Trade up or fix taco lean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 302, Oct 27, 2013.
  1. Oct 27, 2013 at 5:40 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Get new tires, suspension, and new rims then you are set for a long time
  2. Oct 27, 2013 at 5:42 PM
    302
    302 [OP] I love Taylor Swift :D
    Lawrence
    302
    07' DCSB TRD Sport SSM
    Bedside decal
    Is that how you talk to your son when he asks for advice?
    Thanks TXFireman for that info. I've done my own oil changes but never thought about doing plugs and leaf packs myself. Probably a good idea to learn and save myself some money. I'll look into it.
    3
  3. Oct 27, 2013 at 5:43 PM
    302
    Lawrence
    302
    Bedside decal
    Thanks guys, going to make a list and start ordering stuff over winter.
  4. Oct 27, 2013 at 5:43 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Wut?
  5. Oct 27, 2013 at 5:45 PM
    Swank
    Swank Certified Mall Crawling Instructor
    Steven
    Greenville NC
    SOLD/TOTALED
    :rofl: pretty sure the second "baby" is his truck. :cool:
  6. Oct 27, 2013 at 5:45 PM
    302
    Lawrence
    302
    Bedside decal
    Is there one you would recommend? Ones to avoid?
  7. Oct 27, 2013 at 5:46 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I wouldn't. It's way too early for you to get full value for your money.
    I bought a 1996 Tacoma brand new for under $10,000. Then sold it 17 years later for $4,000. That's getting the full value out of a vehicle. :thumbsup:
  8. Oct 27, 2013 at 5:47 PM
    302
    Lawrence
    302
    Bedside decal
    Yes I have a couple baby's (wife and truck) and we have one on the way. The wife and I do I mean lolol
  9. Oct 27, 2013 at 5:52 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  10. Oct 27, 2013 at 6:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You don't have plug wires, and the 4.0 uses copper plugs.
    Cheap job.
    Biggest issue you've got going is the springs.
  11. Oct 27, 2013 at 6:22 PM
    302
    Lawrence
    302
    Bedside decal
    Good to know about the plugs, only ever changed them in my Camry, years ago.
    So if I go with a nice strong set of dakars in the rear, what size do I get for hauling wood? Secondly what so I do in the front to level it all out? Want to make sure I am purchasing the right stuff. Not going to change tire size. Will likely go with AT2's.
  12. Oct 27, 2013 at 6:30 PM
    anotherreject
    anotherreject Well-Known Member
    This...
    All the stuff you listed can be done very cheap.
    The most expensive being tires, check out treadwright for tires and generalspring for leaf packs
  13. Oct 27, 2013 at 6:30 PM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
    If I were considering buying your truck, I'd work a deal and then chop another $800 off for tires. No one is going to pay your asking price if the tires are dry rotted when they come to test drive it. Just my $.02
  14. Oct 27, 2013 at 7:36 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    No worries, man. It's really a simple procedure. In a nutshell, just jack up the truck, set the frame on the stands once you get it up a bit. Remove tires and rear shocks, and I usually take some weight off by dropping the axle a bit, (with the floor jack) and then remove the U bolts, and then drop it down some more to clear springs (axle will drop lower and the spring perches where the springs sit will separate away from the spring packs). Then I just remove the bolts holding the springs in the shackles and replace. Pretty much just reverse everything from there. It would be best to see if there is a youtube video or something, just to get an idea, but it's really simple. Certainly worth your time to do vs paying someone.
  15. Oct 27, 2013 at 7:57 PM
    #35
    Rich91710
    Rich
    Los Angeles
    08 Base
    +1
    After doing Fabtech AAL on my '94 5-lug, I wished I had just bought a new pack.
  16. Oct 27, 2013 at 8:17 PM
    #36
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i have a friend. he wanted a travel trailer bad!! we found him a super clean used one..private sale. about $10k. he went and got a new one for $22k. why? because the shop would finance the new trailer purchase, and not the used one.
    i did want to slap him. you're trying to spend LOTS of money to save A LITTLE bit of money.
    dont be like my friend. spark plugs are easy, cheap..cost you some lunch money. same with diff oil changes..burger and fries for you and a couple of friends..WAY cheap if you dont use some fancy synthetic.
  17. Oct 27, 2013 at 8:29 PM
    #37
    302
    Lawrence
    302
    Bedside decal
    Much appreciated advice folks.
    The plugs, diff change and tires all seem pretty simple. Copper plugs, non synthetic differential, stock tire size for me, nothing extravagent. But this suspension is puzzling for someone like me. So much to choose from. I don't want to lift her really, but can go up an inch if need be. Really just don't want to get the same crummy leaf pack. Love to double my payload capacity if possible, but I have a feeling the stronger leaf packs are going to lift me. If this were your truck, and you had a grand to throw at the suspension, and had some friends that could help with install, what would buy???
    302
  18. Oct 27, 2013 at 8:37 PM
    #38
    Rich91710
    Rich
    Los Angeles
    08 Base
    You're not going to safely double the Tacoma's payload capacity.
    If you need to haul that much, then yes, trade up... to a Tundra.
  19. Oct 27, 2013 at 9:08 PM
    #39
    302
    Lawrence
    302
    Bedside decal
    Really? That's crazy. That's how I pancaked the stock leafs, just a couple full loads of oak. 1370 lbs is like 10 good size oak logs. Love to get 12+ in at a time. Maybe I don't need double the payload capacity but I would like to increase it if at all possible.
  20. Oct 27, 2013 at 9:25 PM
    #40
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    You should get the firestone ride-rite air bags for your rear suspension. It's a bolt in kit that usually costs about $300-350 online. The part number is 2407. You can adjust the ride height super-easy so your truck always sits level. If you keep separate air lines for each air bag instead of tee-ing them together, you can also level the truck side-to-side. A bike pump can fill them up no problem.
