Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
Do you weed whack before or after you mow?
  1. Before
    45.0%
  2. After
    55.0%
  3. Neither
    12.5%
  4. I weed whack while someone else mows
    5.0%
Multiple votes are allowed.
  1. Oct 13, 2020 at 6:46 AM
    #1741
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    37 at the house this morning, supposed to rain later. We're inching towards woodstove weather, but unless we get a few cold rainy days in a row it'll probably be after Halloween before I need to fire up the cellar monster. Right now we're just kicking the pellet stove on for 30 minutes or so in the mornings to take the chill off.
    I'd like a diesel for the hauling potential and the resale, but honestly a modern gasser works nearly as well for what I'm doing. At some point I'll upgrade to a dedicated 'work' truck and just have a knockaround beater car for the rest of the time, and that truck will probably be a 1-ton diesel.
    six5crèéd[OP] and T-yoda like this.
  2. Oct 13, 2020 at 7:43 AM
    #1742
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    I hope for your sake , you are digging through that with a tractor/loader and not just a chainsaw. Dozer piles can be very dangerous with their hidden binds/twists and buckles. A hidden bind on a branch of just 1-2 inchs can hit you in the face very quickly. Also if and when you get it untangled and pulled apart - you usually have dirt all over your wood --bad on chain life.
    Take the extra tine to be careful!!
  3. Oct 13, 2020 at 7:48 AM
    #1743
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    72 gallons of windshield washer fluid going in these when I can find time.
    Bigdaddy4760, po35042, T-yoda and 2 others like this.
  4. Oct 13, 2020 at 10:11 AM
    #1744
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    How does one install washer fluid in a tire? Looks a bit time consuming!
  5. Oct 13, 2020 at 10:12 AM
    #1745
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    A friend of mine has a sump pump, will use a bucket and get my kids to help pour it in. I have an adapter that fits the hose and the valve stem for adding liquid.
    T-yoda[QUOTED] likes this.
  6. Oct 13, 2020 at 10:13 AM
    #1746
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Gotcha
    six5crèéd[OP] likes this.
  7. Oct 13, 2020 at 12:05 PM
    #1747
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    the way I will do it when I replace my rears
    https://youtu.be/GjaO0dA0MIw
  8. Oct 14, 2020 at 2:47 AM
    #1748
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    G’morning fellas! Have a good one today... off today so let’s see what I can get into ;-)
  9. Oct 14, 2020 at 3:18 AM
    #1749
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Here’s the fitting that connects to the hose and valve stem. The little thing on the side is to let the air out as the liquid goes in.
  10. Oct 14, 2020 at 4:49 AM
    #1750
    Noelie84
    Noel
    Wales, Maine
    That's way more high-tech than the system we used to fill the rears on my dad's tractor when we replaced them. We just screwed an adapter onto the jug of washer fluid, ran a rubber tube from the adapter to the valve stem, turned the jug over, and stuck a football needle on a compressor into the bottom of the jug. Emptied each jug in like 10-15 seconds that way.
    Did they at least give you a discount for buying in bulk?
  11. Oct 14, 2020 at 8:17 AM
    #1751
    Jtcmedic
    Jtcmedic Shop beekeeper
    Jeff
    Florida
    2014 prerunner sr5
    Bed led, under hood led, secondary auxiliary panel,
    Ya thanks we I’ve been going thru it with my tractor and grapple a life saver
  12. Oct 14, 2020 at 1:04 PM
    #1752
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    How much goes in each tire.... ?
  13. Oct 14, 2020 at 1:10 PM
    #1753
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Started off my morning with filling in some holes with the dirt brother joe brought home. Then did some fishing. No catches but missed 2! Took me into the Lilly pads and was unable to bring then in. Split some wood and stacked . The first pic is the view from the wood pile to the house. Gorgeous day it was4D4B02B0-43A1-4F46-967E-D5FAD7E51A69.jpg 3B9D77DE-E6E6-4EA0-8713-E49C57F6B0B8.jpg A3928B56-273E-429C-A41E-F4513E0AC149.jpg AF868310-385E-4998-BBF8-5AAD9AAE1AB3.jpg 941D12AB-B48F-4F70-B53A-D140093B4593.jpg
  14. Oct 14, 2020 at 1:17 PM
    #1754
    Noelie84
    Noel
    Wales, Maine
    At a guess, 36 gallons.
  15. Oct 14, 2020 at 1:18 PM
    #1755
    T-yoda
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    Sheesh!! That’s a good amount
  16. Oct 14, 2020 at 3:19 PM
    #1756
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Yes, got it through our supplier at our store.
    Noelie84[QUOTED] likes this.
  17. Oct 14, 2020 at 3:19 PM
    #1757
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Supposed to be 35 gallons each :thumbsup:
  18. Oct 14, 2020 at 7:03 PM
    #1758
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Swapped out the mower for the backhoe yesterday on my Kubota GL3130. Did some pond cleanup.
    My naive 85yr old Dad has a neighbor who spends Winter in Florida. We live in Indiana. Two years ago he brought back a plant and asked my Dad to let him put it in his pond to "see if it can survive the Winter". Well, two years later, it had already covered about 10% of the pond. Luckily, it was a near bank dweller, and I could still reach it and pull it our from the bank.
    I have a Taylor-Way (Italian) backhoe attachment. I had always heard it is risky to use 3-point backhoes on Kubota tractors due to brittle steel having been used in the rear diff housings. I got lucky and found a subframe. It extends from the backhoe to about middle of the tractor (visible in 1st pic, just below foot position). All I had to do was make a right angle bracket with some bolt holes to attach to the subframe. I have gotten a lot of usage from it.
    The gray is a hair like root mass floating beneath the plants. Looks like what comes out of the shower drain when clogged!
    Pulled about 10 piles like these from the water. It's like green spaghetti.
    DON'T EVER RELOCATE PLANTS FROM FLORIDA TO ANY OTHER PART OF THE US!
    T-yoda, 95 taco and six5crèéd[OP] like this.
  19. Oct 14, 2020 at 7:14 PM
    #1759
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    That’s crazy :eek:
    T-yoda likes this.
  20. Oct 14, 2020 at 7:18 PM
    #1760
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    My weedeater finally ran out of string today. Took me <2 minutes to restring it. That new head is awesome :thumbsup:
    Gregthespy[QUOTED] and T-yoda like this.
