Tractors, Mowers, Chippers, Trailers, Chainsaws, Generators, Driveway Erosion Control, ETC.
Discussion in 'Off-Topic Discussion' started by six5crèéd, Jan 27, 2020.
  1. Feb 11, 2020 at 10:49 AM
    #161
    fdb03taco
    fdb03taco Well-Known Member
    Danny
    SOMD!
    2014 Tundra SR5 CrewMax 5.7 4x4
    This is a cool thread. I have a Kubota BX25D. It has a backhoe, mid mount mower, and front end loader. My family has 7+ acres. I use it to mow, move firewood, snow plow, and endless other random tasks. It isn't a big tractor, but it does everything I need it to.
  2. Feb 11, 2020 at 10:50 AM
    #162
    six5crèéd
    six5crèéd [OP] Be the light
    Southern Virginia
    8 lugs no plugs
    Show us some pictures!
    Crow_of_judgement and UncleBubs like this.
  3. Feb 11, 2020 at 2:04 PM
    #163
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Not well...
    I think that the wheelbase was only like 6 feet, but that's wheel hub to wheel hub. You'd have a lot hanging off both ends because the tractor as a whole is like 10 feet long. And I'm pretty sure that they're at least 5 feet wide, too.
    And that's IF the trailer could handle the weight, lol. I know that an 8n with fluid in the tires weighs right around 2 tons, and the 9n is pretty similar dimensionally so I can't imagine it'd be too much lighter.
  4. Feb 11, 2020 at 2:09 PM
    #164
    Noelie84
    Noel
    Wales, Maine
    Too far to drive it, I'm assuming?
    six5crèéd[OP] likes this.
  5. Feb 11, 2020 at 2:13 PM
    #165
    Noelie84
    Noel
    Wales, Maine
    Aha. Good reason not to try driving it, then...That's a long way to push.
    Regular 6x12 U-haul should handle it fine. Are the tires loaded?
  6. Feb 11, 2020 at 2:56 PM
    #166
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    It has a clutch, but you can shift between gears, even F to R, without the clutch. I like it. I always use the clutch when taking off, but rarely after that. I also use it forward to reverse, but not required.
  7. Feb 11, 2020 at 4:21 PM
    #167
    Noelie84
    Noel
    Wales, Maine
    So you could load it either forwards or backwards, then. If they were loaded it could be iffy either way; if you loaded it facing backwards too much tongue weight for a Tacoma, and facing forwards not enough. But if they're not loaded then you could load it facing as far forward as possible and the weight of the engine would load the tongue properly. :thumbsup:
  8. Feb 12, 2020 at 6:22 AM
    #168
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    UncleBubs and Crow_of_judgement like this.
  9. Feb 12, 2020 at 8:05 AM
    #169
    lordetaco
    lordetaco Well-Known Member
    Tristan
    Lawton,OK
    2005 Toyota Tacoma
    It really smoothed out the ride on our tractor, and you can pick up three round bales now. We like filling tires cause it takes the weigh off the tractor and puts it on the ground where it belongs, only sucks when you puncture a tire.
  10. Feb 12, 2020 at 10:22 AM
    #170
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Got this mower mounted and the belt is way too long. Ordered another one.
  11. Feb 12, 2020 at 10:41 AM
    #171
    fdb03taco
    Danny
    SOMD!
    Here she is a few years ago on snow removal duty without the MMM. Haven't had to move any snow this year at all.
  12. Feb 13, 2020 at 9:27 AM
    #172
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Couple years ago I had a piece of I-beam and decided to make a one point hitch yard tool with it. Had my buddy powdercoat it.
  13. Feb 13, 2020 at 12:01 PM
    #173
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Had some throttle teeth worn so I tig welded some globs on and ground it back normalish.
  14. Feb 14, 2020 at 6:06 PM
    #174
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    What’s the status on this project? When you picking it up?
  15. Feb 17, 2020 at 7:18 AM
    #175
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  16. Feb 19, 2020 at 11:16 AM
    #176
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Needed a battery box lid and front for this Cub so I made them out of a piece of pitted material to match the rest of the battery box. When the primer dries it should match the rest of the battery box with the pitting.
  17. Feb 19, 2020 at 12:29 PM
    #177
    Hyperion
    Hyperion Member
    Ford 1700, I believe it's a '79 model. Got totally submerged in Katrina, and it was well over a month before we could service it. Flushed all the fluids, new batt/alt/starter, and pulled the injectors and turned it over to squirt all the water out. That's all it took to get it running again and has been mostly trouble free since.
  18. Feb 19, 2020 at 6:02 PM
    #178
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I wish I had your talent!!
    Very Impressive!!
  19. Feb 19, 2020 at 6:27 PM
    #179
    FirsandFire
    FirsandFire Well-Known Member
    New York
    No more Taco. A 2500HD and a Bronco sport
    We stick to green tractors on our little tree farm. (Occasionally orange ones too)
    Our Deere 4440 and 4620
  20. Feb 20, 2020 at 4:37 AM
    #180
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I love the older Deeres!
