls, or he'll get his first cellphone and the batting cage will become the world's largest animal trap.
  17. Jun 30, 2025 at 2:37 AM
    Tiedie
    David
    WFOY
    Good morning, I really got a chance to try out the Gator blades yesterday. Did notice that the clippings did shoot farther out. I can definitely tell they're heavier, wider.
    Time will tell, hopefully they are my go-to from now on.
  18. Jun 30, 2025 at 6:00 AM
    Groan Old
    Ken
    Newton NC
    I like Gator blades, have them on both my mowers. I can tell they shred the clippings/leaves into smaller pieces, and they still have good enough lift that they work well with my Power Flow vacuum.
  19. Jun 30, 2025 at 9:11 AM
    Tiedie
    David
    WFOY
    I see your in Newton, your only 2 hrs east of me.
    Drainbung and six5crèéd[OP] like this.
  20. Jun 30, 2025 at 10:37 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @koditten any idea what would cause the ground side of the plug from the electric clutch to get hot?
    This is my boss mans g/f's mower that sits outside.
    He bought the wire with both plugs that goes from the clutch to the wiring harness and I went to replace it and the clutch end is molded into the clutch (TSC zero turn, never seen one you couldn't unplug until this one).
    It hasn't blown a fuse, yet. Could it just be a bad connection or you think it's a bad clutch. My thought is if it's the clutch, it would blow the fuse.
    Drainbung and Kbar like this.
