Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.0%
  2. After
    55.0%
  3. Neither
    12.5%
  4. I weed whack while someone else mows
    5.0%
Multiple votes are allowed.
  1. Oct 4, 2020 at 9:27 AM
    #1661
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
  2. Oct 4, 2020 at 9:43 AM
    #1662
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
  3. Oct 4, 2020 at 9:43 AM
    #1663
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
  4. Oct 4, 2020 at 10:57 AM
    #1664
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    Heat stripped my 3205 hitch a few minutes ago. If you don't feel safe then don't do this. I'm an adult and take responsibility for what I do. If you aren't then just don't do it or take all the precautions you need to keep you from killing yourself, I'm not responsible for you, yadda, yadda.
    This took much longer to heat than the sheetmetal did due to the thickness of the hitch. I could wave the heat over the sheetmetal and the paint and PC would blister right up. After I stopped the vid I donned a Left welding glove to finish up. The subsequent heatings took less time because the thick hitch had already soaked up heat.
    https://youtu.be/_57_K2uWBz8
    six5crèéd[OP] likes this.
  5. Oct 4, 2020 at 11:39 AM
    #1665
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Neat method, need to try that sometime.
    The irony of this to me is that it seems like a falling leaf will scratch the paint on my truck -- you passed the torch over that paint for 30 seconds and the paint looked completely undamaged...
  6. Oct 4, 2020 at 6:03 PM
    #1666
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Right about at the max lift with this one...
    The green butt end of a large-ish oak tree. She lifted it, but not happily. Rear end was light and the steering...wasn't.
    Got the rest of it stacked up no problem with a little creativity, though.
    Also cleaned up the mess from 'maintenance day' on the camp road. 4 trailerloads of brush/slash takes up a lot less room when you roll it up into a pile with the tractor :D
    Edit- Also cleaned out a horse farm of a year's supply of manure today, but didn't get any pictures because it was dark at both the 'start' and 'finish' times. 6 full trailer loads (at 5-6 tons per load), though. I'll try to remember to snap a photo of the pile tomorrow before work.
  7. Oct 4, 2020 at 6:06 PM
    #1667
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Love being outdoors in this type of scenery
  8. Oct 4, 2020 at 6:28 PM
    #1668
    Steve Urquell
    Little Ferd is grunting. And thats a load of horse shit. :D
  9. Oct 5, 2020 at 3:48 AM
    #1669
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    86548202-5DE1-47E5-8454-5AB937F1E9C6.jpg Did some post for a fence out of some large post, brother in law had a excavator for the weekend we used it. 86548202-5DE1-47E5-8454-5AB937F1E9C6.jpgAlso broke down a large compost pile and pulled out the log and stumps from a logging operation on my new tract from 8 years ago here is a before I got to take a after 2A79D620-85B8-48A4-B9AE-3D5F688DDADE.jpg
    Bushed, Noelie84, T-yoda and 2 others like this.
  10. Oct 5, 2020 at 8:02 AM
    #1670
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Got a buddy who works on welders. He’s a Kohler dealer. Should have went and seen him instead of putting a used starter on my mower :facepalm:
    Bushed, Steve Urquell, T-yoda and 2 others like this.
  11. Oct 5, 2020 at 8:39 AM
    #1671
    Noelie84
    Noel
    Wales, Maine
    A big load. I dropped 3, shuttled the tractor back home and stacked them into one pile, then shuttled the tractor back to the farm and brought 3 more loads back. By the time I got the tractor back home again it was after dark, which isn't a huge deal because I've got plenty of work lights on it. But I was done for the day, so I'll just stack the other 3 after work tonight. Fortunately I already had a large depression at the back side of my 'work' lot that I can store it in while it breaks down, but a lot of it has already cooked down and is nearly ready to use as it is.
  12. Oct 6, 2020 at 6:18 PM
    #1672
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Went over and cut the deer food plot today with the 140 and reseeded part of it.
  13. Oct 7, 2020 at 3:28 AM
    #1673
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here's a trick I learned from my dad years ago. Take an old conveyor and pull a couple rollers out of it and wire brush, sand, and paint rims. It allows you to roll it for a good even coat and the only thing messed up is the edge but 99% of the time the tire covers that anyway.
    I had to buy 2 new rear rims for one of our 140's. Both of our 140's had one good wheel and one bad one. I saved this good one and only wanted to paint the inside to stop the rust before I mount the tire on it and leave the original finish on the outside to match the other one on the tractor.
    Bigdaddy4760, Bushed, T-yoda and 4 others like this.
  14. Oct 7, 2020 at 8:58 AM
    #1674
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Love tips and tricks from dad
  15. Oct 7, 2020 at 10:20 AM
    #1675
    Steve Urquell
    Grandpa had 3.
    1. Use WD-40
    2.Put a rubber on it.
    3. Don't buy no flat bottles. (Referring to pints of liquor being the most expensive) :D
  16. Oct 7, 2020 at 10:44 AM
    #1676
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Don’t except wooden nickels
  17. Oct 7, 2020 at 6:16 PM
    #1677
    RustyGreen
    sleeping in a chair
    Pavement Princess
    I asked a retiring machinist for words of wisdom on his last day:
    1) Never pass up an opportunity to use the restroom
    2) Never waste "a woody"
    3) Never trust a fart
    He always said he knew all about women and marriage -- he had done it 5 times...
    six5crèéd[OP] and T-yoda like this.
  18. Oct 7, 2020 at 9:31 PM
    #1678
    Steve Urquell
    My co-worker came over tonight. We worked on a sod cutter. I'm gonna help him take up 50ft of sod, spread sb2, and lay down astro turf for a batting cage. Built the sides and bottom a couple weeks ago and tried it on my rear sleeve hitch. It started to cut sod but dug too deep and caused me to spin out.
    Fitted it for depth rollers tonight. Cut some old lawnmower blades up and welded them to the front sides to lead in and slice the sides of the sod.
    Welded some plates on the sides and mounted 2 deck rollers 2" up from the bottom blade. I have 2 pieces of angle cut and drilled to weld to the sides which will bolt to the loader bucket. I'll be able to angle it any way I want and put a bunch of downpressure on it w/o unloading the rear tires.
    I taught him how to weld and let him run some 7018 and flux core wire with the 2 welders. He did pretty good. It's not perfect but it'll hold
  19. Oct 8, 2020 at 8:30 PM
    #1679
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Spread 15 yards of 7/8's this afternoon. Had to clean up the mess left behind when the electrical was trenched out to my garage. Lots of clay around my property, so they back filled the trench with sand. Cleaning up piles of clay took me 3 days, and about half a day spreading stone to make my driveway nice again.
  20. Oct 9, 2020 at 3:15 AM
    #1680
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Looks good, beautiful view too :thumbsup:
    Bushed[QUOTED] likes this.
