Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
How many times a year do you sharpen mower blades?
  1. Once
    66.7%
  2. Twice
    16.7%
  3. Three +
    16.7%
  1. Aug 2, 2025 at 6:24 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Stuff here is planted pretty thick also but is in rows
    six5crèéd[OP] and Drainbung like this.
  2. Aug 2, 2025 at 6:54 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    It's in rows, but they're 6-8" apart.
  3. Aug 2, 2025 at 7:01 AM
    ace_10
    Rural NoVA
    No dairy left in the county. Some beefers, but only a few small herds here and there. Most of the trash hay that gets bailed as required by Land Use tax scheme, gets abandoned in tree lines.
    I half wouldn't be surprised to see the kid with combine next month. lol
    This land was actually a dairy farm for most of the 20th century. The old barn is on the parcel on my other side.
  4. Aug 2, 2025 at 7:04 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    I didn't really have a question, but I was kind of puzzled at the different shape of the plunger on the two solenoids. Thanks for the input on that.. :thumbsup:
    The info I had seen online said to remove the carburetor to change the solenoid. That didn't make sense to me from what I could see looking at the engine. I inquired here last week about the subject and was told the carb didn't need to be removed. The Kohler instruction sheet didn't say to remove the carb either, just drain the bowl and unscrew the solenoid.
    Anyway, the engine shut off fine at low throttle yesterday after I used it. I'm just hoping that it wasn't a fluke :fingerscrossed:
  5. Aug 2, 2025 at 7:05 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    When I started to rebuild my deck, I had to use screw drivers to crack apart all of the petrified layers of build up before I hit it with the power washer.
    I sprayed the underside with silicone spray on hopes that it might help the fresh grass from sticking. Ive only cut once since doing that, so I need a few more sessions before having a look to draw a conclusion.
