Traded in my 2013 TRD OR 4x4 double cab.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NutsTacoma, Nov 17, 2013.
  1. Nov 24, 2013 at 7:08 AM
    #61
    skiwaves8
    skiwaves8 Well-Known Member
    Pagosa Springs Colorado
    TRD
    Eco boost is a joke,the owner of the ranch I work on bought 3 f450 his is a King Ranch,mine is just the lariat, motor is a beast towing.Although the computer holds it back at times.He bought an eco boost for mileage and comfort and he only got comfort for driving back and forth to the ranch from Cali the 450 empty gets better mileage!!He mostly just uses his jet to get back and forth though!!
  2. Nov 24, 2013 at 9:29 AM
    #62
    NutsTacoma
    NutsTacoma [OP] Active Member
    Northwest Florida
    2013 F-150 XLT crew cab 4x4
    What kind of rear end problems did yours have, I thought Ford had a pretty solid trans in the half ton, sorry you had all kind of problems with yours, and like I've said before "I Loved my Tacoma". If it's big enough for your family I highly recommend it.
  3. Nov 24, 2013 at 9:37 AM
    #63
    Smooth Operator
    Smooth Operator Well-Known Member
    G
    Central, PA
    2013 TRD Sport / Long Bed
    None
    I'm not saying that Ford isn't a great product, I think they have some great advancements but it seems only after their products were seen as failing gas-guzzlers. The turbo is a late idea, and while I don't know much about the EcoBoost, I do know that Toyota is one of the last few companies that has the Body on Frame designs. (Ugh, run-on)
    Stick to your roots.
  4. Nov 24, 2013 at 9:45 AM
    #64
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    The two vehicles I narrowed my choice down to were the Taco and the F-150 XLT 4x4 Quad Cab with Ecoboost (which is the main reason to buy that truck). One of the factors that influenced my decision is that the comparably equipped F-150 cost about $8,000 more, yet in 3-4 years they would have been worth the same amount of money...
  5. Nov 25, 2013 at 8:47 AM
    #65
    xrgilly
    xrgilly Well-Known Member
    tyler
    brooklin, ontario
    2012 dcab lb sport silver
    nadda
    Rear end had a clunk when going into revers...rear seal blew out scorched the bearings and pinion ...trans problem hard shifting it would slam into gear. Hard enough that it would make u think u broke a drive shaft.. rear end of the truck shacking at highway speed. Speakers popping all the time in the winter 4x4 would clunk loudly when engaging it ..even in neutral. .even with the problems I liked the truck. . I just knew I wouldn't be keeping it past warranty so I unloaded it while it was still worth something.. best of luck
  6. Nov 25, 2013 at 8:53 AM
    #66
    xrgilly
    tyler
    brooklin, ontario
    nadda
    Rear end had a clunk when going into revers...rear seal blew out scorched the bearings and pinion ...trans problem hard shifting it would slam into gear. Hard enough that it would make u think u broke a drive shaft.. rear end of the truck shacking at highway speed. Speakers popping all the time in the winter 4x4 would clunk loudly when engaging it ..even in neutral. .even with the problems I liked the truck. . I just knew I wouldn't be keeping it past warranty so I unloaded it while it was still worth something.. best of luck .. ps I had 30000 k when i dumped it
  7. Nov 25, 2013 at 9:00 AM
    #67
    silver streak taco
    silver streak taco Well-Known Member
    I was going to trade my 05 trd 4x4 tacoma for an fx4 but decided to keep it cause its payed off and we already have two f350's and didnt need another full size truck. My smaller tacoma will be my go to vehicle for running around the pasture/land too. We typically drive fords and nice choice on f150
